Re: Custom ESB application type [message #1004496 is a reply to message #1004247] |
Wed, 23 January 2013 10:57   |
Hi Gudrun,
this is possible and has been done in a number of projects. However, the API for the custom application type is not part of the official product API and therefore there is very little documentation on this topic. Also note that there is no guaranty that internal API will be kept stable accross releases and adjustments may be required.
As time permits we will add this topic to the knowledgebase wiki.
I would pick the application type that is closest to what you plan to implementen and start from its source code.
For the Camel application the important classes would be:
org.eclipse.stardust.engine.extensions.camel.app.CamelProducerSpringBeanApplicationInstance
org.eclipse.stardust.engine.extensions.camel.app.CamelProducerSpringBeanAccessPointProvider
org.eclipse.stardust.engine.extensions.camel.app.CamelProducerSpringBeanValidator
org.eclipse.stardust.model.xpdl.builder.variable.CamelApplicationBuilder
Hope this helps. Let me know if you have questions regarding this code.
Best regards
Robert
FUDForum. Page generated in 0.02566 seconds
