Cant see (Run > Run As > Run-time Workbench) [message #13514] |
Tue, 05 April 2005 06:05 |
Originally posted by: prasen.bea.com
Trying to Run "Log Parser Sample". I followed the readme.html till I
get to the stage where it asks me to create a run-time instance of the
Workbench (Run > Run As > Run-time Workbench).
I cant see any "Run-time Workbench" under Run-> Run As.
What am I doing wrong here ?
thanks,
prasen
Re: Cant see (Run > Run As > Run-time Workbench) [message #13587 is a reply to message #13566] |
Tue, 05 April 2005 14:14 |
I realized that later. But I dont get to see "Eclipse Application"
either for LogParserProject in 3.1. Although if I use 3.0.0 then I can
see Run As > Run-time Workbench. But if I use 3.0.0 I dont get to see
"Simple Parser V1.0" in AddLogFile wizard.
And LogParserproject doesnt seem to work with 3.1 out-of-the-box. What
do I need to do to make it work in 3.1 ?
Any other combination of eclipse/haydes-tool will work oob ?
thanks,
prasen
Paul Slauenwhite wrote:
> Hi Prasen,
> In Eclipse v3.1 (Eclipse base for TPTP v4.0), "Run-time Workbench" has
> been changed to "Eclipse Application". As such:
> Run > Run As > Eclipse Application
> I will open a defect to have this changed in all of the TPTP v4.0
> samples.
> Paul
> <prasen@bea.com> wrote in message news:d2ta0j$qit$1@news.eclipse.org...
>>thanks,
>>prasen
Re: Cant see (Run > Run As > Run-time Workbench) [message #13608 is a reply to message #13587] |
Tue, 05 April 2005 14:29 |
OK. I deleted one of the plugin-import and it seem to worked
<requires>
<!-- <import
plugin="org.eclipse.hyades.logging.adapter.config"/> -->
<import plugin="org.eclipse.hyades.logging.parsers"/>
</requires>
thanks,
prasen
> thanks,
> prasen
>> Hi Prasen,
>> has
>> samples.
>> Paul
>>> thanks,
>>> prasen
FUDForum. Page generated in 0.03119 seconds
