Home » Modeling » UML2 » Set Enumeration Type in Property of Stereotype
Set Enumeration Type in Property of Stereotype [message #1005433] Fri, 25 January 2013 12:32 Go to next message
edipo federle is currently offline edipo federleFriend
Hello, I am trying via Java, set a property of a stereotype with an Enumeration. For Example:
First I create the enumeration and enumeration literals
private static void createBindingTimeEnumeration (Profile prof) {
try {
Enumeration bindingTime Helper.createEnumeration = (prof, "BidingTime");
Helper.createEnumerationLiteral (bindingTime, "DESIGN_TIME");
Helper.createEnumerationLiteral (bindingTime, "LINK_TIME");
Helper.createEnumerationLiteral (bindingTime, "COMPILE_TIME");
Helper.createEnumerationLiteral (bindingTime, "RUN_TIME");
} catch (Exception e) {
System.out.println (e.getMessage ());
Then I create the stereotype, and I would do something like this:
  Helper.createAttribute (myStereotype, "bindingTime" bidingTime, 1, 1);
Where is the 'bidingTime' enumeration.
Can anyone help?
thank you
Re: Set Enumeration Type in Property of Stereotype [message #1005460 is a reply to message #1005433] Fri, 25 January 2013 14:23 Go to previous messageGo to next message
Christian W. Damus is currently offline Christian W. DamusFriend
What is "Helper" ? I assume that's some class you devised that wraps
the UMLFactory?
What is the problem? The bindingTime variable is a reference to the
Enumeration, which is a kind of Type. Just set it as the type of the
attribute. I assume that the Helper.createAttribute(...) method does
this already.
HTH,
Christian
> try {
> Can anyone help?
> thank you
Re: Set Enumeration Type in Property of Stereotype [message #1005464 is a reply to message #1005460] Fri, 25 January 2013 14:38 Go to previous message
Actually I was with a problem with my method that return the enum by name. A cast problem;
Then, now everthing work: The code is:
Enumeration bindingTime = (Enumeration) getEnumerationByName(prof, "BidingTime");
 Helper.createAttribute(variantPoint, "bindingTime", bindingTime  , 1, 1);
	private static PackageableElement getEnumerationByName(Profile prof, String name) {
		EList<PackageableElement> a = prof.getPackagedElements();
		for (PackageableElement packageableElement : a) {
			if(packageableElement instanceof Enumeration && packageableElement.getName().equals(name))
				return packageableElement;
		return null; // TODO retaforar Exp
Thanks.
Sorry for the confusion
[]s
[Updated on: Fri, 25 January 2013 14:39]
Report message to a moderator
Previous Topic:linking lifeline to its corresponding class
Next Topic:How to get a metaclass for Stereotype.createExtension()
Current Time: Fri Apr 10 00:13:42 GMT 2020
Powered by FUDForum. Page generated in 0.01711 seconds
