Gemini JPA and Spring [message #1001421] |
Wed, 16 January 2013 17:03  |
Simon Watson Messages: 30 Registered: September 2011 |
Member |
I'm migrating an application which uses Spring DM & Virgo 3.05 to Gemini Blueprint & Virgo 3.6. I have it working but I would like to use Gemini DBAccess (with MySQL) and Gemini JPA.
Currently, my DB access is achieved with 3 of my OSGi bundles:
1. Datasource, providing a javax.sql.DataSource service (also uses a properties file to store DB connection params).
2. Domain model, which defines a persistence unit.
3. DAO, which consumes the datasource service and injects an EntityManager into various @Repository POJOs.
I've looked through all the Gemini JPA docs but I'm unclear how I should modify my bundle-context.xml. Previously I had this:
<bean id="entityManagerFactory" class="org.springframework.orm.jpa.LocalContainerEntityManagerFactoryBean" p:dataSource-ref="dataSource">
<property name="jpaVendorAdapter">
<bean id="jpaVendorAdapter" class="org.springframework.orm.jpa.vendor.EclipseLinkJpaVendorAdapter"
p:databasePlatform="org.eclipse.persistence.platform.database.MySQLPlatform"
p:showSql="true"/>
</property>
</bean>
<osgi:reference id="dataSource" interface="javax.sql.DataSource"/>
How can I use the Gemini JPA EntityManagerFactory service to inject an EntityManager into my Spring POJOs, e.g.:
@PersistenceContext
private EntityManager em;
I've tried the following:
<osgi:reference id="entityManagerFactory"
interface="javax.persistence.EntityManagerFactory"
filter="(osgi.unit.name=MyPU)"
but I'm unsure whether this should work, and where best to configure the DB connection params. I'd rather reference these from my DAO bundle than the persistence unit if possible.
Any pointers, ideas, suggestions gratefully received.
Simon.
Re: Gemini JPA and Spring [message #1001906 is a reply to message #1001421] |
Thu, 17 January 2013 14:40   |
Member |
Thanks for your reply, that makes sense. Are you using Gemini DBAccess/JPA? Also, what app server do you use?
So far, on Virgo 3.6 I'm seeing a strange problem when I deploy a simple Virgo plan with the required Gemini bundles and a test bundle with a persistence unit. Virgo goes into a loop, starting and stopping my plan hundreds of times:
[2013-01-17 14:33:48.481] startup-tracker <KE0001I> Kernel starting.
[2013-01-17 14:33:50.207] startup-tracker <KE0002I> Kernel started.
[2013-01-17 14:33:50.402] system-artifacts <DE0000I> Installing plan 'org.eclipse.virgo.kernel.userregion.blueprint' version '3.6.0'.
[2013-01-17 14:33:50.524] system-artifacts <DE0000I> Installing bundle 'org.eclipse.gemini.blueprint.core' version '1.0.2.RELEASE'.
[2013-01-17 14:33:50.555] system-artifacts <DE0000I> Installing bundle 'org.eclipse.gemini.blueprint.extender' version '1.0.2.RELEASE'.
[2013-01-17 14:33:50.570] system-artifacts <DE0000I> Installing bundle 'org.eclipse.gemini.blueprint.io' version '1.0.2.RELEASE'.
[2013-01-17 14:33:50.589] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.kernel.agent.dm' version '3.6.0.RELEASE'.
[2013-01-17 14:33:50.595] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.kernel.deployer.dm' version '3.6.0.RELEASE'.
[2013-01-17 14:33:50.616] system-artifacts <DE0000I> Installing bundle 'org.eclipse.equinox.ds' version '1.4.0.v20120112-1400'.
[2013-01-17 14:33:50.637] system-artifacts <DE0000I> Installing bundle 'org.eclipse.equinox.util' version '1.0.300.v20111010-1614'.
[2013-01-17 14:33:50.640] system-artifacts <DE0000I> Installing configuration 'osgi.console' version '0.0.0'.
[2013-01-17 14:33:51.764] system-artifacts <DE0001I> Installed bundle 'org.eclipse.gemini.blueprint.core' version '1.0.2.RELEASE'.
