Home » Modeling » TMF (Xtext) » Skipping validations of features from EMF Model
Skipping validations of features from EMF Model [message #995815] Mon, 31 December 2012 07:18 Go to next message
Ashwani Kr Sharma is currently offline Ashwani Kr SharmaFriend
I am creating DSL for existing EMF Model who persistence format is xmi. The DSL will be just an alternate representation of xmi format.
The DSL contains many less features because i want only relevant features available to user and system specific stuff is kept hidden.
These features in DSL are marked optional in grammar. But they are not optional in ECore model.
Hence in the DSL i see error reporting that "... feature is not optional and should be specified ...". One way is to change the ECore model but I can't do this because i don't have authorizations to change the ECore model. Is it possible to skip these validation errors ?
Ashwani Kr Sharma
Re: Skipping validations of features from EMF Model [message #999616 is a reply to message #995815] Sat, 12 January 2013 17:10 Go to previous messageGo to next message
I am kinna stuck with this issue. Can you please give some hints.
Ashwani Kr Sharma
Re: Skipping validations of features from EMF Model [message #1000197 is a reply to message #995815] Mon, 14 January 2013 08:38 Go to previous messageGo to next message
Sebastian Zarnekow is currently offline Sebastian ZarnekowFriend
Am 31.12.12 08:18, schrieb Ashwani Kr Sharma:
> Regards,
> Ashwani Kr Sharma
Yes, you may skip the EObjectValidator in case you validate your
language files. See
org.eclipse.xtext.validation.CompositeEValidator.useEObjectValidator
Sebastian
Looking for professional support for Xtext, Xtend or Eclipse Modeling?
Re: Skipping validations of features from EMF Model [message #1006986 is a reply to message #1000197] Sun, 03 February 2013 15:10 Go to previous messageGo to next message
Hi Sebastian,
Where do i specify org.eclipse.xtext.validation.CompositeEValidator.useEObjectValidator ?
In mwe2 file ?
Ashwani Kr Sharma
Re: Skipping validations of features from EMF Model [message #1006990 is a reply to message #1006986] Sun, 03 February 2013 15:51 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
adding a simple straight forward binding to the runtime module doesnt work?
public void configureUseEObjectValidator(Binder binder) {
binder.bind(Boolean.class)
.annotatedWith(
Names.named(CompositeEValidator.USE_EOBJECT_VALIDATOR))
.toInstance(Boolean.FALSE);
Twitter : @chrdietrich
Re: Skipping validations of features from EMF Model [message #1010297 is a reply to message #1006990] Sun, 17 February 2013 04:21 Go to previous messageGo to next message
I have put following method in my RuntimeModule class. But nothing changes:
binder.bind(Boolean.class).annotatedWith(Names.named(CompositeEValidator.USE_EOBJECT_VALIDATOR)).toInstance(Boolean.FALSE);
I read the documentation of xText and following is mentioned there. So, can't we skip them ?
The IConcreteSyntaxValidator validates all constraints that are implied by a grammar.
Meeting these constraints for a model is mandatory to be serialized.
Ashwani Kr Sharma
[Updated on: Sun, 17 February 2013 04:55]
Report message to a moderator
Re: Skipping validations of features from EMF Model [message #1010437 is a reply to message #1010297] Sun, 17 February 2013 09:30 Go to previous message
so are we talking about two things?
first you where talking about mandatory things in the metamodel that do not appear in the grammar, not you are talking about mandatory things in the grammar that dont appear in the model?
~Christian
Previous Topic:Empty rule
Next Topic:XMI resource to xText resource
Current Time: Tue Apr 16 19:07:22 GMT 2024
Powered by FUDForum. Page generated in 0.68805 seconds
