Re: EMF and SOAP - how? [message #998358 is a reply to message #998324] |
Wed, 09 January 2013 21:31 |
He Anton,
You can also try the EMF subproject Texo, this project is targeted for web server/service environments (although more
using JSON/REST/XML approaches).
http://wiki.eclipse.org/Texo
http://martintaal.wordpress.com/2012/04/05/emf-texo-json-rest-web-service-support-connecting-your-client-to-an-emf-supporting-web-server/
gr. Martin
On 01/09/2013 09:02 PM, Anton Hughes wrote:
> Hi
> I'm new to EMF and, so far, and very impressed with it.
> Especially xcore.
> However, today I tried to use my generated code in a webservice and found that I couldnt.
> This is surprising.
> Are there any ways to easily change the generated classes so that they are compatible with SOAP?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: EMF and SOAP - how? [message #998611 is a reply to message #998600] |
Thu, 10 January 2013 10:47 |
Ed Merks Messages: 33140 Registered: July 2009 |
Anton,
I know SOAP as an XML-based interchange protocol, but I don't know what
it means to be a SOAP object. What are EMF objects missing in order to
be SOAP objects?
On 10/01/2013 11:33 AM, Anton Hughes wrote:
> Hi Ed
> Your message came through as raw html - not the easiest to read. But
> I'm trying ... :)
> The links that you posted show how to use EMF generated classes with
> xml - but not soap.
> It appears that the generated objects are not compatiable for as Soap
> objects.
Ed Merks
FUDForum. Page generated in 0.03236 seconds
