Home » Eclipse Projects » WindowBuilder » Incomplete product installation(Windowbuilder won't launch)
Incomplete product installation [message #998967] Fri, 11 January 2013 03:49 Go to next message
Thorsten Willard is currently offline Thorsten WillardFriend
I've just installed Eclipse Juno (4.2.1) and other programs work fine. When I create a designer Class the code is generated but when I try to go to designer I get:
Incomplete product installation or upgrade detected. Please install or update the entire product. If the problem persists, un-install and re-install the entire product. Also ensure that the Eclipse JDT and PDE are fully installed as required by the system requirements
I did the following:
1. File->New->Java Project
2. Project name: MyProj (JavaSE-1.7)
3. Finish
4. Expand MyProj in Package Explorer
5. Right-Click on "src"
6. New->Other
7. Expand "WindowBuilder" folder
8. Expand "Swing" folder
9. Select "Application Window"
10. Next
11. Name: MyProj
12. Finish
13. Click "Designer" tab
I installed WindowDesigner from Help->Install new software
I selected all options when installing then did a "Check for Updates".
Help->About Eclipse->Installation Details->Installed Software Shows I have:
Swing Designer
WindowBuilder Core
WindowBuilder Core UI
WindowBuilder GroupLayout Support
Please Help, This is for a class I'm taking and really need to get this working.
Re: Incomplete product installation [message #999306 is a reply to message #998967] Fri, 11 January 2013 19:29 Go to previous message
Eric Clayberg is currently offline Eric ClaybergFriend
WHat exact version of WB do you have installed and what update site did you install it from?
What happened when you tried the suggestions in the error message?
Previous Topic:Custom composite with GridLayout
Next Topic:Preview pane does not receive focus
Current Time: Sun Mar 29 12:34:57 GMT 2020
Powered by FUDForum. Page generated in 0.03201 seconds
