Home » Modeling » EMF » [CDO] CDOAdapter vs CDOViewInvalidationEvent
[CDO] CDOAdapter vs CDOViewInvalidationEvent [message #1000744] Tue, 15 January 2013 11:21 Go to next message
Christophe Bouhier is currently offline Christophe BouhierFriend
In the title I suggest that CDOAdapter and CDOViewInvalidationEvent compete, which is what I would like to be confirmed. Nowdays, when I have to deal with invalidations I do:
1. turn on passive updates.
2. Register an IListener on a CDOView , and dispatch according to the event, i.e. an CDOViewInvalidationEvent would be used to call refresh() on a viewer.
3. I also call view.options().addChangeSubscriptionPolicy(CDOAdapterPolicy.CDO); which would be used when adding a CDOAdapter to an object to be observed.
Question: If that same object is data-bound to a JFace viewer, any notification would also be reflected on the viewer. Is this statement correct?
I guess, I am asking how to use a CDOAdapter in combination with JFace databinding.
rgds Christophe
Re: [CDO] CDOAdapter vs CDOViewInvalidationEvent [message #1000781 is a reply to message #1000744] Tue, 15 January 2013 12:28 Go to previous messageGo to next message
Eike Stepper is currently offline Eike StepperFriend
Am 15.01.2013 12:21, schrieb Christophe Bouhier:
> Hello,
> 1. turn on passive updates. 2. Register an IListener on a CDOView , and dispatch according to the event, i.e. an
> CDOViewInvalidationEvent would be used to call refresh() on a viewer. 3. I also call
The effects of CDOViewInvalidationEvent and EMF adapter notification are very similar. They originate from the same
doInvalidate() method in CDOViewImpl (i.e. they don't compete for exclusive usage):
fireInvalidationEvent(lastUpdateTime, Collections.unmodifiableMap(revisionDeltas),
Collections.unmodifiableSet(detachedObjects));
// First handle the conflicts, if any.
if (conflicts != null)
handleConflicts(conflicts, deltas);
// Then send the notifications. The deltas could have been modified by the conflict resolvers.
if (!deltas.isEmpty() || !detachedObjects.isEmpty())
sendDeltaNotifications(deltas, detachedObjects, oldRevisions);
You see that adapters are only notified if deltas are available while the invalidation event (as the name implies) is
also emitted if only the IDs of the changed objects are available. There are two ways to request that the server sends
deltas in addition to the object IDs:
1) session.options().setPassiveUpdateMode(PassiveUpdateMode.CHANGES);
2) view.options().addChangeSubscriptionPolicy(CDOAdapterPolicy.ALL);
Does that help?
Cheers
/Eike
http://www.esc-net.de
Re: [CDO] CDOAdapter vs CDOViewInvalidationEvent [message #1000791 is a reply to message #1000781] Tue, 15 January 2013 12:46 Go to previous messageGo to next message
Yes this helps! So there is a relation between the passiveUpdateMode and which subscriptions
are delivered. Still I am not sure what the purpose of CDOAdapter is, if the policy is CDOAdapterPolicy.CDO.
If the passive update mode is CHANGES, this means that I will receive the delta's by a listener
which processes an InvalidationEvent. So basically all information is in the delta, why would I need to add a CDOAdapter to the object?
Is it that both approaches are interchangeable, and do more or less the same thing?
So why are there two ways? (If my observation is correct..)
Thank You Christophe
Re: [CDO] CDOAdapter vs CDOViewInvalidationEvent [message #1000804 is a reply to message #1000791] Tue, 15 January 2013 13:00 Go to previous messageGo to next message
Am 15.01.2013 13:46, schrieb Christophe Bouhier:
> Yes this helps! So there is a relation between the passiveUpdateMode and which subscriptions are delivered. Still I am
It's just a convenient way to limit subscriptions to specific adapters, those that implement CDOAdapter.
> If the passive update mode is CHANGES, this means that I will receive the delta's by a listener which processes an
> InvalidationEvent.
And all adapters are also notified! The passive update mode was introduced together with the offline and fail-over
replication where a client (the repository synchronizer) really needs all deltas from all objects at all times,
unconditionally.
You don't have to. That depends on your change subscription policy.
Yes, more or less.
Their characteristics can be very different, especially for large and heavily modified repositories, where you only work
with few local objects.
And there are historical reasons. Adapter notification as such is a little newer than the event mechansim.
