Purpose for supporting JTA in Gemini-JPA [message #999213] |
Fri, 11 January 2013 15:14 |
One OSGI compliant JTA implementation which works well with spring exists: wouldn't it be possible to integrate Atomikos in Gemini-JPA (or Gemini-Tx) in order to support JTA XA transaction in JPA?
Or making a bridge in order to integrate these both worlds.
Best regards, Charlie Mordant
Re: Purpose for supporting JTA in Gemini-JPA [message #999230 is a reply to message #999223] |
Fri, 11 January 2013 15:53 |
Unfortunately, i'm neither an Atomikos expert nor a Gemini-JPA source code explorer, it was just a suggestion.
If you find some more competent lead dev I would be glad to help.
I will try to view how both are coded, and if it they're easy to mix, but I can't promise any result.
FUDForum. Page generated in 0.03556 seconds
