Home » Modeling » TMF (Xtext) » Custom error message for unordered groups
Custom error message for unordered groups [message #1006306] Wed, 30 January 2013 18:35 Go to next message
Phil H is currently offline Phil HFriend
since the normal error message for incomplete unordered groups is not really helpful for the user, I would like to change it to a more meaningful.
SyntaxErrorMessageProvider is the way to go, I know so far, but there are hardly any examples or existing documentation which helped me so far.
Has anyone already succesfully changed this kind of error msg?
Re: Custom error message for unordered groups [message #1006316 is a reply to message #1006306] Wed, 30 January 2013 19:27 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
if your are in such a situation the use of the the debugger is always a good starting point.
this will show:
- org.eclipse.xtext.parser.antlr.AbstractInternalAntlrParser.UnorderedGroupErrorContext.getDefaultMessage() is called
- this calls getRecognitionException and getRecognitionException
- the first one delivers a FailedPredicateException which contains the message info for the exception
- but there is other stuff to call too. e.g. getMissingMandatoryElements
The rest is up to you Wink
~Christian
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Custom error message for unordered groups [message #1006331 is a reply to message #1006316] Wed, 30 January 2013 21:17 Go to previous messageGo to next message
Big thanks! I was able to change the error msg now.
Here is the code, for all which are interested:
class EfvmSyntaxErrorMessageProvider extends SyntaxErrorMessageProvider {
	public static String INCOMPLETE_UNORDERED_GROUP = "INCOMPLETE_UNORDERED_GROUP";
	public SyntaxErrorMessage getSyntaxErrorMessage(IParserErrorContext context) {
		if (context.getRecognitionException() instanceof FailedPredicateException) {
			return new SyntaxErrorMessage(
					"The following elements are necassary for an adapter inctance: Name, Tool and Model",
					INCOMPLETE_UNORDERED_GROUP);
		return super.getSyntaxErrorMessage(context);
You talked about getMissingMandatoryElements ect. - in which case and how could I use this?
Cheers
Re: Custom error message for unordered groups [message #1006335 is a reply to message #1006331] Wed, 30 January 2013 21:29 Go to previous messageGo to next message
What about if you have 10 unordered groups, or you want to say what exactly is missing
[Updated on: Wed, 30 January 2013 21:29]
Report message to a moderator
Re: Custom error message for unordered groups [message #1006343 is a reply to message #1006335] Wed, 30 January 2013 22:29 Go to previous messageGo to next message
You're right, but how should I access this methods from IParserErrorContext? UnorderedGroupErrorContext is a subclass of ParserErrorContext. Or am I wrong?
Re: Custom error message for unordered groups [message #1006345 is a reply to message #1006343] Wed, 30 January 2013 22:40 Go to previous messageGo to next message
UnorderedGroupErrorContext extends ParserErrorContext implements IUnorderedGroupErrorContext
Re: Custom error message for unordered groups [message #1006348 is a reply to message #1006345] Wed, 30 January 2013 23:09 Go to previous messageGo to next message
Sry, I don't get it, how to access UnorderedGroupErrorContext from IParserErrorContext..It's a little bit confusing for me right now..
You mean something like: if (context.getRecognitionException() instanceof IUnorderedGroupErrorContext) ??
Re: Custom error message for unordered groups [message #1006350 is a reply to message #1006348] Wed, 30 January 2013 23:22 Go to previous messageGo to next message
yes downcast to IUnorderedGroupErrorContext
Re: Custom error message for unordered groups [message #1006440 is a reply to message #1006350] Thu, 31 January 2013 11:11 Go to previous messageGo to next message
OK, I've got my AbstractElements now, but I don't now how to make the type check. This doesn't work:
if( abstractelment instanceof ConfigurationName){
dosomething...
Where ConfigurationName is a mandatory element of the unordered group.
Re: Custom error message for unordered groups [message #1006445 is a reply to message #1006440] Thu, 31 January 2013 11:22 Go to previous message
Hi I cannot say what to do (doing your work) so use the debugger and
see what you get
Need training, onsite consulting or any other kind of help for Xtext?
Go visit http://xtext.itemis.com or send a mail to xtext at itemis dot de
Previous Topic:IIncompatible implicit return type on short or byte with numeric constants
Next Topic:Run xtext workflow from another plugin project
Current Time: Wed Sep 23 04:36:36 GMT 2020
Powered by FUDForum. Page generated in 0.02595 seconds
