Home » Language IDEs » Java Development Tools (JDT) » Howto Link all projects to same code formatter rules file
icon5.gif  Howto Link all projects to same code formatter rules file [message #992375] Fri, 21 December 2012 08:52 Go to next message
Hey Eclipse-Users,
I have about 50 Eclipse Java projects form different developers and I want to use the same code formatter rules for all projects.
So I create a set of formatter rules and export them into a XML file. Is it possible to link all projects to this file? So I only have to change this single file when updating the formatting rules?
The only way I found so far is to update all projects manually by importing with the XML file. Then rules are then copied to org.eclipse.jdt.code.prefs. So changing rules is very expensive.
Patrick
Re: Howto Link all projects to same code formatter rules file [message #992738 is a reply to message #992375] Sat, 22 December 2012 08:11 Go to previous messageGo to next message
I don't think that it can be done, personnaly when I have to update the configuration of the formatter on my projects, I import the XML file on one project and then I copy the content of the file ".settings/org.eclipse.jdt.code.prefs" of this project and paster it in all the other projects. It's a bit faster than importing the XML file in all the projects.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Google+: +stephane.begaudeau
Blog: http://stephanebegaudeau.tumblr.com | Eclipse Java Development Tools Tips and Tricks
Re: Howto Link all projects to same code formatter rules file [message #992812 is a reply to message #992738] Sat, 22 December 2012 13:20 Go to previous messageGo to next message
I'm surprised you want to re-format projects from different developers, rather than letting each project define its own formatting rules.
Secondly, wouldn't per-workspace preferences serve your needs?
Third, if you want to synchronize settings between developers / projects / workspaces, you may want to use a plug-in like workspace mechanic.
my 2c.
Re: Howto Link all projects to same code formatter rules file [message #997371 is a reply to message #992812] Mon, 07 January 2013 03:51 Go to previous message
Thank's for your answers. I will have a look on your suggestions.
Previous Topic:No Java Perspective
Next Topic:Java Inspector ignores static imports
Current Time: Mon Jun 16 09:46:40 EDT 2025
Powered by FUDForum. Page generated in 0.04947 seconds