[2013-01-17 14:33:51.766] system-artifacts <DE0001I> Installed bundle 'org.eclipse.gemini.blueprint.extender' version '1.0.2.RELEASE'.
[2013-01-17 14:33:51.767] system-artifacts <DE0001I> Installed bundle 'org.eclipse.gemini.blueprint.io' version '1.0.2.RELEASE'.
[2013-01-17 14:33:51.767] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.kernel.agent.dm' version '3.6.0.RELEASE'.
[2013-01-17 14:33:51.768] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.kernel.deployer.dm' version '3.6.0.RELEASE'.
[2013-01-17 14:33:51.769] system-artifacts <DE0001I> Installed bundle 'org.eclipse.equinox.ds' version '1.4.0.v20120112-1400'.
[2013-01-17 14:33:51.771] system-artifacts <DE0001I> Installed bundle 'org.eclipse.equinox.util' version '1.0.300.v20111010-1614'.
[2013-01-17 14:33:51.771] system-artifacts <DE0001I> Installed configuration 'osgi.console' version '0.0.0'.
[2013-01-17 14:33:51.772] system-artifacts <DE0001I> Installed plan 'org.eclipse.virgo.kernel.userregion.blueprint' version '3.6.0'.
[2013-01-17 14:33:51.798] system-artifacts <DE0004I> Starting plan 'org.eclipse.virgo.kernel.userregion.blueprint' version '3.6.0'.
[2013-01-17 14:33:51.804] system-artifacts <DE0004I> Starting bundle 'org.eclipse.gemini.blueprint.core' version '1.0.2.RELEASE'.
[2013-01-17 14:33:51.808] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.gemini.blueprint.core' version '1.0.2.RELEASE'.
[2013-01-17 14:33:51.809] system-artifacts <DE0004I> Starting bundle 'org.eclipse.gemini.blueprint.extender' version '1.0.2.RELEASE'.
[2013-01-17 14:33:52.459] system-artifacts <DE0004I> Starting bundle 'org.eclipse.gemini.blueprint.io' version '1.0.2.RELEASE'.
[2013-01-17 14:33:52.464] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.kernel.agent.dm' version '3.6.0.RELEASE'.
[2013-01-17 14:33:52.470] start-signalling-2 <DE0005I> Started bundle 'org.eclipse.gemini.blueprint.io' version '1.0.2.RELEASE'.
[2013-01-17 14:33:52.472] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.kernel.deployer.dm' version '3.6.0.RELEASE'.
[2013-01-17 14:33:52.474] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.gemini.blueprint.extender' version '1.0.2.RELEASE'.
[2013-01-17 14:33:52.477] start-signalling-3 <DE0005I> Started bundle 'org.eclipse.virgo.kernel.agent.dm' version '3.6.0.RELEASE'.
[2013-01-17 14:33:52.480] system-artifacts <DE0004I> Starting bundle 'org.eclipse.equinox.ds' version '1.4.0.v20120112-1400'.
[2013-01-17 14:33:52.626] start-signalling-3 <DE0005I> Started bundle 'org.eclipse.equinox.ds' version '1.4.0.v20120112-1400'.
[2013-01-17 14:33:52.635] system-artifacts <DE0004I> Starting bundle 'org.eclipse.equinox.util' version '1.0.300.v20111010-1614'.
[2013-01-17 14:33:52.682] system-artifacts <DE0004I> Starting configuration 'osgi.console' version '0.0.0'.
[2013-01-17 14:33:52.693] start-signalling-3 <DE0005I> Started bundle 'org.eclipse.equinox.util' version '1.0.300.v20111010-1614'.
[2013-01-17 14:33:52.700] system-artifacts <DE0005I> Started configuration 'osgi.console' version '0.0.0'.
[2013-01-17 14:33:52.735] start-signalling-3 <DE0005I> Started bundle 'org.eclipse.virgo.kernel.deployer.dm' version '3.6.0.RELEASE'.
[2013-01-17 14:33:52.737] start-signalling-3 <DE0005I> Started plan 'org.eclipse.virgo.kernel.userregion.blueprint' version '3.6.0'.
[2013-01-17 14:33:52.884] system-artifacts <DE0000I> Installing plan 'org.eclipse.virgo.web.tomcat' version '3.6.0'.
