Home » Modeling » EMF » [CDO] Help to debug server-side commit operation
[CDO] Help to debug server-side commit operation [message #1005846] Tue, 29 January 2013 00:58 Go to next message
Warwick Burrows is currently offline Warwick BurrowsFriend
I'm trying to trace a commit operation on the server but haven't been able to hit a breakpoint during the commit operation. I'm trying to trace what happens on the server when the client provides new model packageunits to the server. Can someone direct me to a class/method that is definitely called in the execution path following a commit request from the client?
Sorry, forgot to add CDO to the subject.
Warwick
[Updated on: Tue, 29 January 2013 01:00]
Report message to a moderator
Re: Help to debug server-side commit operation [message #1005854 is a reply to message #1005846] Tue, 29 January 2013 05:28 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Am 29.01.2013 01:58, schrieb Warwick Burrows:
Although you nowhere mention CDO I assume that you do refer to it :P
Where did you set your breakpoints?
> the client?
The first meaningful place would be in
org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CDODataInput, OMMonitor).
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] Help to debug server-side commit operation [message #1005856 is a reply to message #1005854] Tue, 29 January 2013 05:48 Go to previous messageGo to next message
Thanks Eike I'll try that.
> Although you nowhere mention CDO I assume that you do refer to it Razz
Yes again Smile Although I don't understand why you don't see the same updated post subject as I do. I posted this then modified the post to add [CDO] to the subject immediately afterward... I'm talking within 30 seconds of the original post. I guess it's another quirk of the Eclipse forums. Oh and I added [CDO] to the subject again just to be certain Wink
Re: [CDO] Help to debug server-side commit operation [message #1005859 is a reply to message #1005856] Tue, 29 January 2013 06:01 Go to previous message
Am 29.01.2013 06:48, schrieb Warwick Burrows:
>> Although you nowhere mention CDO I assume that you do refer to it :p
> Yes again :) Although I don't understand why you don't see the same updated post subject as I do. I posted this then
> post. I guess it's another quirk of the Eclipse forums. Oh and I added [CDO] to the subject again just to be certain ;)
I suspect that changing posts after they've been submitted is an exclusive feature of the web forum software, which
can't be mirrored to the master nntp: service ;-(
Cheers
/Eike
Previous Topic:Create proxy object for abstract reference type
Next Topic:deleting the namespace
Current Time: Tue Apr 16 13:24:28 GMT 2024
Powered by FUDForum. Page generated in 0.07384 seconds
