Re: Update site build replacing qualifier [message #998676 is a reply to message #998511] |
Thu, 10 January 2013 13:45 |
you are referring to legacy update site, not p2 repository, right?
On 01/10/2013 07:25 AM, Phillip Drew wrote:
> Basically when I build my update site the first time it works fine. The
> versions of the features used are just 1.0.0.qualifier.
> However when it does the build it replaces the '.qualifier' with the
> actual concrete value.
> When I try to build the update site again at a later time it complains
> that it can't find the features between the version range [previous
> concrete qualifier, previous concrete qualifier], obviously because the
> qualifier has moved on!
> It doesn't happen all the time but it is happening consistently enough
> to be a big stumbling block in what should be a smooth update process.
> When it does complain about not being able to find the correct version I
> have to go into the site.xml and replace the concrete qualifier with
> '.qualifier' again.
> Any suggestions what could be causing my problem?
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
TDD Book: https://leanpub.com/tdd-buildautomation-ci
Xtext Book: https://www.packtpub.com/application-development/implementing-domain-specific-languages-xtext-and-xtend-second-edition
FUDForum. Page generated in 0.03957 seconds