[2013-01-17 14:33:52.886] system-artifacts <DE0000I> Installing configuration 'org.eclipse.virgo.web' version '0.0.0'.
[2013-01-17 14:33:52.893] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.web.spring.integration' version '3.6.0.RELEASE'.
[2013-01-17 14:33:52.922] system-artifacts <DE0000I> Installing bundle 'org.eclipse.gemini.web.core' version '2.2.0.RELEASE'.
[2013-01-17 14:33:52.963] system-artifacts <DE0000I> Installing bundle 'org.eclipse.gemini.web.tomcat' version '2.2.0.RELEASE'.
[2013-01-17 14:33:52.974] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.web.core' version '3.6.0.RELEASE'.
[2013-01-17 14:33:52.979] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.web.dm' version '3.6.0.RELEASE'.
[2013-01-17 14:33:52.987] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.web.tomcat.support' version '3.6.0.RELEASE'.
[2013-01-17 14:33:52.991] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.web.servlet.adapter' version '3.6.0.RELEASE'.
[2013-01-17 14:33:53.585] system-artifacts <DE0001I> Installed configuration 'org.eclipse.virgo.web' version '0.0.0'.
[2013-01-17 14:33:53.586] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.web.spring.integration' version '3.6.0.RELEASE'.
[2013-01-17 14:33:53.587] system-artifacts <DE0001I> Installed bundle 'org.eclipse.gemini.web.core' version '2.2.0.RELEASE'.
[2013-01-17 14:33:53.588] system-artifacts <DE0001I> Installed bundle 'org.eclipse.gemini.web.tomcat' version '2.2.0.RELEASE'.
[2013-01-17 14:33:53.589] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.web.core' version '3.6.0.RELEASE'.
[2013-01-17 14:33:53.590] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.web.dm' version '3.6.0.RELEASE'.
[2013-01-17 14:33:53.591] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.web.tomcat.support' version '3.6.0.RELEASE'.
[2013-01-17 14:33:53.592] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.web.servlet.adapter' version '3.6.0.RELEASE'.
[2013-01-17 14:33:53.593] system-artifacts <DE0001I> Installed plan 'org.eclipse.virgo.web.tomcat' version '3.6.0'.
[2013-01-17 14:33:53.606] system-artifacts <DE0004I> Starting plan 'org.eclipse.virgo.web.tomcat' version '3.6.0'.
[2013-01-17 14:33:53.606] system-artifacts <DE0004I> Starting configuration 'org.eclipse.virgo.web' version '0.0.0'.
[2013-01-17 14:33:53.609] system-artifacts <DE0005I> Started configuration 'org.eclipse.virgo.web' version '0.0.0'.
[2013-01-17 14:33:53.611] system-artifacts <DE0005I> Started bundle 'org.eclipse.virgo.web.spring.integration' version '3.6.0.RELEASE'.
[2013-01-17 14:33:53.613] system-artifacts <DE0004I> Starting bundle 'org.eclipse.gemini.web.core' version '2.2.0.RELEASE'.
[2013-01-17 14:33:53.627] start-signalling-3 <DE0005I> Started bundle 'org.eclipse.gemini.web.core' version '2.2.0.RELEASE'.
[2013-01-17 14:33:53.628] system-artifacts <DE0004I> Starting bundle 'org.eclipse.gemini.web.tomcat' version '2.2.0.RELEASE'.
[2013-01-17 14:33:54.444] system-artifacts <TC0000I> Starting Tomcat.
[2013-01-17 14:33:54.490] system-artifacts <TC0010I> Creating HTTP/1.1 connector with scheme http on port 8080.
[2013-01-17 14:33:54.508] system-artifacts <TC0010I> Creating HTTP/1.1 connector with scheme https on port 8443.
[2013-01-17 14:33:54.516] system-artifacts <TC0010I> Creating AJP/1.3 connector with scheme http on port 8009.
[2013-01-17 14:33:54.519] system-artifacts <TC0001I> Started Tomcat.
[2013-01-17 14:33:54.544] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.web.core' version '3.6.0.RELEASE'.
[2013-01-17 14:33:54.566] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.web.dm' version '3.6.0.RELEASE'.
