Infer questions [message #996507] |
Wed, 02 January 2013 08:50 |
Happy new year everyone!
I'm going to write an inferrer for my dsl and I have some questions that I could not solve with only the help of documentation.
First one:
I need to create static void main() from a feature: how can I add static with .toMethod()?
Second one:
Suppose I have a rule in my dsl like this:
Sequence:
'SEQ' name=ID '{'
statements+=Statement*
Where Statement:
Statement:
Sequence | others...
Sequence must be mapped to a void method and the body of that method is composed from the traslation of statements.
But the problem is this: when inside a Sequence I'll find another Sequence I have to create a method for the new sequence and add a call in super sequence.
For example:
SEQ first {
instructions...
SEQ second {
other instructions....
instructions...
Must generate:
void first(){
instructions(translated)...
second();
void second(){
other instructions(translated)...
Is it possible to realize it?
Very thank you, and have a good new year!
Re: Infer questions [message #997097 is a reply to message #996507] |
Thu, 03 January 2013 16:41 |
Thanks again !
A little curiosity: my previous Xtext project doesn't use Xbase and generates C code. Do you think is possible to write a debugger for it?
Re: Infer questions [message #997165 is a reply to message #996507] |
Fri, 04 January 2013 08:49 |
And is it possible to debug a dsl that generate java code without using of Xbase?
In this way I can create a simulation environment in java for debug dsl and then (if all is ok), generate the C code.
Re: Infer questions [message #997874 is a reply to message #997165] |
Tue, 08 January 2013 23:02 |
> of Xbase?
Although I didn't make further experiments, in this project
https://github.com/LorenzoBettini/Xtext-Buckminster-Example
the grammar derives from Xbase, but basically does not use its rules
https://github.com/LorenzoBettini/Xtext-Buckminster-Example/blob/master/org.xtext.example.hellobuck/src/org/xtext/example/hellobuck/HelloBuck.xtext
(the DSL in this example is pretty stupid, since that was not the final
subject :)
it then uses the inferrer to generate Java code (you can use it also if
you don't use elements from Xbase):
https://github.com/LorenzoBettini/Xtext-Buckminster-Example/blob/master/org.xtext.example.hellobuck/src/org/xtext/example/hellobuck/jvmmodel/HelloBuckJvmModelInferrer.xtend
since the generation relies on the inferrer you should get also
debugging functionalities, but they are limited, I guess, to the Java
elements you map to your model elements, and for generated Java methods
you will have to deal with trace functionalities yourself (probably
taking inspiration from XbaseCompiler).
cheers
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
TDD Book: https://leanpub.com/tdd-buildautomation-ci
Xtext Book: https://www.packtpub.com/application-development/implementing-domain-specific-languages-xtext-and-xtend-second-edition
FUDForum. Page generated in 0.04538 seconds
