Home » Archived » Visual Editor (VE) » VE for eclipse 3.5/galileo is being worked on - part of eclipse project again?
VE for eclipse 3.5/galileo is being worked on - part of eclipse project again? [message #146031] Wed, 24 June 2009 10:07 Go to next message
Originally posted by: sbrandt_NOSPAM_.gmx.de
Hi, everybody!
Surprisingly, this information has not yet been posted to the group here:
http://wiki.eclipse.org/VE/Update
*Install VE 1.4 into Eclipse 3.5 / Galileo*
Help > Install New Software...
In the "Work with:" field, paste
http://download.eclipse.org/tools/ve/updates/1.4,
and hit enter
When the site loads, select the feature(s) you want to install, then hit
Next
And so on - graphical explanation also for installing it on ganymede.
So, obviously, VE is part of the eclipse project again!
Thanks, to whoever this is doing!
Yours,
Sebastian
Re: VE for eclipse 3.5/galileo is being worked on - part of eclipse project again? [message #146039 is a reply to message #146031] Thu, 25 June 2009 04:24 Go to previous messageGo to next message
Originally posted by: formatzeh.gmx.de
....no repository found?
Is the update-server down?
Re: VE for eclipse 3.5/galileo is being worked on - part of eclipse project again? [message #146046 is a reply to message #146039] Thu, 25 June 2009 18:34 Go to previous messageGo to next message
I was happy to see there is support for the new eclipse.
Unfortunately the VE seems to depend on a special version of the EMF which
can't be installed together with the included one. That means that also
the VE cannot be installed :(
Does anybody have a solution for this issue?
Re: VE for eclipse 3.5/galileo is being worked on - part of eclipse project agai [message #146130 is a reply to message #146046] Mon, 06 July 2009 11:39 Go to previous message
Is the VE dependent specifically on EMF 2.4, rather than works with EMF
2.5?
I've been attempting to get VE installed and operational in Eclipse 3.5,
with
EMF 2.5 and the latest version of GEF, etc, but while VE installs, I don't
see
anything in the UI that would hint that there is an VE 'project' or
anything
like that. It's as if it wasn't there at all.
--oh
Re: VE for eclipse 3.5/galileo is being worked on - part of eclipse project again? [message #617364 is a reply to message #146031] Thu, 25 June 2009 04:24 Go to previous message
Re: VE for eclipse 3.5/galileo is being worked on - part of eclipse project again? [message #617365 is a reply to message #146039] Thu, 25 June 2009 18:34 Go to previous message
Re: VE for eclipse 3.5/galileo is being worked on - part of eclipse project agai [message #617374 is a reply to message #146046] Mon, 06 July 2009 11:39 Go to previous message
2.5?
with
see
anything
--oh
Previous Topic:Intallation Problem when updated to latest Eclipse
Next Topic:VE Doesn't Install Into Galileo Packages
Current Time: Fri Jun 20 22:22:10 EDT 2025
Powered by FUDForum. Page generated in 0.04858 seconds
