[CDO] Skipping EClasses/EStructuralFeatures from prefetch [message #994182] |
Wed, 26 December 2012 16:30 |
Guido Scalise Messages: 16 Registered: April 2012 |
I'm trying to force a prefetch of a 4-level object tree, but one of the levels has a couple of structural features I want to avoid from prefetching for performance and bandwidth reasons.
I've tried putting a CDOFetchRule before prefetching and I've seen the CDOFetchRule arriving to the LoadRevisionsIndication in the server, but it doesn't do anything with it. Is there a straightforward way of telling the CDO server not to fetch/serialize an EClass or a EStructuralFeature?
Guido
[Updated on: Wed, 26 December 2012 19:13] Report message to a moderator
Re: [CDO] Skipping EClasses/EStructuralFeatures from prefetch [message #994226 is a reply to message #994182] |
Wed, 26 December 2012 19:38 |
Well, I've been investigating how the multilevel prefetch works, and I've made a *very* small modification in org.eclipse.emf.cdo.server.internal.net4j.protocol.LoadRevisionsIndication that allows me to set an arbitrary set of EClass/EStructuralFeature combinations and skip them from the prefetch operation, thus eliminating the associated Store access and network load of the pruned elements.
This change doesn't add any new data to the LoadRevisionsRequest signal payload nor to the client semantics, as the payload already contains a list of CDOFetchRule elements, which are set by using the Session's CDOFetchRuleManager (it defaults to the NOOPFetchRuleManager, which doesn't set any CDOFetchRules on the outgoing LoadRevisionsRequests).
One thing to consider is that while the API itself doesn't change, the behavior of cdoPrefetch(int depth) does change -only when CDOFetchRules are set-, so any clients already combining cdoPrefetch and CDOFetchRules might need to be reviewed to ensure that this change doesn't affect them.
If you are interested in the patch, I can post it to bugzilla or send a pull request.
Guido
[Updated on: Wed, 26 December 2012 19:49] Report message to a moderator
Re: [CDO] Skipping EClasses/EStructuralFeatures from prefetch [message #994398 is a reply to message #994226] |
Thu, 27 December 2012 07:23 |
Hi Guido,
Yes, I'm always interested in enhancements and prefetching is a recurring topic. I'll review your changes if you attach
a patch to a bugzilla.
Cheers
/Eike
http://www.esc-net.de
Am 26.12.2012 20:38, schrieb Guido Scalise:
> EClass/EStructuralFeature combinations and skip them from the prefetch, thus eliminating the associated network load.
> Regards,
> Guido
Cheers
/Eike
FUDForum. Page generated in 0.02093 seconds
