Re: Problem with the color themes [message #997410 is a reply to message #993858] |
Mon, 07 January 2013 10:52 |
The settings of your editor should be saved in the settings of your workspace (if I am not mistaken) so it would be normal to have the same setting if you try to use a new Eclipse (on the same existing workspace). If you have changed back the settings of the Java editor to the default setting, as your screenshot is suggesting it, could you go to the "General -> Editors -> Text Editors" section of the same window (the Window -> Preferences menu) to see what is the currently selected background color for your text editors.
It the setting is the "System default" then what is happening in a new workspace? If it's still dark, then it must be something in the settings of Windows.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Google+: +stephane.begaudeau
Blog: http://stephanebegaudeau.tumblr.com | Eclipse Java Development Tools Tips and Tricks
FUDForum. Page generated in 0.08223 seconds