[2013-01-17 14:33:54.572] system-artifacts <DE0005I> Started bundle 'org.eclipse.virgo.web.tomcat.support' version '3.6.0.RELEASE'.
[2013-01-17 14:33:54.574] system-artifacts <DE0004I> Starting bundle 'org.eclipse.virgo.web.servlet.adapter' version '3.6.0.RELEASE'.
[2013-01-17 14:33:54.577] start-signalling-3 <DE0005I> Started bundle 'org.eclipse.virgo.web.dm' version '3.6.0.RELEASE'.
[2013-01-17 14:33:54.578] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.web.servlet.adapter' version '3.6.0.RELEASE'.
[2013-01-17 14:33:54.696] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.gemini.web.tomcat' version '2.2.0.RELEASE'.
[2013-01-17 14:33:54.718] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.virgo.web.core' version '3.6.0.RELEASE'.
[2013-01-17 14:33:54.720] start-signalling-1 <DE0005I> Started plan 'org.eclipse.virgo.web.tomcat' version '3.6.0'.
[2013-01-17 14:33:54.788] system-artifacts <DE0000I> Installing configuration 'org.eclipse.virgo.apps.repository' version '0.0.0'.
[2013-01-17 14:33:54.802] system-artifacts <DE0001I> Installed configuration 'org.eclipse.virgo.apps.repository' version '0.0.0'.
[2013-01-17 14:33:54.806] system-artifacts <DE0004I> Starting configuration 'org.eclipse.virgo.apps.repository' version '0.0.0'.
[2013-01-17 14:33:54.810] system-artifacts <DE0005I> Started configuration 'org.eclipse.virgo.apps.repository' version '0.0.0'.
[2013-01-17 14:33:54.889] system-artifacts <DE0000I> Installing plan 'org.eclipse.virgo.management' version '3.6.0'.
[2013-01-17 14:33:54.958] system-artifacts <DE0000I> Installing bundle 'osgi.enterprise' version '4.2.0.v201108120515'.
[2013-01-17 14:33:54.981] system-artifacts <DE0000I> Installing bundle 'org.eclipse.gemini.management' version '1.0.5.RELEASE'.
[2013-01-17 14:33:54.988] system-artifacts <DE0000I> Installing bundle 'org.eclipse.virgo.management.fragment' version '3.6.0.RELEASE'.
[2013-01-17 14:33:55.079] system-artifacts <DE0001I> Installed bundle 'osgi.enterprise' version '4.2.0.v201108120515'.
[2013-01-17 14:33:55.081] system-artifacts <DE0001I> Installed bundle 'org.eclipse.gemini.management' version '1.0.5.RELEASE'.
[2013-01-17 14:33:55.083] system-artifacts <DE0001I> Installed bundle 'org.eclipse.virgo.management.fragment' version '3.6.0.RELEASE'.
[2013-01-17 14:33:55.085] system-artifacts <DE0001I> Installed plan 'org.eclipse.virgo.management' version '3.6.0'.
[2013-01-17 14:33:55.098] system-artifacts <DE0004I> Starting plan 'org.eclipse.virgo.management' version '3.6.0'.
[2013-01-17 14:33:55.101] system-artifacts <DE0004I> Starting bundle 'osgi.enterprise' version '4.2.0.v201108120515'.
[2013-01-17 14:33:55.103] start-signalling-1 <DE0005I> Started bundle 'osgi.enterprise' version '4.2.0.v201108120515'.
[2013-01-17 14:33:55.105] system-artifacts <DE0004I> Starting bundle 'org.eclipse.gemini.management' version '1.0.5.RELEASE'.
[2013-01-17 14:33:55.123] start-signalling-1 <DE0005I> Started bundle 'org.eclipse.gemini.management' version '1.0.5.RELEASE'.
[2013-01-17 14:33:55.126] system-artifacts <DE0005I> Started bundle 'org.eclipse.virgo.management.fragment' version '3.6.0.RELEASE'.
[2013-01-17 14:33:55.128] system-artifacts <DE0005I> Started plan 'org.eclipse.virgo.management' version '3.6.0'.
[2013-01-17 14:33:55.131] sync Event Dispatcher Thread <UR0001I> User region ready.
[2013-01-17 14:33:55.134] startup-readiness <KE0007I> Virgo ready. Started for 8.406s.
