Home » Language IDEs » C / C++ IDE (CDT) » g++ not found in PATH (g++)
g++ not found in PATH [message #992798] Sat, 22 December 2012 12:26 Go to next message
After choosing the default "Hello World" project I am getting an ERROR g++ not found in path.
$ which g++
/usr/bin/g++
after googling I added /usr/bin/g++ to "Project -> Properties -> C/C++ Build -> Settings -> Path"
Linux Mint 13
Eclipse IDE for C/C++ Developers
Version: Juno Service Release 1
Build id: 20120920-0800
Re: g++ not found in PATH [message #994097 is a reply to message #992798] Wed, 26 December 2012 06:34 Go to previous messageGo to next message
open the package manager tool and Install the G++ package (Gnu C++ compiler).
Or, in a terminal try:
sudo apt-get install g++
regards,
Klaus
Re: g++ not found in PATH [message #1043884 is a reply to message #994097] Thu, 18 April 2013 04:21 Go to previous messageGo to next message
I have the same issue and i can´t resolve it.
I can´t find neither the f**l package manager nor the Terminal in which i can type the expression.
Re: g++ not found in PATH [message #1067926 is a reply to message #1043884] Thu, 11 July 2013 05:27 Go to previous messageGo to next message
I also had the same problem. But the following worked for me.
Note that I have following environment:
OS:
Windows XP SP3
Eclipse:
Version: Kepler Release
Build id: 20130614-0229
C/C++ compiler:
MinGW GCC
Setup environment variable PATH to include "<MINGW_HOME>/bin" where <MINGW_HOME> is the MinGW installed directory that you have chosen in the previous step.
Now to install the g++ package:
1. Start > Run > cmd
2. At the command prompt, type the following
mingw-get install g++
Re: g++ not found in PATH [message #1070632 is a reply to message #992798] Thu, 18 July 2013 07:02 Go to previous messageGo to next message
This is the solution that works for me in Ubuntu Linux.eclipse-cpp-kepler-R-linux-gtk.tar.gz
1) Remove the directory of eclipse installation. For example: rm -rf eclipse
2) If g++ was not installed yet, then install it: sudo apt-get install g++
3) Reinstall the eclipse. For example: tar zxvf eclipse-cpp-kepler-R-linux-gtk.tar.gz
4) Run the eclipse for the first time with this command: ./eclipse -initialize
5) After the initialization was done, run it as normal: ./eclipse
Re: g++ not found in PATH [message #1243465 is a reply to message #1067926] Mon, 10 February 2014 21:25 Go to previous messageGo to next message
This did not work for me. I followed the exact steps but I still continue to get the same error.
Re: g++ not found in PATH [message #1276584 is a reply to message #1243465] Mon, 24 March 2014 15:21 Go to previous messageGo to next message
this helped for me:
1. Edit the project's environments settings (Properties/ C/C++ Build / Environment). If the PATH variable doesn't appear here or is not printed boldly, then cancel that dialog and edit them in Window / Preferences / C/C++ Build / Environment).
2. Make sure your PATH variable setting contains the string ':${PATH}'. It must have the curly braces around it! If the variable is already there and isn't resolved anyway, then get its value from your operating system and replace ${PATH} with that value.
(from the GIMP developer wiki)
Re: g++ not found in PATH [message #1404394 is a reply to message #1070632] Thu, 31 July 2014 19:10 Go to previous messageGo to next message
David C wrote on Thu, 18 July 2013 07:02
Point number four has worked for me, I didn't even had to reinstall eclipse just ran that command. Thank you
Re: g++ not found in PATH [message #1715974 is a reply to message #1276584] Sun, 29 November 2015 21:58 Go to previous messageGo to next message
this worked for me thanks!
Re: g++ not found in PATH [message #1757938 is a reply to message #992798] Wed, 22 March 2017 00:19 Go to previous messageGo to next message
what I don't understand is why the super geniuses who made this couldn't even make the install work correctly. doesn't fill a guy with confidence when something as simple as installing it doesn't work right. They sure made it seem like this would compile and run c/c++ programs. Guess you'd call it false advertising but I didn't pay anything for it. What's that old adage? You get what you pay for?
Re: g++ not found in PATH [message #1768609 is a reply to message #992798] Thu, 20 July 2017 10:53 Go to previous messageGo to next message
I'm having same issue.
Ubuntu 16.04.
Eclipse CDT returns "Program "powerpc-linux-gcc not found in PATH" and same for g++.
But:
toug@ubuntu:~/Test_C$ ll /usr/bin/powerpc-linux-gnu-gcc
lrwxrwxrwx 1 root root 23 Feb 11  2016 /usr/bin/powerpc-linux-gnu-gcc -> powerpc-linux-gnu-gcc-5*
toug@ubuntu:~/Test_C$ echo $PATH
/home/toug/bin:/home/toug/.local/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games:/snap/bin
so what's the trick?
I tried to run eclipse --initialize once, but no change.
Re: g++ not found in PATH [message #1768715 is a reply to message #1768609] Sat, 22 July 2017 02:49 Go to previous message
Maybe because powerpc-linux-gcc is not the same as powerpc-linux-gnu-gcc ?
Not enough info to determine why g++ isn't found.
Is it installed?
[Updated on: Sat, 22 July 2017 05:05] by Moderator
Previous Topic:watchpoint unimplemented call
Next Topic:How do I create a simple shared object library in C
Current Time: Fri Apr 25 19:19:37 EDT 2025
Powered by FUDForum. Page generated in 0.10375 seconds
