Home » Eclipse Projects » Virgo » ClassNotFoundException: javax.validation.spi.ValidationProvider after upgrade to Virgo 3.6
ClassNotFoundException: javax.validation.spi.ValidationProvider after upgrade to Virgo 3.6 [message #998047] Wed, 09 January 2013 09:00 Go to next message
Jean-Pierre Bergamin is currently offline Jean-Pierre BergaminFriend
Member
Hello everyone
We are upgrading Virgo from 3.0.3 to 3.6 and face a ClassNotFoundException we cannot explain. The same setup worked in 3.0.3 though.
[2013-01-09 09:35:45.814] start-signalling-2           <DE0006E> Start failed for bundle 'net.junisphere.eranger.core.config' version '1.0.0.RELEASE'. org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dbUpdateExecutor' defined in URL [bundleentry://164.fwk1495622108/META-INF/spring/db-update-context.xml]: Cannot create inner bean 'net.junisphere.eranger.domain.internal.neo4j.dbupdate.VersionUpdate#dd63e54' of type [net.junisphere.eranger.domain.internal.neo4j.dbupdate.VersionUpdate] while setting constructor argument with key [0]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.junisphere.eranger.domain.internal.neo4j.dbupdate.VersionUpdate#dd63e54' defined in URL [bundleentry://164.fwk1495622108/META-INF/spring/db-update-context.xml]: Cannot create inner bean 'net.junisphere.eranger.domain.internal.neo4j.dbupdate.task.AddUuidToPropertyValueNodes#2e5b9f90' of type [net.junisphere.eranger.domain.internal.neo4j.dbupdate.task.AddUuidToPropertyValueNodes] while setting constructor argument with key [0]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.junisphere.eranger.domain.internal.neo4j.dbupdate.task.AddUuidToPropertyValueNodes#2e5b9f90': Injection of autowired dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire field: private org.springframework.data.neo4j.support.Neo4jTemplate net.junisphere.eranger.domain.internal.neo4j.dbupdate.AbstractTask.neo4j; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'customNeo4jConfiguration': Injection of autowired dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire field: private javax.validation.Validator org.springframework.data.neo4j.config.Neo4jConfiguration.validator; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'validator' defined in URL [bundleentry://164.fwk1495622108/META-INF/spring/module-context.xml]: Initialization of bean failed; nested exception is java.lang.TypeNotPresentException: Type javax.validation.spi.ValidationProvider not present
	at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveInnerBean(BeanDefinitionValueResolver.java:281)
	at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:120)
	at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveManagedList(BeanDefinitionValueResolver.java:353)
	at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:153)
	at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:630)
	at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:148)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1035)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:939)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:485)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:456)
	at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:294)
	at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:225)
	at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:291)
	at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:193)
	at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:585)
	at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:913)
	at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.access$1600(AbstractDelegatedExecutionApplicationContext.java:60)
	at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext$4.run(AbstractDelegatedExecutionApplicationContext.java:325)
	at org.eclipse.gemini.blueprint.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
	at org.eclipse.gemini.blueprint.context.support.AbstractDelegatedExecutionApplicationContext.completeRefresh(AbstractDelegatedExecutionApplicationContext.java:290)
	at org.eclipse.gemini.blueprint.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor$CompleteRefreshTask.run(DependencyWaiterApplicationContextExecutor.java:137)
	at org.eclipse.virgo.kernel.agent.dm.ContextPropagatingTaskExecutor$2.run(ContextPropagatingTaskExecutor.java:95)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
	at java.lang.Thread.run(Thread.java:722)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.junisphere.eranger.domain.internal.neo4j.dbupdate.VersionUpdate#dd63e54' defined in URL [bundleentry://164.fwk1495622108/META-INF/spring/db-update-context.xml]: Cannot create inner bean 'net.junisphere.eranger.domain.internal.neo4j.dbupdate.task.AddUuidToPropertyValueNodes#2e5b9f90' of type [net.junisphere.eranger.domain.internal.neo4j.dbupdate.task.AddUuidToPropertyValueNodes] while setting constructor argument with key [0]; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.junisphere.eranger.domain.internal.neo4j.dbupdate.task.AddUuidToPropertyValueNodes#2e5b9f90': Injection of autowired dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire field: private org.springframework.data.neo4j.support.Neo4jTemplate net.junisphere.eranger.domain.internal.neo4j.dbupdate.AbstractTask.neo4j; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'customNeo4jConfiguration': Injection of autowired dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire field: private javax.validation.Validator org.springframework.data.neo4j.config.Neo4jConfiguration.validator; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'validator' defined in URL [bundleentry://164.fwk1495622108/META-INF/spring/module-context.xml]: Initialization of bean failed; nested exception is java.lang.TypeNotPresentException: Type javax.validation.spi.ValidationProvider not present