[2013-01-17 14:33:56.136] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'demo.plan'.
[2013-01-17 14:33:56.200] fs-watcher <DE0000I> Installing plan 'my-test.plan' version '1.0.0'.
[2013-01-17 14:33:56.278] fs-watcher <DE0000I> Installing bundle 'my-test.plan-1-com.springsource.com.mysql.jdbc' version '5.1.6'.
[2013-01-17 14:33:56.287] fs-watcher <DE0000I> Installing bundle 'my-test.plan-1-org.eclipse.gemini.dbaccess.mysql' version '1.1.0.RC1'.
[2013-01-17 14:33:56.313] fs-watcher <DE0000I> Installing bundle 'my-test.plan-1-org.eclipse.gemini.jpa' version '1.1.0.RELEASE'.
[2013-01-17 14:33:56.319] fs-watcher <DE0000I> Installing bundle 'my-test.plan-1-foo.test.pu' version '1.0.1'.
[2013-01-17 14:33:56.465] fs-watcher <DE0001I> Installed bundle 'my-test.plan-1-com.springsource.com.mysql.jdbc' version '5.1.6'.
[2013-01-17 14:33:56.466] fs-watcher <DE0001I> Installed bundle 'my-test.plan-1-org.eclipse.gemini.dbaccess.mysql' version '1.1.0.RC1'.
[2013-01-17 14:33:56.471] fs-watcher <DE0001I> Installed bundle 'my-test.plan-1-org.eclipse.gemini.jpa' version '1.1.0.RELEASE'.
[2013-01-17 14:33:56.476] fs-watcher <DE0001I> Installed bundle 'my-test.plan-1-foo.test.pu' version '1.0.1'.
[2013-01-17 14:33:56.478] fs-watcher <DE0001I> Installed bundle 'my-test.plan-1-synthetic.context' version '1.0.0'.
[2013-01-17 14:33:56.480] fs-watcher <DE0001I> Installed plan 'my-test.plan' version '1.0.0'.
[2013-01-17 14:33:56.498] fs-watcher <DE0004I> Starting plan 'my-test.plan' version '1.0.0'.
[2013-01-17 14:33:56.502] fs-watcher <DE0004I> Starting bundle 'my-test.plan-1-com.springsource.com.mysql.jdbc' version '5.1.6'.
[2013-01-17 14:33:56.505] start-signalling-1 <DE0005I> Started bundle 'my-test.plan-1-com.springsource.com.mysql.jdbc' version '5.1.6'.
[2013-01-17 14:33:56.510] fs-watcher <DE0004I> Starting bundle 'my-test.plan-1-org.eclipse.gemini.dbaccess.mysql' version '1.1.0.RC1'.
[2013-01-17 14:33:56.521] start-signalling-1 <DE0005I> Started bundle 'my-test.plan-1-org.eclipse.gemini.dbaccess.mysql' version '1.1.0.RC1'.
[2013-01-17 14:33:56.521] fs-watcher <DE0004I> Starting bundle 'my-test.plan-1-org.eclipse.gemini.jpa' version '1.1.0.RELEASE'.
[2013-01-17 14:33:56.565] start-signalling-1 <DE0005I> Started bundle 'my-test.plan-1-org.eclipse.gemini.jpa' version '1.1.0.RELEASE'.
[2013-01-17 14:33:56.577] fs-watcher <DE0004I> Starting bundle 'my-test.plan-1-foo.test.pu' version '1.0.1'.
[2013-01-17 14:33:56.587] Refresh Packages <DE0010I> Stopping bundle 'my-test.plan-1-foo.test.pu' version '1.0.1'.
[2013-01-17 14:33:56.589] start-signalling-1 <DE0005I> Started bundle 'my-test.plan-1-foo.test.pu' version '1.0.1'.
[2013-01-17 14:33:56.590] Refresh Packages <DE0010I> Stopping plan 'my-test.plan' version '1.0.0'.
[2013-01-17 14:33:56.593] Refresh Packages <DE0010I> Stopping bundle 'my-test.plan-1-com.springsource.com.mysql.jdbc' version '5.1.6'.
