EMFTVM doesn't generate output [message #1005537] |
Sat, 26 January 2013 09:26 |
Antonio Moreno Messages: 16 Registered: November 2012 |
I'm developing some transformations in EMFTVM because I need multiple inheritance rules. Like I didn't get any output in all of them, I tried run the example PortsToPins available in Git repository of ATL.
My header of *.atl file is:
-- @atlcompiler emftvm
-- @path Ports=platform:/resource/TestPorts2Pins/Ports.ecore
-- @path Pins=platform:/resource/TestPorts2Pins/Pins.ecore
module PortsToPins;
create OUT : Pins from IN : Ports;
helper context Ports!Port def : pins : Sequen
The run configuration windows is:
h ttp://s8.postimage.org/6cf24q5md/Screen_Shot_2013_01_26_at_10_08_14.png
(paste without space)
Moreover, my launch file is:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<launchConfiguration type="org.eclipse.m2m.atl.emftvm.launcher.EMFTVMTransformation">
<stringAttribute key="ATL File Name" value="//TestPorts2Pins/PortsToPins.atl"/>
<booleanAttribute key="Disable JIT compiler" value="false"/>
<booleanAttribute key="Display Timing Data" value="true"/>
<mapAttribute key="Inout Model Options"/>
<mapAttribute key="Inout Models"/>
<mapAttribute key="Inout Models Output Locations"/>
<mapAttribute key="Input Model Options"/>
<mapAttribute key="Input Models">
<mapEntry key="IN" value="platform:/resource/TestPorts2Pins/PortsBlockDiagram.xmi"/>
</mapAttribute>
<mapAttribute key="Metamodel Options"/>
<mapAttribute key="Metamodels">
<mapEntry key="Pins" value="platform:/resource/TestPorts2Pins/Pins.ecore"/>
<mapEntry key="Ports" value="platform:/resource/TestPorts2Pins/Ports.ecore"/>
</mapAttribute>
<stringAttribute key="Module Name" value="PortsToPins"/>
<stringAttribute key="Module Path" value="/TestPorts2Pins/"/>
<mapAttribute key="Output Model Options">
<mapEntry key="OUT" value="allowIntermodelReferences derivedFile"/>
</mapAttribute>
<mapAttribute key="Output Models">
<mapEntry key="OUT" value="platform:/resource/TestPorts2Pins/PinsOutput.xmi"/>
</mapAttribute>
<listAttribute key="Superimpose"/>
</launchConfiguration>
However, when I run the transformation, it generate the output file PinsOutput.xmi, but it only contains the XML header:
<?xml version="1.0" encoding="ASCII"?>
<xmi:XMI xmi:version="2.0" xmlns:xmi="h ttp://www.omg.org/XMI"/>
(the space in http is due to I can't post urls if I have less than 5 posts)
I take the same output for all transformations runned by EMFTVM
I have the last distribution of ATL (3.4.0).
Any suggestions?
Thank you in advance!
Antonio
[Updated on: Sat, 26 January 2013 09:29] Report message to a moderator
Re: EMFTVM doesn't generate output [message #1005572 is a reply to message #1005537] |
Sat, 26 January 2013 18:08 |
Op 26/01/13 10:26, Antonio M. Moreno schreef:
> Hello,
> module PortsToPins;
> <mapEntry key="IN"
> </mapAttribute>
> </mapAttribute>
> </mapAttribute>
> </mapAttribute>
> I take the same output for all transformations runned by EMFTVM :(
> Any suggestions? Thank you in advance!
> Antonio
The metamodels of that transformation use the eclipse workspace path as their
nsURI (see
http://git.eclipse.org/c/mmt/org.eclipse.atl.git/tree/tests/org.eclipse.m2m.atl.emftvm.tests/test-data/PortsToPins).
Hence, if you move the metamodels to /TestPorts2Pins/, they no longer work.
This is because the .xmi models have a reference to the nsURI of the
metamodels. This is default EMF behaviour.
If you want to move the metamodels, you need to update the metamodel EPackage
nsURIs, as well as the nsURI references in the .xmi files.
Alternatively, put everything in the same project/folder as it originally was
(/org.eclipse.m2m.atl.emftvm.tests/test-data/PortsToPins/).
A third option is to register the nsURI of the metamodels in the global EMF
registry using the ATL tooling:
1. Switch to the ATL perspective.
2. Right-click Pins.ecore and select "Register Metamodel"
3. Right-click Ports.ecore and select "Register Metamodel"
4. Refer to PORTS and PINS using the registered nsURI (EMF registry...) in the
ATL EMFTVM launch dialog.
Dennis
Dennis
FUDForum. Page generated in 0.02724 seconds
