Home » Modeling » EMF » Client-/Server Architecture with Server-Side EMF Model(Building a Client-/Server-Architecture with keeping the EMF Model on Server-Side only.)
Client-/Server Architecture with Server-Side EMF Model [message #1006706] |
Fri, 01 February 2013 13:58 |
Timo Rohrberg Messages: 69 Registered: September 2011 Location: Karlsruhe |
Member |
Hello everybody,
I have a more high-level question related to modeling in a client-/server architecture which I would just like to post here in the hope of smart hints and suggestions...
I need to build a classic 3-tier client-/server business application with a database, a business model, and a GUI. The database and the business model both run on the server part, while the GUI runs on the client part as an RCP application or - additionally - on another server machine as a RAP application to which clients connect via Webbrowser. I would now like to use EMF to model and generate source code for my business model. For example, suppose there are three classes modeled and generated in the business model: A Car, a BMW, and a Mercedes. The latter two extend the Car. The GUI consist of a tabular editor which allows to modify the attributes of the individual business objects (e.g. the color, price, etc.). However, the displaying and editing should work generically at GUI level, i.e. GUI elements do not know the specifics of a Car, BMW, or Mercedes instance, but access all of them as instances of Business Objects. Such a Business Object has some generic methods to retrieve all available attributes and to retrieve and set values for those attributes, e.g.:
List<String> getAttributes()
Object getAttributeValue(String attributeName)
void setAttributeValue(String attributeName, Object newValue)
This allows for easy extending the business model on server-side only (e.g. adding a new attribute to the Car class) without the need of changing the generically implemented client. It will just retrieve all available attributes including the new one and display and edit them via the generic methods.
Looking at EMF, I was thinking of using the eGet() and eSet() methods of EObject which is implemented by all modelled and generated model classes. However, the complete business model still needs to be available to the client side class loader as the actual values are stored within the particular business model classes Car, BMW, and Mercedes.
What I am looking for is to only keep the actual attribute values somehow generically in the objects at client side and when sending them to the server side (e.g. on a dedicated commit) write them to the underlying business object class instances that are only known on server-side and from there persist them to the database.
I was looking at CDO, but with that, the EMF model also lives on the client side. So far, I'm not completely sure if my requirement is just a little weired, or if I missed something, ...
Do you guys have any hint, idea, comment to the described scenario?
Thanks for any suggestions...
Best Regards
Timo
Re: Client-/Server Architecture with Server-Side EMF Model [message #1006710 is a reply to message #1006706] |
Fri, 01 February 2013 14:17 |
Christophe Bouhier Messages: 937 Registered: July 2009 |
Hi Timo, my 2cts from a CDO perspective,
The idea is pretty cool, and a classic problem of model extendibility. Unfortunately, this problems will force you to deal with interpretation of a generic attribute.
which is
attribute[0] => "Rear-view-mirror tagged: Objects In The Rear View Mirror May Appear Closer Than They Are"
You will need to maintain this mapping of attributes which are generic to the actually modelled specific attributes of a Car. so this mapping
will have to be maintained either in 1) runtime (For converting client to server) or 2) when upgrading your meta-model with specific attributes,
and migrating your data.
For 1) I doubt this is actually supported in CDO now, perhaps a custom transaction/commit handler would do the trick?
For 2) Currently in CDO the only viable option for migration, is really spitting out your data first and storing in to the v2 of your meta-model.
I think maintaining this mapping in runtime, is harder to realize, then in controlled fixed and planned migration intervals.
Cheers Christophe
Re: Client-/Server Architecture with Server-Side EMF Model [message #1006714 is a reply to message #1006706] |
Fri, 01 February 2013 14:29 |
Ed Merks Messages: 33113 Registered: July 2009 |
Timo,
Comments below.
On 01/02/2013 2:58 PM, Timo Rohrberg wrote:
> Hello everybody,
> attributes, e.g.:
Perhaps that's unnecessary given that EMF provides much the same
thing... I.e., you can use ReflectiveItemProviderAdapter factory and
will will produce a properties view for any EObject.
> Mercedes.
It's possible to use dynamic EMF. I.e., you could send the client a
serialized version of the Ecore model, and that can be used to
deserialize instances sent to the client from the server. As an example
of this, try using "Create Dynamic Instance..." from the context menu of
the EClass for Mercedes.
> client side.
Yes.
I'm not sure if CDO can deal with a dynamic model in the client side
that corresponds to a generated model on the server side. It should be
possible in principle, but I doubt that's been implemented in practice.
I think dynamic Ecore might be a good fit..
Build metamodels with dynamic EMF
<http://www.ibm.com/developerworks/library/os-eclipse-dynamicemf/>
Discover the Eclipse Modeling Framework (EMF) and Its Dynamic
Capabilities <http://www.devx.com/Java/Article/29093/0/page/1>
> Best Regards
> Timo
Ed Merks
Re: Client-/Server Architecture with Server-Side EMF Model [message #1006719 is a reply to message #1006714] |
Fri, 01 February 2013 14:50 |
Am 01.02.2013 15:29, schrieb Ed Merks:
> Yes.
Yes, a CDO client, i.e., CDOSession + CDOView/CDOTransaction, instantiates EObjects. But a CDO client can be embedded in
a CDO server, i.e., IRepository. Infact that's often the case, especially with web applications such as RAP applications.
> I'm not sure if CDO can deal with a dynamic model in the client side that corresponds to a generated model on the
> server side. It should be possible in principle, but I doubt that's been implemented in practice.
CDO features DynamicCDOObjects. But once the dynamic meta model, i.e., an EPackage that has been constructed dynamically
at runtime, is committed to the repository, it is immutable and cannot be changed thereafter. At least not under the
registered nsURI.
Cheers
/Eike
http://www.esc-net.de
Cheers
/Eike
Re: Client-/Server Architecture with Server-Side EMF Model [message #1006748 is a reply to message #1006706] |
Fri, 01 February 2013 16:36 |
Hi Timo,
And to bring another solution stack to the table... You can also consider the EMF Texo project:
http://wiki.eclipse.org/Texo#Benefits_of_using_Texo
See for a blog of running it all client-server:
http://martintaal.wordpress.com/2012/08/30/taking-emf-to-the-third-tier-the-texo-json-resource/
gr. Martin
On 02/01/2013 02:58 PM, Timo Rohrberg wrote:
> Hello everybody,
> attributes, e.g.:
> Best Regards
> Timo
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: Client-/Server Architecture with Server-Side EMF Model [message #1007084 is a reply to message #1007077] |
Mon, 04 February 2013 11:45 |
Hi Timo,
Yes, on the client you have standard EMF and EMF generated code. The JSONTexoResource implements standard EMF resoure
behavior.
gr. Martin
On 02/04/2013 11:59 AM, Timo Rohrberg wrote:
> Hello Martin,
> thanks to you (and also all the others) for your answers. These are all really valuable information which might guide us
> to a working solution based on current technology - which is great!
> From reading the available information about Texo, it already appears to me a possible solution. But what I don't get
> so far is the following: Once I have EMF-Objects (i.e. instances of EObject) available at GUI-level via the
> JSONTexoResource, will those objects have all the nice behavior of EMF-Objects, such as notification etc.?
> Thanks for any further answer...
> Best Regards
> Timo
The Netherlands
Current Time: Fri Mar 29 08:56:01 GMT 2024
Powered by FUDForum. Page generated in 0.02918 seconds
