Home » Eclipse Projects » BIRT » Reg : Particular column should not repeat
Reg : Particular column should not repeat [message #1001259] Wed, 16 January 2013 10:37 Go to next message
Mindlogicx Infratec is currently offline Mindlogicx InfratecFriend
I am creating a mark sheet report.
for displaying marks based on subject i am using group but one particular column should not repeat.
eg:
Subject Marks Remarks
Maths 50
English 50 A-Absent
Hindi 45 Z-Zero
Science 45
Remarks column should not repeat and it will contain static value.
Re: Reg : Particular column should not repeat [message #1001409 is a reply to message #1001259] Wed, 16 January 2013 16:47 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason WeathersbyFriend
Do you have sample data in something like a csv file that we could use to show you how to do this?
Jason
Re: Reg : Particular column should not repeat [message #1001410 is a reply to message #1001409] Wed, 16 January 2013 16:48 Go to previous messageGo to next message
Also what version of BIRT are you using?
Jason
Re: Reg : Particular column should not repeat [message #1001659 is a reply to message #1001410] Thu, 17 January 2013 06:38 Go to previous messageGo to next message
Version: 3.7.2.v20120213-809u7bFT0z0-TlB2KsjN7w
Build id: v20120214-1408
  • Attachment: sample.csv
    (Size: 1.85KB, Downloaded 140 times)
Re: Reg : Particular column should not repeat [message #1001947 is a reply to message #1001659] Thu, 17 January 2013 15:41 Go to previous messageGo to next message
I did not see a remarks column in your sample data.
Jason
Re: Reg : Particular column should not repeat [message #1008171 is a reply to message #1001947] Mon, 11 February 2013 09:11 Go to previous messageGo to next message
sorry for the late reply..
The remarks column is static. so no need to fetch from database.
thank you
Re: Reg : Particular column should not repeat [message #1008321 is a reply to message #1008171] Mon, 11 February 2013 22:28 Go to previous message
So in the case of the CSV how do you want it displayed? If you select a column, you can always check the suppress duplicates box to not repeat fields.
Jason
Previous Topic:Zoom Capability
Next Topic:Dynamic Crosstab report
Current Time: Tue Dec 07 22:19:11 GMT 2021
Powered by FUDForum. Page generated in 0.02760 seconds