	at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveInnerBean(BeanDefinitionValueResolver.java:270)
	... 24 common frames omitted
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'net.junisphere.eranger.domain.internal.neo4j.dbupdate.task.AddUuidToPropertyValueNodes#2e5b9f90': Injection of autowired dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire field: private org.springframework.data.neo4j.support.Neo4jTemplate net.junisphere.eranger.domain.internal.neo4j.dbupdate.AbstractTask.neo4j; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'customNeo4jConfiguration': Injection of autowired dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire field: private javax.validation.Validator org.springframework.data.neo4j.config.Neo4jConfiguration.validator; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'validator' defined in URL [bundleentry://164.fwk1495622108/META-INF/spring/module-context.xml]: Initialization of bean failed; nested exception is java.lang.TypeNotPresentException: Type javax.validation.spi.ValidationProvider not present
	at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor.postProcessPropertyValues(AutowiredAnnotationBeanPostProcessor.java:287)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1106)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:517)
	... 34 common frames omitted
Caused by: org.springframework.beans.factory.BeanCreationException: Could not autowire field: private org.springframework.data.neo4j.support.Neo4jTemplate net.junisphere.eranger.domain.internal.neo4j.dbupdate.AbstractTask.neo4j; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'customNeo4jConfiguration': Injection of autowired dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire field: private javax.validation.Validator org.springframework.data.neo4j.config.Neo4jConfiguration.validator; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'validator' defined in URL [bundleentry://164.fwk1495622108/META-INF/spring/module-context.xml]: Initialization of bean failed; nested exception is java.lang.TypeNotPresentException: Type javax.validation.spi.ValidationProvider not present
	at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor$AutowiredFieldElement.inject(AutowiredAnnotationBeanPostProcessor.java:506)
	at org.springframework.beans.factory.annotation.InjectionMetadata.inject(InjectionMetadata.java:87)
	at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor.postProcessPropertyValues(AutowiredAnnotationBeanPostProcessor.java:284)
	... 38 common frames omitted
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'customNeo4jConfiguration': Injection of autowired dependencies failed; nested exception is org.springframework.beans.factory.BeanCreationException: Could not autowire field: private javax.validation.Validator org.springframework.data.neo4j.config.Neo4jConfiguration.validator; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'validator' defined in URL [bundleentry://164.fwk1495622108/META-INF/spring/module-context.xml]: Initialization of bean failed; nested exception is java.lang.TypeNotPresentException: Type javax.validation.spi.ValidationProvider not present
	at org.springframework.beans.factory.support.ConstructorResolver.instantiateUsingFactoryMethod(ConstructorResolver.java:353)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateUsingFactoryMethod(AbstractAutowireCapableBeanFactory.java:1015)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:911)
	at org.springframework.beans.factory.support.DefaultListableBeanFactory.findAutowireCandidates(DefaultListableBeanFactory.java:848)
	at org.springframework.beans.factory.support.DefaultListableBeanFactory.doResolveDependency(DefaultListableBeanFactory.java:790)
	at org.springframework.beans.factory.support.DefaultListableBeanFactory.resolveDependency(DefaultListableBeanFactory.java:707)
	at org.springframework.beans.factory.annotation.AutowiredAnnotationBeanPostProcessor$AutowiredFieldElement.inject(AutowiredAnnotationBeanPostProcessor.java:478)
	... 40 common frames omitted
Caused by: org.springframework.beans.factory.BeanCreationException: Could not autowire field: private javax.validation.Validator org.springframework.data.neo4j.config.Neo4jConfiguration.validator; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'validator' defined in URL [bundleentry://164.fwk1495622108/META-INF/spring/module-context.xml]: Initialization of bean failed; nested exception is java.lang.TypeNotPresentException: Type javax.validation.spi.ValidationProvider not present
	... 60 common frames omitted
