Re: Eclipse launcher unable for find shared library error [message #1008070 is a reply to message #1006310] |
Fri, 08 February 2013 17:36 |
On 01/30/2013 09:37 PM, john.garrett@xxxxxxxx Garrett wrote:
> I downloaded and unzipped eclipse-cpp-juno-win32-x86-64.zip. I have
> Java(TM) SE Runtime Environment (build 1.6.0_07-b06) installed.
> Whenever I launce eclipse.exe I get an errror dialog displayed stating
> "The Eclipse executable launcher was unable to locate its companion
> shared library. I get the same error message when using eclipse
> downloaded with eclipse-jee-juno-SR1-win32-x86_64.zip. I've tried
> searching the eclipse executable for the shared library name, but was
> unable to find a string matching a shared library (*.dll). The
> eclipse.ini file has reference to a launcher.library entry. The path
> listed with the launcher.library exists with an eclipse_1503.dll file
> within it. I tried adding the dll file name to the path, but it didn't
> solve the problem. Any help will be greatly appreciated.
Although I'm not using windows much, this error happened to me as well
when I unzipped eclipse into a deep folder structure (don't remember the
number of folders...)
have you tried unzipping it, let's say, into C:\ directly?
hope this helps
Lorenzo
HOME: http://www.lorenzobettini.it
TDD Book: https://leanpub.com/tdd-buildautomation-ci
Xtext Book: https://www.packtpub.com/application-development/implementing-domain-specific-languages-xtext-and-xtend-second-edition
Re: Eclipse launcher unable for find shared library error [message #1155541 is a reply to message #1008070] |
Sat, 26 October 2013 00:40 |
Perico De los Palotes Messages: 1 Registered: October 2013 |
I found a lot of material and 'solutions', I will help with the one I found:
The problem was that WinRar, when unzipping (unraring), creates a folder with the same name as the .zip (.rar), and inside another one, again, with the same name!!! The solution is simple: Copy and paste the inner elements into the outer, geniune, folder, and delete the inner one. That way, the route will be OK as read from the launcher.
FUDForum. Page generated in 0.02983 seconds
