F2 focus for a TextHover comment [message #1006667] |
Fri, 01 February 2013 06:21 |
I am looking for a piece of code that could give F2 focus for a TextHover information.I understand that i should be using IinformationControlCreator and IInformationPresenter. Please let me the know the code that should go into getInformationControlCreator and getInformationPresenter. I have used these methods in the AAConfiguration class that extends SourceViewerConfiguration.
This is the code that i am using - @Override
public IInformationPresenter getInformationPresenter(ISourceViewer sourceViewer) {
InformationPresenter informationPresenter = (InformationPresenter) super.getInformationPresenter(sourceViewer);
ITextViewerExtension2 textViewerExtension2= (ITextViewerExtension2) sourceViewer;
ITextHover textHover= textViewerExtension2.getCurrentTextHover();
Point hoverEventLocation= textViewerExtension2.getHoverEventLocation();
int offset= computeOffsetAtLocation(sourceViewer, hoverEventLocation.x, hoverEventLocation.y);
if (offset == -1) {
return null;
IRegion hoverRegion= textHover.getHoverRegion(sourceViewer, offset);
if (hoverRegion == null) {
return null;
String hoverInfo= textHover.getHoverInfo(sourceViewer, hoverRegion);
IInformationControlCreator controlCreator= null;
if (textHover instanceof IInformationProviderExtension2)
controlCreator= ((IInformationProviderExtension2)textHover).getInformationPresenterControlCreator();
IInformationProvider informationProvider= new InformationProvider(hoverRegion, hoverInfo, controlCreator);
informationPresenter.setInformationProvider(informationProvider, IDocument.DEFAULT_CONTENT_TYPE);
return informationPresenter;
public IInformationControlCreator getInformationControlCreator(ISourceViewer sourceViewer) {
return new IInformationControlCreator() {
public IInformationControl createInformationControl(Shell parent) {
return new DefaultInformationControl(parent, false);
private int computeOffsetAtLocation(ITextViewer textViewer, int x, int y) {
StyledText styledText= textViewer.getTextWidget();
IDocument document= textViewer.getDocument();
if (document == null) {
return -1;
try {
int widgetLocation= styledText.getOffsetAtLocation(new Point(x, y));
if (textViewer instanceof ITextViewerExtension5) {
ITextViewerExtension5 extension= (ITextViewerExtension5) textViewer;
return extension.widgetOffset2ModelOffset(widgetLocation);
IRegion visibleRegion= textViewer.getVisibleRegion();
return widgetLocation + visibleRegion.getOffset();
} catch (IllegalArgumentException e) {
return -1;
class InformationProvider implements IInformationProvider, IInformationProviderExtension2 {
private IRegion fHoverRegion;
private String fHoverInfo;
private IInformationControlCreator fControlCreator;
InformationProvider(IRegion hoverRegion, String hoverInfo, IInformationControlCreator controlCreator) {
fHoverRegion= hoverRegion;
fHoverInfo= hoverInfo;
fControlCreator= controlCreator;
public IInformationControlCreator getInformationPresenterControlCreator ()
return fControlCreator;
public String getInformation (ITextViewer arg0, IRegion arg1)
return fHoverInfo;
public IRegion getSubject (ITextViewer arg0, int arg1)
return fHoverRegion;
And my plugin.xml contains the bindings as
<command
categoryId="aaa.editor.command.category"
id="aaa.editor.command.hover"
name="Doc Hover comment">
</command>
<key
commandId="aaa.editor.command.hover"
contextId="aaa.aEditorScope"
schemeId="org.eclipse.ui.defaultAcceleratorConfiguration"
sequence="F2">
</key>
<actionSet
label="Hover Actions"
description="Action set containing text hover actions"
visible="true"
id="aaa.editor.commands.HoverActionSets">
<action
definitionId="aaa.editor.command.hover"
class="org.eclipse.ui.texteditor.AbstractTextEditor.createActions" >
</action>
</actionSet>
With the above code, i am not able to open any code in the editor. It throws NPE when attempted.
Please let me know the steps that i should follow to enable F2 support for the text hover.
Thanks in Advance,
Shyamala
FUDForum. Page generated in 0.26438 seconds
