Home » Eclipse Projects » Mylyn » Eclipse freezes on startup
Eclipse freezes on startup [message #1004795] Wed, 23 January 2013 21:58 Go to next message
Nigel Daniels is currently offline Nigel DanielsFriend
Member
I'm using the Juno SR-1 Eclipse Modeling Tools. Whenever I start Eclipse
and load a workspace Eclipse freezes on the splash screen with the line
'loading workspace'. The only way I can get it to start is to go into
the workspaces .metadata folder and delete the .mylyn folder.
To the best of my knowledge I am not explicitly using Mylyn for
anything. Any thoughts on where I can look to fix this or what I need to
do to fix this are welcome!
Thanks, Nigel
Re: Eclipse freezes on startup [message #1034545 is a reply to message #1004795] Fri, 05 April 2013 15:13 Go to previous message
Steffen Pingel is currently offline Steffen PingelFriend
please capture a stack dump when the freeze occurs:
http://wiki.eclipse.org/Mylyn/Contributor_Reference#Debugging . Then file a
bug and attach the stack dump and we will analyze the problem further.
You can also try to close the Mylyn Task List and disable all Mylyn
extensions under General > Startup to prevent Mylyn bundles from loading.
Hope that helps.
Steffen
Nigel Daniels wrote:
> Thanks, Nigel
Steffen Pingel
Principal Software Engineer, Eclipse Mylyn Tasks Lead
http://tasktop.com
Previous Topic:How to get a repository for Mylyn???
Next Topic:context copy to link ghosted
Current Time: Tue Apr 16 13:48:59 GMT 2024
Powered by FUDForum. Page generated in 0.46977 seconds
