Re: EcoreUtil.copyAll and EMap [message #1007064 is a reply to message #1007045] |
Mon, 04 February 2013 10:10 |
Martin Taal Messages: 5468 Registered: July 2009 |
Hi Ed,
Ouch, it was a problem in my code, so this post can be forgotten...
gr. Martin
On 02/04/2013 09:38 AM, Ed Merks wrote:
> Martin,
> The Copier is not aware of EMaps. From that perspective an EMap is just a containment reference to the EObjects that
> represent the Map.Entry instances. So the value reference of the map entry will be copied during copyReferences just
> like any other cross reference. The only thing that would prevent copying is if it's a bidirectional reference and the
> referenced object itself has not been copied...
> So try setting a breakpoint (conditional on the reference's name being "value") in
> org.eclipse.emf.ecore.util.EcoreUtil.Copier.copyReference(EReference, EObject, EObject) and see why its not copying the
> reference...
> On 04/02/2013 9:26 AM, Martin Taal wrote:
>> I have a model with an emap where the value is a non-containment ereference. It seems that EcoreUtil.copyAll does not
>> correctly copy the value of the emap elements (it is null). Is this a known issue?
>> If not then I can create a bugzilla (with a testcase) to show the problem.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
FUDForum. Page generated in 0.03108 seconds
