Re: Reference issues with EclipseCDT [message #1006148 is a reply to message #1006101] |
Wed, 30 January 2013 09:04 |
J C Messages: 8 Registered: January 2013 |
Jesse Weinstein wrote on Tue, 29 January 2013 16:58You're running the same version as I am, but the build id is about a year older. I don't *think* that's the source of the differences...
Is there some way to update that on Ubuntu 12.04LTS?
Jesse Weinstein
Assuming you want to take the 2nd path, you mention that "know how to solve the problems owed to libraries references (includes)" but you don't "know how to set up eclipse CDT in order to create the references to the own project files/folders". I don't exactly understand the distinction you are making here. Using what you do know, can you make your project build at all?
What I meant was that I do know how to make the references for adding the libraries which sometimes are missing when I index the project, however, when Eclipse complains about some includes which refer to a inner project path, for instance and using the origianl files tree if I have on File B3 a line like #include <FolderA/FolderA2/a2.h> then I got an error saying FolderA/FolderA2/a2.h: No such file or directory
Using what I knew I started to include all the inner folders as a "libraries" were (using includes in C/c++ general >> paths and symbols) but in certain point the same reference errors come back leading to compiling errors.
Jesse Weinstein
If you want to take the 1st path, create a fresh project using the New... > C++ Project ; Executable / Empty Project wizard, and check for the Project References pane there.
Now I have the Project References, there I have ticked my on project but even so I still have the reference errors.
FUDForum. Page generated in 0.03365 seconds
