[CDO] Query & Lucene [message #997327] |
Sun, 06 January 2013 01:36 |
Mixa Alekseev Messages: 10 Registered: February 2011 |
Required: Indexing attributes of the object based on the annotations in the model.
How it can be implemented?
Sorry for my bad English.
Re: [CDO] Query & Lucene [message #998120 is a reply to message #997970] |
Wed, 09 January 2013 12:08 |
Christophe Bouhier Messages: 937 Registered: July 2009 |
Hi Eike,
Is this just an idea you have now, thinking out loud, or has it been done like this before? If so, can we get our hands on the code?
I looked at Lucene, it looks pretty much geard towards indexing text, but with EMF models it doesn't seem to have value. (Ok, I didn't dive deep into it, so perhaps I am talking bullocks).
I ended, building an index, which simply listens for invalidations and available server side only. What I needed to index is feature paths.
So i.e. Path 1: Object1.featureX -> Object2.featureY -> Object3.featureY , and simply serialized it as a String and put in a Hashmap with the string as the Key and the CDOID of the last object in the path as the value. A query does a text lookup on the String. Would Lucene add some value to this concept?
Cheers Christophe
[Updated on: Wed, 09 January 2013 12:08] Report message to a moderator
Re: [CDO] Query & Lucene [message #998131 is a reply to message #998120] |
Wed, 09 January 2013 12:24 |
Am 09.01.2013 13:08, schrieb Christophe Bouhier:
> Hi Eike,
> Is this jus an idea you have now, thinking out loud, or has it been done like this before? If so, can we get our hands
> on the code?
I haven't done it, nor do I know that someone else has done it. But I've thought a couple times about it ;-)
Well there are EDataTypes that do provide text, e.g., EString. I could well imagine model annotations that specify
extraction rules or configure extractor instances per package, class, feature or data type.
Yes.
I'd call those ESettings ;-)
Certainly!
Cheers
/Eike
http://www.esc-net.de
Cheers
/Eike
Re: [CDO] Query & Lucene [message #1000538 is a reply to message #1000254] |
Tue, 15 January 2013 00:29 |
Ok! Only CDO API...
Context: CDOCommitInfoHandler#handleCommitInfo(CDOCommitInfo)
CDOCommitInfo have getNewObjects which cast to InternalCDORevision
CDOCommitInfo have getChangedObjects without capabilities cast to InternalCDORevision
My spherical vacuum problem case need only "ChangedObjects" without FeatureDeltas
the similarity InternalCDORevision.getValue(feature)
Thanks!
[Updated on: Tue, 15 January 2013 00:43] Report message to a moderator
FUDForum. Page generated in 0.04230 seconds