[2013-01-17 14:33:56.594] Refresh Packages <DE0011I> Stopped bundle 'my-test.plan-1-com.springsource.com.mysql.jdbc' version '5.1.6'.
[2013-01-17 14:33:56.597] Refresh Packages <DE0010I> Stopping bundle 'my-test.plan-1-org.eclipse.gemini.dbaccess.mysql' version '1.1.0.RC1'.
[2013-01-17 14:33:56.599] Refresh Packages <DE0011I> Stopped bundle 'my-test.plan-1-org.eclipse.gemini.dbaccess.mysql' version '1.1.0.RC1'.
[2013-01-17 14:33:56.602] Refresh Packages <DE0010I> Stopping bundle 'my-test.plan-1-org.eclipse.gemini.jpa' version '1.1.0.RELEASE'.
[2013-01-17 14:33:56.607] Refresh Packages <DE0011I> Stopped bundle 'my-test.plan-1-org.eclipse.gemini.jpa' version '1.1.0.RELEASE'.
[2013-01-17 14:33:56.609] Refresh Packages <DE0011I> Stopped plan 'my-test.plan' version '1.0.0'.
[2013-01-17 14:33:56.610] Refresh Packages <DE0011I> Stopped bundle 'my-test.plan-1-foo.test.pu' version '1.0.1'.
[2013-01-17 14:33:56.618] Refresh Packages <DE0004I> Starting bundle 'my-test.plan-1-foo.test.pu' version '1.0.1'.
[2013-01-17 14:33:56.623] start-signalling-1 <DE0005I> Started bundle 'my-test.plan-1-foo.test.pu' version '1.0.1'.
[2013-01-17 14:33:56.626] fs-watcher <DE0004I> Starting plan 'my-test.plan' version '1.0.0'.
[2013-01-17 14:33:56.629] fs-watcher <DE0004I> Starting bundle 'my-test.plan-1-com.springsource.com.mysql.jdbc' version '5.1.6'.
[2013-01-17 14:33:56.637] start-signalling-1 <DE0005I> Started bundle 'my-test.plan-1-com.springsource.com.mysql.jdbc' version '5.1.6'.
[2013-01-17 14:33:56.647] fs-watcher <DE0004I> Starting bundle 'my-test.plan-1-org.eclipse.gemini.dbaccess.mysql' version '1.1.0.RC1'.
[2013-01-17 14:33:56.650] start-signalling-1 <DE0005I> Started bundle 'my-test.plan-1-org.eclipse.gemini.dbaccess.mysql' version '1.1.0.RC1'.
[2013-01-17 14:33:56.653] fs-watcher <DE0004I> Starting bundle 'my-test.plan-1-org.eclipse.gemini.jpa' version '1.1.0.RELEASE'.
[2013-01-17 14:33:56.665] start-signalling-1 <DE0005I> Started bundle 'my-test.plan-1-org.eclipse.gemini.jpa' version '1.1.0.RELEASE'.
[2013-01-17 14:33:56.669] fs-watcher <DE0004I> Starting bundle 'my-test.plan-1-synthetic.context' version '1.0.0'.
[2013-01-17 14:33:56.672] Refresh Packages <DE0010I> Stopping bundle 'my-test.plan-1-synthetic.context' version '1.0.0'.
[2013-01-17 14:33:56.674] fs-watcher <HD0001I> Hot deployer processing 'INITIAL' event for file 'org.eclipse.virgo.apps.repository_3.6.0.RELEASE.par'.
[2013-01-17 14:33:56.674] start-signalling-3 <DE0005I> Started bundle 'my-test.plan-1-synthetic.context' version '1.0.0'.
[2013-01-17 14:33:56.677] start-signalling-1 <DE0005I> Started bundle 'my-test.plan-1-synthetic.context' version '1.0.0'.
[2013-01-17 14:33:56.677] Refresh Packages <DE0010I> Stopping plan 'my-test.plan' version '1.0.0'.
[2013-01-17 14:33:56.678] start-signalling-1 <DE0005I> Started plan 'my-test.plan' version '1.0.0'.
[2013-01-17 14:33:56.679] Refresh Packages <DE0010I> Stopping bundle 'my-test.plan-1-com.springsource.com.mysql.jdbc' version '5.1.6'.
