Using plans with Virgo tooling [message #1000319] |
Mon, 14 January 2013 14:18 |
Simon Watson Messages: 30 Registered: September 2011 |
Member |
I'm developing a project with Virgo 3.6 and I'd like to understand if it's possible to use a plan to install bundles within my Eclipse IDE.
I'd like to use a plan to control the order bundles are loaded in (this seems crucial for success with Gemini JPA & DBAccess). A plan works just fine in a production deployment (plan in pickup folder, bundles in /usr repo) but is it possible to make this work within the Eclipse IDE with Virgo tooling? In this environment, the plan would reference bundle projects in the Eclipse workspace.
Looking at bug report 379765 (https://bugs.eclipse.org/bugs/show_bug.cgi?id=379765), it seems like this isn't yet supported. However, the final bug comment talks about a workaround, where the stage folder is added as a watched repo when the Virgo server is started within Eclipse.
I've tried to replicate this by doing the following:
1. Create a copy my Virgo server's configuration folder called configuration-eclipse.
2. Edit org.eclipse.virgo.repository.properties in my new config folder to add the stage folder as a watched repo. The chain is set as stage,ext,usr
3. Modify the launch configuration of the server in Eclipse IDE to point at the new configuration by adding the argument: -Dorg.eclipse.virgo.kernel.config=configuration-eclipse
4. Create a simple test bundle (named foo.test) and test plan (test.plan) projects in my Eclipse workspace
5. Drag the plan onto the server in Eclipse. I can then expand the plan and see the bundle referenced (pretty neat, although I'm not sure what mechanism it uses to find the bundle at this point). Both the plan and the bundle JAR are present in Virgo's stage folder.
6. The server gives an error "Cannot find bundle 'foo.test' version range '[0.0.0, oo)' in repository 'ext-usr'". Where does 'ext-usr' come from?
What am I doing wrong? Should this approach work? Is there any way to check that Eclipse is using its new config?
I also notice a org.eclipse.virgo.repository.properties file in the stage folder - what creates this and why?
Beyond this simple test case, I would like the plan to reference both bundles in my workspace, and those in the /usr repo e.g. Gemini JPA bundles, DB driver.
Test bundle's manifest:
Manifest-Version: 1.0
Bundle-Vendor: Test
Bundle-Version: 1.0.0
Bundle-Name: TestBundle
Bundle-ManifestVersion: 2
Bundle-Description: Test
Bundle-SymbolicName: foo.test
Test plan manifest:
Bundle-Name: TestPlan
Bundle-SymbolicName: foo.test.plan
Test plan:
<plan name="test.plan" version="1.0.0" scoped="true" atomic="true"
xmlns="http://www.eclipse.org/virgo/schema/plan"
xsi:schemaLocation="
http://www.eclipse.org/virgo/schema/plan/eclipse-virgo-plan.xsd">
<artifact type="bundle" name="foo.test" />
</plan>
Server output:
[2013-01-14 14:11:22.687] TCP Connection(5)-127.0.0.1 <DE0000I> Installing plan 'test.plan' version '1.0.0'.
[2013-01-14 14:11:22.688] TCP Connection(5)-127.0.0.1 <DE0700E> Cannot find bundle 'foo.test' version range '[0.0.0, oo)' in repository 'ext-usr'.
[2013-01-14 14:11:22.691] TCP Connection(5)-127.0.0.1 <DE0002E> Installation of plan 'test.plan' version '1.0.0' failed. org.eclipse.virgo.nano.deployer.api.core.DeploymentException: Deployment of plan 'test.plan' version '1.0.0' in scope 'null' failed: bundle 'foo.test' in version range '[0.0.0, oo)' not found
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.operate(PlanResolver.java:116)
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.access$0(PlanResolver.java:92)
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver$1.visit(PlanResolver.java:86)
at org.eclipse.virgo.util.common.ThreadSafeGraphNode.visitInternal(ThreadSafeGraphNode.java:193)
at org.eclipse.virgo.util.common.ThreadSafeGraphNode.visit(ThreadSafeGraphNode.java:184)
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.transform(PlanResolver.java:82)
at org.eclipse.virgo.kernel.install.pipeline.stage.transform.internal.TransformationStage.doProcessGraph(TransformationStage.java:54)
at org.eclipse.virgo.kernel.install.pipeline.stage.AbstractPipelineStage.process(AbstractPipelineStage.java:41)
at org.eclipse.virgo.kernel.install.pipeline.internal.StandardPipeline.doProcessGraph(StandardPipeline.java:62)
at org.eclipse.virgo.kernel.install.pipeline.internal.CompensatingPipeline.doProcessGraph(CompensatingPipeline.java:73)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.driveInstallPipeline(PipelinedApplicationDeployer.java:359)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.doInstall(PipelinedApplicationDeployer.java:185)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.install(PipelinedApplicationDeployer.java:140)
at org.eclipse.virgo.kernel.deployer.core.internal.PipelinedApplicationDeployer.deploy(PipelinedApplicationDeployer.java:253)
at org.eclipse.virgo.kernel.deployer.management.StandardDeployer.deploy(StandardDeployer.java:52)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at com.sun.jmx.mbeanserver.ConvertingMethod.invokeWithOpenReturn(ConvertingMethod.java:167)
at com.sun.jmx.mbeanserver.MXBeanIntrospector.invokeM2(MXBeanIntrospector.java:96)
at com.sun.jmx.mbeanserver.MXBeanIntrospector.invokeM2(MXBeanIntrospector.java:33)
at com.sun.jmx.mbeanserver.MBeanIntrospector.invokeM(MBeanIntrospector.java:208)
at com.sun.jmx.mbeanserver.PerInterface.invoke(PerInterface.java:120)
at com.sun.jmx.mbeanserver.MBeanSupport.invoke(MBeanSupport.java:262)
at com.sun.jmx.interceptor.DefaultMBeanServerInterceptor.invoke(DefaultMBeanServerInterceptor.java:836)
at com.sun.jmx.mbeanserver.JmxMBeanServer.invoke(JmxMBeanServer.java:761)
at javax.management.remote.rmi.RMIConnectionImpl.doOperation(RMIConnectionImpl.java:1454)
at javax.management.remote.rmi.RMIConnectionImpl.access$300(RMIConnectionImpl.java:74)
at javax.management.remote.rmi.RMIConnectionImpl$PrivilegedOperation.run(RMIConnectionImpl.java:1295)
at javax.management.remote.rmi.RMIConnectionImpl.doPrivilegedOperation(RMIConnectionImpl.java:1387)
at javax.management.remote.rmi.RMIConnectionImpl.invoke(RMIConnectionImpl.java:818)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:303)
at sun.rmi.transport.Transport$1.run(Transport.java:159)
at sun.rmi.transport.Transport.serviceCall(Transport.java:155)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:535)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:790)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:649)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:680)
Caused by: org.eclipse.virgo.nano.deployer.api.core.DeploymentException: bundle 'foo.test' in version range '[0.0.0, oo)' not found
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.obtainInstallArtifactGraph(PlanResolver.java:165)
at org.eclipse.virgo.kernel.deployer.core.internal.PlanResolver.operate(PlanResolver.java:101)
... 48 common frames omitted
[2013-01-14 14:11:22.694] TCP Connection(5)-127.0.0.1 <DE0003E> Install failed for plan 'test.plan' version '1.0.0'.
[2013-01-14 14:11:23.544] TCP Connection(5)-127.0.0.1 <ME0003I> Dump 'serviceability/dump/2013-01-14-14-11-696' generated
FUDForum. Page generated in 0.03981 seconds
