Home » Modeling » TMF (Xtext) » JvmTypesBuilder generate final parameters
JvmTypesBuilder generate final parameters [message #1002252] Fri, 18 January 2013 08:52 Go to next message
Davide Poletti is currently offline Davide PolettiFriend
Im'm tring to generate, using the Xtend Xbase API, a simple Java mathod.
This is the Xtend code.
var jvmMethod = element.toMethod("fromSap",element.newTypeRef(element.dtoFullName))[
						var jvmTypeReference= fromSap.sapType;
						var param = toParameter("sapOb",jvmTypeReference)
						parameters+=param
						body = ['''....''')]
everything works fine except the parameter that has the final modifier.
This is the generated code:
public class DTOTest {
  public DTOTest fromSap(final String sapOb) {
    DTOTest result = new DTOTest();
    return result;
I tried to add:
	param.setFinal(false);
but I got
This expression is not allowed in this context, since it doesn't cause any side effects.
at compile time
Can someone help me to remove the final modifier from the generated code?
Davide
[Updated on: Fri, 18 January 2013 08:59]
Report message to a moderator
Re: JvmTypesBuilder generate final parameters [message #1002304 is a reply to message #1002252] Fri, 18 January 2013 11:04 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Hi Davide,
parameters are considered to be final in the linking / scoping of the
expression that are contained in your method. If they weren't final,
none of the could be used from within lambda expressions. Unfortunately
there is no means of 'final' in the reflective API (java.lang.reflect)
for parameters. Therefore no property 'isFinal' can be exposed. Why do
you want to generate non-final parameters in the first place?
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Am 18.01.13 09:52, schrieb Davide Poletti:
> var jvmMethod =
> parameters+=param
> return result;
> I tried to add:
> but I got
> any side effects.
> at compile time
> Davide
Re: JvmTypesBuilder generate final parameters [message #1002326 is a reply to message #1002304] Fri, 18 January 2013 12:06 Go to previous message
Actually there is no problem and I even find out that declaring parameters as final is even a good practice .
It looked only strange to me that there was no possibility to change this behaviour.
Davide
Previous Topic:How to trigger the serializer on existing EMF model?
Next Topic:Setting linking diagnostics to ignore?
Current Time: Sun Mar 29 15:34:29 GMT 2020
Powered by FUDForum. Page generated in 0.01773 seconds
