Re: [CDO] CDOResource path [message #997646 is a reply to message #997253] |
Sat, 05 January 2013 08:36 |
Am 04.01.2013 18:53, schrieb Andrew Whelan:
> I guess I'm just finding it confusing from a pure database context.
I see. But CDO is primarily a modeling technology. Relational databases are just one possible type of physical storage
used with CDO.
> I understand that you would need a path/URI to use the out of the box method of the EMF persistence mechanism of
> saving data to a file. This is because you need a URI to save it too.
Yes, and to load it from. I like this definition: "A CDOResource is an EObject with a well-known *name* that can serve
as an entry point into the EObject graph". Note that this is not exactly true outside of CDO because elsewhere a
Resource is typically not an EObject.
> I also see value in the idea of storing objects in different repositories. So then if I am only using one repository,
> I would just use the same repository every time?
That sounds like a trick question :P
> CDOResource resource = transaction.getOrCreateResource("/repo1");
> And then use this resource to add data to and get data from the one repository (repo1). Does this make sense or am I
> missing something?
Hmm. From an EMF point of view a resource has a URI. In CDo this URI consists of three parts, the "cdo://" prefix, the
repository UUID and the path of the resource within that repository, for example: cdo://repo1/path/to/my/resource
Note that "repo1" is usually a *name* of a repository, not it's UUID. Names are required to be unique in the scope of an
IAcceptor. In addition a repository always has a UUID that's used in client-side URIs (no network details are needed to
make URIs unique). But in the common case that an application system only uses one repository (more correct: one
host/acceptor) there's no need to pollute URIs with long and ugly UUIDs. So most people override the UUID to be the *name* .
Cheers
/Eike
http://www.esc-net.de
Cheers
/Eike
FUDForum. Page generated in 0.04088 seconds
