Mapping eType of reference to eType of attribute [message #1001891] |
Thu, 17 January 2013 14:15 |
I define an ecore model with Java interfaces:
import java.net.InetAddress;
* @model
public interface net {
* @model dataType="java.net.InetAddress"
InetAddress getAddress();
and
import java.util.List;
* @model
public interface nic {
* @model containment="true" required="false" type="java.net.InetAddress"
List<InetAddress> getAddresses();
Now, I would expect that ecore uses the same eType for the attribute net.address and the reference nic.addresses. However, it uses two different eTypes: InetAddress for the attribute and InetAddress_1 for the reference.
How can I enforce that the same eType is used? And why is that happening anyways?
I'm using Eclispe Juno.
Martin
[Updated on: Thu, 24 January 2013 11:56] Report message to a moderator
Re: Mapping eType of reference to eType of attribute [message #1002083 is a reply to message #1001891] |
Thu, 17 January 2013 22:32 |
Hallvard Traetteberg Messages: 673 Registered: July 2009 Location: Trondheim, Norway |
The eType of an attribute must be a DataType, while the eType of a
Reference must be an EClass, hence it generates and uses another type
for the reference.
Hallvard
On 17.01.13 07.57, Martin C. wrote:
> and
> the reference.
> anyways?
> Martin
Re: Mapping eType of reference to eType of attribute [message #1005064 is a reply to message #1002237] |
Thu, 24 January 2013 12:07 |
Let's use a list:
- Thanks Hallvard, that explained what happens.
- Also thanks Ed for the pointer to Xcore. However, I'm not quite sure if I want to use Xcore. It looks already so similar to Java that I could also model with Java classes themselves.
- Is there a way to specify the name of the EClass/eType? So I could get rid of the annoying "_1" name.
- BTW: I pasted the annotations to the wrong statements in my code examples, because I simplified the code to what the problem is. But it's fixed now.
Re: Mapping eType of reference to eType of attribute [message #1005084 is a reply to message #1005064] |
Thu, 24 January 2013 13:02 |
Ed Merks Messages: 33137 Registered: July 2009 |
Martin,
Comments below.
On 24/01/2013 1:07 PM, Martin C. wrote:
> Let's use a list:
Yes, but as I said, there is little in the way of feedback on what's
wrong with your @model annotations. In your example, not a single one
of the attributes you've specified was sensible in that location.
Have a look at the generated XyzPackage implementation's @model
annotations to see what data types you've ended up with. Once they're
their and they're marked @model, you have to delete them to get rid of them.
> it's fixed now.
What does it look like now?
Ed Merks
FUDForum. Page generated in 0.02742 seconds
