Re: swt error - has anybody seen that? [message #992685 is a reply to message #992421] |
Sat, 22 December 2012 09:38 |
as far as I know buckminster headless should not use swt stuff... what
features have you installed in your headless buckminster?
cheers
Lorenzo
On 12/21/2012 04:45 PM, Axel Guckelsberger wrote:
> Hi all,
> I am getting a weird error for a good while (probably since the update
> to Juno) in all my Jenkins builds.
> ERROR: [SCR] Error while attempting to deactivate instance of component
> Component[
> name = org.eclipse.e4.ui.css.swt.theme
> activate = activate
> deactivate = deactivate
> modified = configuration-policy = optional
> factory = null
> autoenable = true
> immediate = true
> implementation =
> org.eclipse.e4.ui.css.swt.internal.theme.ThemeEngineManager
> state = Disabled
> properties = serviceFactory = false
> serviceInterface = [org.eclipse.e4.ui.css.swt.theme.IThemeManager]
> references = null
> located in bundle =
> org.eclipse.e4.ui.css.swt.theme_0.9.3.v20120806-170624 [591]
> java.lang.NoClassDefFoundError: org/eclipse/swt/widgets/Display
> at java.lang.Class.getDeclaredMethods0(Native Method)
> at java.lang.Class.privateGetDeclaredMethods(Class.java:2427)
> at java.lang.Class.getDeclaredMethods(Class.java:1791)
> at
> org.eclipse.equinox.internal.ds.model.ServiceComponent.getMethod(ServiceComponent.java:126)
> at
> org.eclipse.equinox.internal.ds.model.ServiceComponent.deactivate(ServiceComponent.java:337)
> at
> org.eclipse.equinox.internal.ds.model.ServiceComponentProp.deactivate(ServiceComponentProp.java:161)
> at
> org.eclipse.equinox.internal.ds.model.ServiceComponentProp.dispose(ServiceComponentProp.java:389)
> at
> org.eclipse.equinox.internal.ds.model.ServiceComponentProp.dispose(ServiceComponentProp.java:102)
> at
> org.eclipse.equinox.internal.ds.InstanceProcess.disposeInstances(InstanceProcess.java:366)
> at
> org.eclipse.equinox.internal.ds.InstanceProcess.disposeInstances(InstanceProcess.java:306)
> at
> org.eclipse.equinox.internal.ds.Resolver.disposeComponentConfigs(Resolver.java:717)
> at
> org.eclipse.equinox.internal.ds.Resolver.disableComponents(Resolver.java:693)
> at
> org.eclipse.equinox.internal.ds.SCRManager.stoppingBundle(SCRManager.java:554)
> at
> org.eclipse.equinox.internal.ds.SCRManager.bundleChanged(SCRManager.java:233)
> at
> org.eclipse.osgi.framework.internal.core.BundleContextImpl.dispatchEvent(BundleContextImpl.java:847)
> at
> org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
> at
> org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
> at
> org.eclipse.osgi.framework.internal.core.Framework.publishBundleEventPrivileged(Framework.java:1568)
> at
> org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1504)
> at
> org.eclipse.osgi.framework.internal.core.Framework.publishBundleEvent(Framework.java:1499)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.stopWorker(BundleHost.java:506)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.suspend(AbstractBundle.java:566)
> at
> org.eclipse.osgi.framework.internal.core.Framework.suspendBundle(Framework.java:1206)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.decFWSL(StartLevelManager.java:592)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:257)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.shutdown(StartLevelManager.java:215)
> at
> org.eclipse.osgi.framework.internal.core.InternalSystemBundle.suspend(InternalSystemBundle.java:284)
> at
> org.eclipse.osgi.framework.internal.core.Framework.shutdown(Framework.java:692)
> at
> org.eclipse.osgi.framework.internal.core.Framework.close(Framework.java:600)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.shutdown(EclipseStarter.java:399)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:199)
> at
> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at java.lang.reflect.Method.invoke(Method.java:597)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
> Caused by: java.lang.ClassNotFoundException:
> org.eclipse.swt.widgets.Display
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
> at
> org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
> at
> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
> at java.lang.ClassLoader.loadClass(ClassLoader.java:247)
> ... 39 more
> This seems to be independent of which bundles are installed in the
> headless Buckminster environment (using five different ones which
> contain different bundles).
> Also this error occurs in all job types, may it building a p2 repository
> for a certain component / feature, or may it running a test suite.
> Has maybe anybody seen this before?
> Thank you, Axel
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
TDD Book: https://leanpub.com/tdd-buildautomation-ci
Xtext Book: https://www.packtpub.com/application-development/implementing-domain-specific-languages-xtext-and-xtend-second-edition
FUDForum. Page generated in 0.02729 seconds
