Home » Modeling » TMF (Xtext) » IIncompatible implicit return type on short or byte with numeric constants
IIncompatible implicit return type on short or byte with numeric constants [message #1005681] Mon, 28 January 2013 09:11 Go to next message
Tommaso De Sica is currently offline Tommaso De SicaFriend
Goodmorning,
I've tryed to use short and byte types in my XBase expression; but I can't assign any numeric constants to them.
If I try to do something like this:
byte b;
b=0;
this error appears:
Incompatible implicit return type. Expected byte or java.lang.Byte but was int
Why this?
Thanks.
Re: IIncompatible implicit return type on short or byte with numeric constants [message #1006329 is a reply to message #1005681] Wed, 30 January 2013 21:03 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
the support for byte vs int seems to be buggy in general with xtend/xbase
https://bugs.eclipse.org/bugs/show_bug.cgi?id=382211
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/xtext/
Twitter : @chrdietrich
[Updated on: Wed, 30 January 2013 21:04]
Report message to a moderator
Re: IIncompatible implicit return type on short or byte with numeric constants [message #1006330 is a reply to message #1006329] Wed, 30 January 2013 21:14 Go to previous message
btw casting seem to work byte x = 0 as byte
Previous Topic:Retrieve info from EMF model in UI action and then use it to modify the model itself
Next Topic:Custom error message for unordered groups
Current Time: Sun Aug 09 15:31:52 GMT 2020
Powered by FUDForum. Page generated in 0.01264 seconds