Cheers
/Eike
Re: [CDO] CDOAdapter vs CDOViewInvalidationEvent [message #1000823 is a reply to message #1000804] Tue, 15 January 2013 13:37 Go to previous messageGo to next message
Thank you Eike. I suspected there was some historical reason.
One more thing. Suppose I use a CDOAdapter and add it to a cdoObject.eAdapters() collection.
Do I need to register it on the whole containment hierarchy or would it also be notified when changes occur on the children? (In a similar fashion as EContentAdapter would work).
rgds Christophe
Re: [CDO] CDOAdapter vs CDOViewInvalidationEvent [message #1000830 is a reply to message #1000823] Tue, 15 January 2013 13:45 Go to previous messageGo to next message
Am 15.01.2013 14:37, schrieb Christophe Bouhier:
Or any other kind of adapter that's matched by your change subscription policy ;-)
> and add it to a cdoObject.eAdapters() collection. Do I need to register it on the whole containment hierarchy or would
CDOAdapter is really just a marker *interface*. It has no behaviour by itself, so it depends on your adpater
implementation. You could use an EContentAdapter (subclass) but that would really load all the contents. For cases where
you're just interested in changes to the already loaded contents there's a CDOLazyContentAdapter.
Cheers
/Eike
Re: [CDO] CDOAdapter vs CDOViewInvalidationEvent [message #1006571 is a reply to message #1000830] Thu, 31 January 2013 20:14 Go to previous messageGo to next message
Eike,
I tried the CDOLazyContentAdapter today.
It seems it only registers adapters in an CDOObjectHandler, when the object is of type Resource.
(Which seems to be the purpose, as it is used only as an adapter for CDOModificationTracking of a CDO Resource).
So this code, will add adapters to newly added root target, which has to be a Resource.
Is this a correct observation?
protected void setTarget(EObject target)
    if (isConnectedObject(target))
      if (adaptedRoot == null)
        adaptedRoot = new WeakReference<CDOObject>(CDOUtil.getCDOObject(target));
      basicSetTarget(target);
      if (target instanceof Resource)
        addCleanObjectHandler(target);
    else
      super.setTarget(target);
merci Christophe
Re: [CDO] CDOAdapter vs CDOViewInvalidationEvent [message #1006606 is a reply to message #1006571] Fri, 01 February 2013 07:03 Go to previous messageGo to next message
Am 31.01.2013 21:15, schrieb Christophe Bouhier:
> Eike,
> I tried the CDOLazyContentAdapter today. It seems it only registers adapters in an CDOObjectHandler, when the object
Why do you think this?
No. If it would only exist to be an implementation detail of modification tracking, we'd probably have made it internal.
> So this code, will add adapters to newly added root target, which has to be a Resource. Is this a correct observation?
No, I don't think so.
Cheers
/Eike
> else
> merci Christophe
Re: [CDO] CDOAdapter vs CDOViewInvalidationEvent [message #1006619 is a reply to message #1006606] Fri, 01 February 2013 08:38 Go to previous messageGo to next message
I tried it, when I pass a non Resource object, this code:
if (target instanceof Resource){
prevents it from adding the objectHandler, which will do the actual adding of the already loaded objects in the view. I will further test it, and might submit a bug, test and patch for it.
Cheers Christophe
Re: [CDO] CDOAdapter vs CDOViewInvalidationEvent [message #1006625 is a reply to message #1006619] Fri, 01 February 2013 09:06 Go to previous messageGo to next message
Am 01.02.2013 09:38, schrieb Christophe Bouhier:
I see. I'm not sure why Vik added this guard, but you're right, CDO itself only uses the adapter with resource roots:
org.eclipse.emf.cdo.util.CDOLazyContentAdapter
org.eclipse.emf.cdo.util.CDOModificationTrackingAdapter.CDOModificationTrackingAdapter(CDOResource)
org.eclipse.emf.cdo.tests.bugzilla.Bugzilla_247141_Test.testBehaviourOnUncommittedObjects()
org.eclipse.emf.cdo.tests.bugzilla.Bugzilla_247141_Test.testContentAdapterBehaviour()
I agree that this should be tested and fixed eventually. The chance that this happens soon is bigger with a patch ;-)
Thanks!
Cheers
/Eike
Re: [CDO] CDOAdapter vs CDOViewInvalidationEvent [message #1006696 is a reply to message #1006625] Fri, 01 February 2013 13:29 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=399723
Previous Topic:[CDO] Installation of CDO 4.2 failed
Next Topic:[CDO] using the testbed
Current Time: Tue Apr 16 07:18:36 GMT 2024
Powered by FUDForum. Page generated in 0.04938 seconds