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'validator' defined in URL [bundleentry://164.fwk1495622108/META-INF/spring/module-context.xml]: Initialization of bean failed; nested exception is java.lang.TypeNotPresentException: Type javax.validation.spi.ValidationProvider not present
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:527)
	... 62 common frames omitted
Caused by: java.lang.TypeNotPresentException: Type javax.validation.spi.ValidationProvider not present
	at sun.reflect.generics.factory.CoreReflectionFactory.makeNamedType(CoreReflectionFactory.java:117)
	at sun.reflect.generics.visitor.Reifier.visitClassTypeSignature(Reifier.java:125)
	at sun.reflect.generics.tree.ClassTypeSignature.accept(ClassTypeSignature.java:49)
	at sun.reflect.generics.reflectiveObjects.WildcardTypeImpl.getUpperBounds(WildcardTypeImpl.java:130)
	at com.sun.beans.TypeResolver.resolve(TypeResolver.java:327)
	at com.sun.beans.TypeResolver.resolve(TypeResolver.java:362)
	at com.sun.beans.TypeResolver.resolve(TypeResolver.java:321)
	at com.sun.beans.TypeResolver.resolve(TypeResolver.java:172)
	at com.sun.beans.TypeResolver.resolveInClass(TypeResolver.java:93)
	at java.beans.FeatureDescriptor.getParameterTypes(FeatureDescriptor.java:387)
	at java.beans.MethodDescriptor.setMethod(MethodDescriptor.java:114)
	at java.beans.MethodDescriptor.<init>(MethodDescriptor.java:72)
	at java.beans.MethodDescriptor.<init>(MethodDescriptor.java:56)
	at java.beans.Introspector.getTargetMethodInfo(Introspector.java:1130)
	at java.beans.Introspector.getBeanInfo(Introspector.java:414)
	at java.beans.Introspector.getBeanInfo(Introspector.java:161)
	at org.springframework.beans.CachedIntrospectionResults.<init>(CachedIntrospectionResults.java:224)
	at org.springframework.beans.CachedIntrospectionResults.forClass(CachedIntrospectionResults.java:149)
	at org.springframework.beans.BeanWrapperImpl.getCachedIntrospectionResults(BeanWrapperImpl.java:324)
	at org.springframework.beans.BeanWrapperImpl.getPropertyDescriptors(BeanWrapperImpl.java:331)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.filterPropertyDescriptorsForDependencyCheck(AbstractAutowireCapableBeanFactory.java:1242)
	at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1101)
	... 71 common frames omitted
Caused by: org.eclipse.virgo.kernel.osgi.framework.ExtendedClassNotFoundException: javax.validation.spi.ValidationProvider in KernelBundleClassLoader: [bundle=org.springframework.context_3.1.0.RELEASE]
	at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:139)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:356)
	at java.lang.Class.forName0(Native Method)
	at java.lang.Class.forName(Class.java:264)
	at sun.reflect.generics.factory.CoreReflectionFactory.makeNamedType(CoreReflectionFactory.java:114)
	... 94 common frames omitted
Caused by: java.lang.ClassNotFoundException: javax.validation.spi.ValidationProvider
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
	at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
	at org.eclipse.virgo.kernel.userregion.internal.equinox.KernelBundleClassLoader.loadClass(KernelBundleClassLoader.java:135)
	... 98 common frames omitted
The class javax.validation.spi.ValidationProvider is available as shown in the console:
osgi> clhas javax.validation.spi.ValidationProvider
Bundles containing [javax/validation/spi/ValidationProvider]
  84    com.springsource.javax.validation
        /javax/validation/spi/ValidationProvider.class
Any clues why this class cannot be loaded in Virgo 3.6?
James
Re: ClassNotFoundException: javax.validation.spi.ValidationProvider after upgrade to Virgo 3.6 [message #998287 is a reply to message #998047] Wed, 09 January 2013 18:20 Go to previous messageGo to next message
Chris Frost is currently offline Chris FrostFriend
We don't ship the com.springsource.javax.validation bundle with either version of Virgo so can you tell me how you are making it available to your application, using the ext/use repositories. Also, which packaging of Virgo are you running on. Virgo Tomcat/Kernel/Nano etc..?
There has been a lot of change in this area but I can't see anything specific to that bundle or package so I can't think of anything obvious. I will ask a colleague to have a look as well but the information asked for above will be helpful.
Chris.
Chris Frost, Twitter @cgfrost
Springsource, a divison of VMware.
Re: ClassNotFoundException: javax.validation.spi.ValidationProvider after upgrade to Virgo 3.6 [message #998327 is a reply to message #998287] Wed, 09 January 2013 20:06 Go to previous messageGo to next message
Member
Hi Chris
We provide the com.springsource.javax.validation bundle in the repository/usr repo on Virgo Tomcat 3.6.0.
Our bundle that uses the validation bundle, explicitely imports the javax.validation.spi package, because bundlor is not able to resolve it automatically.
Well... What differs from our current deployment on Virgo 3.0 is that we now are using the spring version 3.1 that comes with virgo 3.6. But the classloading problem still is strange. It somehow sees to be a similiar issue that has been fixed quite a while ago: https://issuetracker.springsource.com/browse/DMS-1930
We're glad for any hints how we can fix this class loading issue.
