Home » Eclipse Projects » BIRT » Publishing/Sharing BIRT Reports
Publishing/Sharing BIRT Reports [message #999200] Fri, 11 January 2013 14:52 Go to next message
birt user is currently offline birt userFriend
I'm new to BIRT and I've gotten the BIRT Report Designer setup. However, I'm not sure about what is the best practice for deploying my BIRT reports to the server with the BIRT runtime.
Is there a built-in BIRT deployment mechanism in the Report Designer? Or should I write a jsp page to upload the .rptdesign file to my server?
Thanks.
Re: Publishing/Sharing BIRT Reports [message #1000927 is a reply to message #999200] Tue, 15 January 2013 17:45 Go to previous message
Michael Williams is currently offline Michael WilliamsFriend
No, unfortunately, there is no deployment mechanism to deploy your reports to Tomcat or whatever app server you're using, from the designer. In Actuate BIRT, this connection can be made to allow publishing to the BIRT iServer.
Michael
Developer Evangelist, Silanis
Previous Topic:specify alternate JDBC drivers folder
Next Topic:Charts in a crosstab column
Current Time: Mon Dec 06 03:39:47 GMT 2021
Powered by FUDForum. Page generated in 0.02263 seconds
