[RESOLVED] Help Setting Up Eclipse with Egit [message #994261] |
Wed, 26 December 2012 21:47 |
Dennis Putnam Messages: 59 Registered: January 2012 |
Member |
After numerous iterations and trying many of the tutorials around I cannot get Eclipse with Egit to work the way I need. I have a Git central repository (on Linux) that contains a Java application. I want to develop that on Windows with Eclipse under version control. I still do not understand all the various repositories the tutorials tell me to create but no matter what I do I cannot develop my code on Windows. The main problem is that I cannot run the code for debugging purposes. I either do not get a Run as Application menu selection or I get class path errors. My last attempt was to create a local repository on Windows then clone that to an Eclipse project. Can someone point me to or create for me a cookbook method of using the central repository to create a project on Windows that both allows me to run the application and add and commit changes? TIA.
[Updated on: Thu, 03 January 2013 13:52] Report message to a moderator
FUDForum. Page generated in 0.03368 seconds
