Home » Archived » BIRT » Not able to see data in Web Service Data Source
Not able to see data in Web Service Data Source [message #996473] Wed, 02 January 2013 06:58 Go to next message
Sameer Singh is currently offline Sameer SinghFriend
I am creating a data source as web services. My connection is successful and i am able to create data set as well but when i am clicking on "preview data" i am getting this exception "org.eclipse.datatools.connectivity.oda.OdaException: Server redirects too many times"
Please suggest some solution.
Re: Not able to see data in Web Service Data Source [message #997106 is a reply to message #996473] Thu, 03 January 2013 18:02 Go to previous messageGo to next message
Michael Williams is currently offline Michael WilliamsFriend
Instead of choosing to preview the data, if you drag the dataSet out to the report layout and run the report, do you get the same error?
Michael
Developer Evangelist, Silanis
Re: Not able to see data in Web Service Data Source [message #997175 is a reply to message #997106] Fri, 04 January 2013 09:20 Go to previous messageGo to next message
Yes William i am getting the same error while i am dragging the dataset and running the reort
Re: Not able to see data in Web Service Data Source [message #997277 is a reply to message #997175] Fri, 04 January 2013 21:49 Go to previous message
Are you working over a VPN? That's one of the causes of an issue like this that I've found.
Michael
Previous Topic:There are errors evaluating script
Next Topic:Webshpere ,birt version 'birt-runtime-2_5_2'
Current Time: Tue Apr 16 13:39:04 GMT 2024
Powered by FUDForum. Page generated in 0.54225 seconds
