Home » Modeling » EMF » [GWT] Where to download the runtime components
Re: [GWT] Where to download the runtime components [message #998745 is a reply to message #998714] |
Thu, 10 January 2013 15:54 |
Dirk Hoffmann Messages: 163 Registered: July 2009 |
Now to the newsgroup:
I managed to download it as a zip File, but still there are lines in the
generated code flagged red. For now these are imports of classes in
packages whose names start with
org.eclipse.emf.common
I would expect them in the
org.eclipse.emf.gwt.ecore.source_2.8.1.v20120917-0436.jar
but seemingly they arent not there.
But now I'm a bit lost.
My plans are to have the GWT client request data from the server as an
XML-serialized object of a type defined in Ecore.
How would I go about that? Are there the same concepts of
XMIResourceSets in the GWT area as in common Java?
Can I use the same Ecore model for the server as well as for the client?
See also below...
Thanks and Regards,
Dirk
Am 10.01.2013 15:44, schrieb Ed Merks:
> Dirk,
> Yes, they're in that update site. You need to use this URL and
> provision a target platform as described in the wiki.
Which URL and which wiki do you mean?
> On 10/01/2013 3:15 PM, Dirk Hoffmann wrote:
>> Hi,
>> from further posts I have learned that I can't simply install the
>> EMF/GWT jars into my instance of Eclipse but have to create a
>> directory acting as a platform target.
>> So where can I download the required runtoime components.
>> I found
>> http://download.eclipse.org/modeling/emf/emf/updates/2.8/
>> but that just tells me it is an update site.
>> I'm using the latest Eclipse 4.2.1 with GWT 2.5.
>> Regards,
>> Dirk
Re: [GWT] Where to download the runtime components [message #999052 is a reply to message #998775] |
Fri, 11 January 2013 08:25 |
Hi Ed,
thanks. I had been missing the fact that the IDE allows me to include
update sites into platform target definitions.
Still there is a problem: The "Edit Target Definition" dialog now
complains about an unsatisfied dependency:
Cannot satisfy dependency:
To: org.eclipse.emf.cheatsheets
Dirk
Am 10.01.2013 18:16, schrieb Ed Merks:
> Dirk,
> You don't want (can't have) the GWT runtime installed in the IDE. You
> must create GWT target platform that contains them and you create such a
> thing following the steps in http://wiki.eclipse.org/EMF/GWT
>>> Dirk,
>> Which wiki and where. For me Eclipse is a huge universe and I often
>> find it hard to find the right galaxy.
>> Tried to run
>> ./eclipsec.exe \
>> -application org.eclipse.equinox.p2.director \
>> -repository http://download.eclipse.org/modeling/emf/emf/updates/2.8 \
>> -installIU org.eclipse.emf.feature.group \
>> -tag FetchEMF \
>> -destination d:/s/K/emf2.8 \
>> -profile SDKProfile
>> but that failed.
>> Also appending /site.xml to the URL dis not succeed.
>>>> Hi,
>>>> I found
>>>> Regards,
>>>> Dirk
Re: [GWT] Where to download the runtime components [message #999071 is a reply to message #999052] |
Fri, 11 January 2013 09:20 |
Ed Merks Messages: 33137 Registered: July 2009 |
Dirk,
Did you pick just the EMF GWT Runtime feature? It doesn't depend on the
things you mention below.
On 11/01/2013 9:25 AM, Dirk Hoffmann wrote:
> Hi Ed,
> From: org.eclipse.emf.doc.feature.group
> Regards,
> Dirk
>> Dirk,
>>>> Dirk,
>>> Tried to run
>>> ./eclipsec.exe \
>>> -repository
>>> -tag FetchEMF \
>>> -profile SDKProfile
>>> but that failed.
>>>>> Hi,
>>>>> I found
>>>>> Regards,
>>>>> Dirk
Ed Merks
Re: [GWT] Where to download the runtime components [message #999146 is a reply to message #999071] |
Fri, 11 January 2013 12:56 |
Hi Ed,
thanks again.
Being more selective about the features and unchecking "Include required
software" did help.
In which situations would I need the other EMF GWT features?
I had to remove some app-engine related stuff from the run configuration
and eventually succeeded in getting the editor running in development mode.
Actually I do not want to deploy the application to the app engine, just
to an ordinary J2EE servlet container.
Under WEB-INF/lib I see a number of jars, some of them related to the
app engine, others I have no clue what they are for.
Can I remove some of them?
Dirk
Am 11.01.2013 10:20, schrieb Ed Merks:
> Dirk,
>> Hi Ed,
>> Regards,
>> Dirk
>>> Dirk,
>>>>> Dirk,
>>>> Tried to run
>>>> ./eclipsec.exe \
>>>> -repository
>>>> -tag FetchEMF \
>>>> -profile SDKProfile
>>>> but that failed.
>>>>>> Hi,
>>>>>> I found
>>>>>> Regards,
>>>>>> Dirk
Re: [GWT] Where to download the runtime components [message #999153 is a reply to message #999146] |
Fri, 11 January 2013 13:12 |
Dirk,
Comments below.
On 11/01/2013 1:56 PM, Dirk Hoffmann wrote:
> Hi Ed,
> thanks again.
> required software" did help.
The target stuff you need target platform. The rest are just
sub-features of the SDK feature. When developing you'd want the full
SDK. When deploying your application (the Java portion for the server),
you'd need the EMF GWT runtime feature.
> configuration and eventually succeeded in getting the editor running
> just to an ordinary J2EE servlet container.
See what happens, but most are there because AppEngine or GWT want the
to be there.
> Regards,
> Dirk
>> Dirk,
>>> Hi Ed,
>>> Regards,
>>> Dirk
>>>> Dirk,
>>>> such a
>>>>>> Dirk,
>>>>> Tried to run
>>>>> ./eclipsec.exe \
>>>>> -repository
>>>>> -tag FetchEMF \
>>>>> -profile SDKProfile
>>>>> but that failed.
>>>>>>> Hi,
>>>>>>> I found
>>>>>>> Regards,
>>>>>>> Dirk
Ed Merks
Current Time: Fri Apr 19 20:07:17 GMT 2024
Powered by FUDForum. Page generated in 0.04178 seconds
