Re: Fix Table height on each page [message #999344 is a reply to message #999002] |
Fri, 11 January 2013 21:49 |
Take a look at this BIRT Exchange example. It shows a way to extend a table using an HTML text box. Another way you could extend the table is by using extra footer rows, then hide/show them based on how many rows are on the last page. If you have multi-line rows, you can compute the number of lines based off of characters, for a good esitmate.
Michael
Developer Evangelist, Silanis
Re: Fix Table height on each page [message #1002473 is a reply to message #1001336] |
Fri, 18 January 2013 16:45 |
I set up a report that I could run, with a simple scripted dataSet and set a PGV in the fetch script and recalled it in the table header label's onRender, with no issue. Can you create a report, that I can run, that has this issue?
Michael
FUDForum. Page generated in 0.03865 seconds