[2013-01-17 14:33:56.681] Refresh Packages <DE0010I> Stopping plan 'my-test.plan' version '1.0.0'.
[2013-01-17 14:33:56.684] Refresh Packages <DE0010I> Stopping bundle 'my-test.plan-1-org.eclipse.gemini.dbaccess.mysql' version '1.1.0.RC1'.
[2013-01-17 14:33:56.694] Refresh Packages <DE0011I> Stopped bundle 'my-test.plan-1-org.eclipse.gemini.dbaccess.mysql' version '1.1.0.RC1'.
[2013-01-17 14:33:56.696] Refresh Packages <DE0010I> Stopping bundle 'my-test.plan-1-org.eclipse.gemini.jpa' version '1.1.0.RELEASE'.
[2013-01-17 14:33:56.700] Refresh Packages <DE0011I> Stopped bundle 'my-test.plan-1-org.eclipse.gemini.jpa' version '1.1.0.RELEASE'.
[2013-01-17 14:33:56.702] Refresh Packages <DE0010I> Stopping bundle 'my-test.plan-1-foo.test.pu' version '1.0.1'.
[2013-01-17 14:33:56.704] Refresh Packages <DE0011I> Stopped bundle 'my-test.plan-1-foo.test.pu' version '1.0.1'.
[2013-01-17 14:33:56.706] Refresh Packages <DE0011I> Stopped plan 'my-test.plan' version '1.0.0'.
[2013-01-17 14:33:56.707] Refresh Packages <DE0011I> Stopped bundle 'my-test.plan-1-com.springsource.com.mysql.jdbc' version '5.1.6'.
[2013-01-17 14:33:56.708] Refresh Packages <DE0011I> Stopped bundle 'my-test.plan-1-synthetic.context' version '1.0.0'.
My plan is:
<plan name="my-test.plan" version="1.0.0" scoped="true" atomic="true"
xmlns="http://www.eclipse.org/virgo/schema/plan"
xsi:schemaLocation="
http://www.eclipse.org/virgo/schema/plan/eclipse-virgo-plan.xsd">
<artifact type="bundle" name="com.springsource.com.mysql.jdbc" />
<artifact type="bundle" name="org.eclipse.gemini.dbaccess.mysql" />
<artifact type="bundle" name="org.eclipse.gemini.jpa" />
<artifact type="bundle" name="foo.test.pu" />
</plan>
My test PU bundle manifest:
Manifest-Version: 1.0
Bundle-Version: 1.0.1
Bundle-Name: PayLiquid Domain Model
Bundle-ManifestVersion: 2
Bundle-SymbolicName: foo.test.pu
Meta-Persistence:
Export-Package: model.configadmin;version="1.1.0"
Import-Package: javax.persistence;version="[2.0.4,2.0.4]";jpa="2.0",
javax.persistence.criteria;version="[2.0.4,2.0.4]";jpa="2.0",
javax.persistence.metamodel;version="[2.0.4,2.0.4]";jpa="2.0",
org.osgi.framework;version="[1.7.0,1.7.0]",
org.osgi.service.jpa;version="[1.0.0,1.0.0]"
and persistence.xml (based on org.eclipse.gemini.jpa.sample.configadmin.pu-1.1.0.RELEASE):
<persistence version="1.0"
xmlns="http://java.sun.com/xml/ns/persistence"
xsi:schemaLocation="http://java.sun.com/xml/ns/persistence http://java.sun.com/xml/ns/persistence/persistence_1_0.xsd">
<persistence-unit name="Library" transaction-type="RESOURCE_LOCAL">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
<class>model.configadmin.Library</class>
<class>model.configadmin.Book</class>
<exclude-unlisted-classes>true</exclude-unlisted-classes>
<properties>
<property name="eclipselink.weaving" value="static"/>
<property name="javax.persistence.jdbc.driver" value="com.mysql.jdbc.Driver" />
<property name="javax.persistence.jdbc.url" value="jdbc:mysql://localhost:3306/test" />
<property name="javax.persistence.jdbc.user" value="test" />
<property name="javax.persistence.jdbc.password" value="test" />
</properties>
</persistence-unit>
</persistence>
FUDForum. Page generated in 0.01952 seconds
