Home » Eclipse Projects » EGit / JGit » JGit TagCommand(Having trouble making a tag via JGit)
JGit TagCommand [message #1004827] Thu, 24 January 2013 00:06 Go to next message
Gurce Isikyildiz is currently offline Gurce IsikyildizFriend
I'm using JGit to build a tailored GUI app. I'm currently experiencing problems with the TagCommand, I use it as follows:
- In my GUI, I have a list of past commits, generated via calling git.log().all().call() which returns a List<RevCommit> collection.
I want to allow the user to tag any one of these prior commits by right-clicking it and entering a tag name.
Once provided a name, I then execute the following JGit code to try apply the requested tag.
            Git git = new Git(gitrepo);
            org.eclipse.jgit.api.TagCommand tagcmd = git.tag();
            tagcmd. setObjectId(revcmt);
            tagcmd.setName(strTag);
            System.out.println("revid = " + tagcmd.getObjectId().getId().toString());
            try
                Ref ref = tagcmd.call();
                System.out.println("refid = " + ref.getObjectId().toString());
            } catch (Exception ex)
                parent.setErrMsg(ex);
                return;
The only problem here is that when I refresh my list of commits (via git.log().all().call() again), I get the following exception:
SEVERE: null
org.eclipse.jgit.errors.IncorrectObjectTypeException: Object b7607418fae91345b3941532ad3ce2e94907a9d8 is not a commit.
        at org.eclipse.jgit.storage.file.WindowCursor.open(WindowCursor.java:130)
        at org.eclipse.jgit.revwalk.RevWalk.getCachedBytes(RevWalk.java:861)
        at org.eclipse.jgit.revwalk.RevCommit.parseHeaders(RevCommit.java:142)
        at org.eclipse.jgit.revwalk.RevWalk.markStart(RevWalk.java:284)
        at org.eclipse.jgit.api.LogCommand.add(LogCommand.java:297)
        at org.eclipse.jgit.api.LogCommand.add(LogCommand.java:172)
        at org.eclipse.jgit.api.LogCommand.all(LogCommand.java:245)
I think the object it is complaining about is the newly created tag, which I called "test1" in this example.
My two debug println's in the above code show the following:
revid = commit a7c533ff99c2b34b42991bccf6b901f4b6b8875a 1357769853 ----sp
refid = AnyObjectId[b7607418fae91345b3941532ad3ce2e94907a9d8]
Ie, "refid" is the id of tag, which equates to the id the exception is complaining about.
I found the tag object within the ".git/" sub-folder of the project in the following location:
.git/refs/tags/test1
Its contents is: b7607418fae91345b3941532ad3ce2e94907a9d8
Hmm, but now, I try something from the command-line as a test:
git tag -d test1 (to remove the tag)
git tag test1 a7c533ff99c2b34b42991bccf6b901f4b6b8875a (ie, make a tag called "test1" on the rev-id I intended it for)
This time, when I edit ".git/refs/tags/test1", it contains: a7c533ff99c2b34b42991bccf6b901f4b6b8875a
Ie:
  • When I add a tag via JGit, this ".git/refs/tags/test1" file contains the Id of the tag itself
  • When I add a tag via command-line git, this ".git/refs/tags/test1" file contains the Id of the commit that the tag is associated with
Anyone know what's going on here? Is it a bug? Or am I making use of JGit in the wrong way?
Re: JGit TagCommand [message #1005336 is a reply to message #1004827] Thu, 24 January 2013 22:24 Go to previous messageGo to next message
Robin Rosenberg is currently offline Robin RosenbergFriend
Gurce Isikyildiz skrev 2013-01-24 01.06:
Git creates unannotated tags by default (no tag object), while JGit creates annotated tags (not convinced it should...).
-- robin
Re: JGit TagCommand [message #1005513 is a reply to message #1005336] Fri, 25 January 2013 19:44 Go to previous messageGo to next message
R Shapiro is currently offline R ShapiroFriend
Slightly off-topic -- does JGit support the creation of simple tags? If so, does EGit provide a hook to that support? I haven't found it in EGit,
Re: JGit TagCommand [message #1005521 is a reply to message #1005513] Fri, 25 January 2013 21:37 Go to previous messageGo to next message
R Shapiro skrev 2013-01-25 20.44:
No, but I think it should.
-- robin
Re: JGit TagCommand [message #1005539 is a reply to message #1004827] Sat, 26 January 2013 11:23 Go to previous messageGo to next message
Thanks for the explanation Robin. I'm trying to take this on-board, and gathering that the "log().all().call()" isn't working due to these annotated tags.
I tried to avoid the exception above by making the log command only add all "refs/heads" and "refs/remotes" (skipping "refs/tags") with code something like this:
            try
                org.eclipse.jgit.api.LogCommand logcmd = git.log();
                Map<String, Ref> mapRefs =repo.getRefDatabase().getRefs("refs/heads");
                mapRefs.putAll(repo.getRefDatabase().getRefs("refs/remotes"));
                Set<String> names = mapRefs.keySet();
                Iterator<String> it = names.iterator();
                while (it.hasNext())
                    String name = it.next();
                    Ref ref = mapRefs.get(name);
                    logcmd.add(ref.getObjectId());
                Iterable<RevCommit> iter_gitlog = logcmd.call();
No more exception, nice... But now I'd like to display the tags I find with ListTagCommand within my tree.
            ListTagCommand taglistcmd = git.tagList();
            lstTags = taglistcmd.call();
            for (Ref tag : lstTags)
                mapObjIdToRefTag.put(tag.getTarget().getObjectId(), tag);
As I iterate through my RevCommits, I try and match them against each tag's tag.getTarget().getObjectId(). This technique seems to work for un-annotated tags, but not for these JGit annotated tags (for me).
I did notice there was a mention of tag.getPeeledObjectId() returning the RevCommit that an annotated tag points to, but when I try that on this "test1" tag in my example, it is returning null (tag.isPeeled() is false too).
What's up here? Am I going about this the wrong way?
Re: JGit TagCommand [message #1005592 is a reply to message #1005539] Sat, 26 January 2013 21:48 Go to previous messageGo to next message
Gurce Isikyildiz skrev 2013-01-26 12.23:>
Determining the target is costly, so it's not done by default.
Use the code below peel the tag. After that you can get the peeled object.
ref = repository.peel(ref)
-- robin
Re: JGit TagCommand [message #1005595 is a reply to message #1005592] Sun, 27 January 2013 01:07 Go to previous message
Ah great, with that tip, it's now working for me, thanks Robin.
Previous Topic:crash during install of EGit plugin in Eclipse Indigo
Next Topic:quick diff with index as baseline?
Current Time: Tue Jan 19 15:09:37 GMT 2021
Powered by FUDForum. Page generated in 0.02432 seconds