Thanks so far,
James
Re: ClassNotFoundException: javax.validation.spi.ValidationProvider after upgrade to Virgo 3.6 [message #998811 is a reply to message #998327] Thu, 10 January 2013 18:23 Go to previous messageGo to next message
I have had an initial look at this and I can't see anything obvious. I have asked a question on the mailing dev mailing list to get some of the other committers to have a look, one of them may know more than me.
Chris.
Re: ClassNotFoundException: javax.validation.spi.ValidationProvider after upgrade to Virgo 3.6 [message #999074 is a reply to message #998047] Fri, 11 January 2013 09:25 Go to previous messageGo to next message
Hristo Iliev is currently offline Hristo IlievFriend
Hi James,
Can you please try clload command as well? It will check if your application loader can access the class.
Hristo Iliev
Re: ClassNotFoundException: javax.validation.spi.ValidationProvider after upgrade to Virgo 3.6 [message #999085 is a reply to message #999074] Fri, 11 January 2013 09:56 Go to previous messageGo to next message
Also, one of the other committers has reported the same problem, ClassNotFoundException: javax.validation.spi.ValidationProvider but not all the time, say 4 out of every 5 times? Could you try this a few times and see what happens. If you get this to work just once then it will confirm the problem as a timing issue.
Thanks, Chris.
Re: ClassNotFoundException: javax.validation.spi.ValidationProvider after upgrade to Virgo 3.6 [message #999164 is a reply to message #999085] Fri, 11 January 2013 13:41 Go to previous messageGo to next message
Florian Waibel is currently offline Florian WaibelFriend
Seems to make a difference which JVM is used:
Running with OpenJDK Runtime Environment i wasn't able to start the application (tried about 10 times)
java version "1.6.0_24"
OpenJDK Runtime Environment (IcedTea6 1.11.5) (6b24-1.11.5-0ubuntu1~12.04.1)
OpenJDK 64-Bit Server VM (build 20.0-b12, mixed mode)
results in
        ... 43 common frames omitted
Running with Java(TM) SE Runtime Environment
java version "1.6.0_38"
Java(TM) SE Runtime Environment (build 1.6.0_38-b05)
Java HotSpot(TM) Server VM (build 20.13-b02, mixed mode)
I got in about 75% of the attempts the different exception below and in the other 25% Virgo succeeds in launching the application/plan.
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.springframework.validation.beanvalidation.LocalValidatorFactoryBean#0': Invocation of init method failed; nested exception is javax.validation.ValidationException: Unable to find a default provider
[Updated on: Fri, 11 January 2013 14:10]
Report message to a moderator
Re: ClassNotFoundException: javax.validation.spi.ValidationProvider after upgrade to Virgo 3.6 [message #1000272 is a reply to message #999164] Mon, 14 January 2013 12:07 Go to previous messageGo to next message
Glyn Normington is currently offline Glyn NormingtonFriend
Check that the setting of WABHeaders is the same on your 3.0.3 and 3.6 installs.
Re: ClassNotFoundException: javax.validation.spi.ValidationProvider after upgrade to Virgo 3.6 [message #1000323 is a reply to message #999085] Mon, 14 January 2013 14:26 Go to previous messageGo to next message
Member
Chris Frost wrote on Fri, 11 January 2013 04:56
We tried it dozens of times, but it never worked - both on Windows 7 and on Ubuntu. We tried it with Oracles Java 1.6.0_37 and 1.7.0_10. So it does not seem to be a timing issue.
Re: ClassNotFoundException: javax.validation.spi.ValidationProvider after upgrade to Virgo 3.6 [message #1000326 is a reply to message #1000272] Mon, 14 January 2013 14:32 Go to previous messageGo to next message
Member
Glyn Normington wrote on Mon, 14 January 2013 07:07
The settings on both virgo versions is "WABHeaders=strict". The bundle in question also is a "normal" bundle and not a Web Application Bundle.
Re: ClassNotFoundException: javax.validation.spi.ValidationProvider after upgrade to Virgo 3.6 [message #1000329 is a reply to message #1000326] Mon, 14 January 2013 14:39 Go to previous messageGo to next message
Member
I allowed myself to open a bug report for this: https://bugs.eclipse.org/bugs/show_bug.cgi?id=398081
I set up a minimal sample project that shows this behaviour: https://bitbucket.org/ractive/validation-test
Re: ClassNotFoundException: javax.validation.spi.ValidationProvider after upgrade to Virgo 3.6 [message #1000693 is a reply to message #1000329] Tue, 15 January 2013 09:16 Go to previous message
Thanks. Let's continue the discussion in the bug as there does seem to be a reproducible problem.
Previous Topic:ActiveMQ Integration
Next Topic:IllegalArgumentException: MALFORMED while processing my servlet XML
Current Time: Tue Apr 16 23:45:30 GMT 2024
Powered by FUDForum. Page generated in 0.13126 seconds
