KeyBinding for delete [message #1005917] |
Tue, 29 January 2013 10:00  |
ModelGeek Mising name Messages: 550 Registered: June 2011 |
I am working with a RCP application. I have defined my scheme extending from org.eclipse.ui.defaultAcceleratorConfiguration.
I have defined key for command org.eclipse.ui.edit.delete(M2+DEL).
In my view(containing treeviewer) when user press delete then action is performed but i want it to be performed with (shift + delete) as defined in scheme.
If user tries edit menu then short cut for delete is shift + delete, then why delete key is still working as shortcut?
Do you know what is problematic here?
[Updated on: Tue, 29 January 2013 10:03] Report message to a moderator
FUDForum. Page generated in 0.02710 seconds
