Where can I change the background colour of the suggestion popups? [message #991941] |
Thu, 20 December 2012 14:18 |
daniel mouritsen Messages: 4 Registered: December 2012 |
When I hover over a error, and it give me suggestions how to fix this (as in, importing the relevant classes, implementing missing methods etc etc). This is done in narrow blue writing on a black background, and is borderline impossible to read. I tend to use this feature quite alot for importing classes, so its fairly annoying.
How can I fix this?
I'm on 4.1.2 running on Arch Linux, I don't want to break my gtk theme (as in change this in my theme. The theme works perfectly fine with all other applications on the workstation, and I don't want to compromise this).
[Updated on: Thu, 20 December 2012 14:19] Report message to a moderator
Re: Where can I change the background colour of the suggestion popups? [message #992142 is a reply to message #992136] |
Fri, 21 December 2012 00:41 |
On 12/20/2012 05:17 PM, daniel mouritsen wrote:
> thank you very much for taking the time to make this detailed answer.
> Unfortunately, it doesn't work on Linux. I just checked, the change
> works fine on OSX, but does nothing on Linux. In the same way as the
> marketplace links doesn't work etc. etc. I suppose eclipse on Linux is
> not really a priority :/
I've resorted to changing appearance. For example, on Lucid (under
Gnome), I use Clearlooks.
FUDForum. Page generated in 0.07812 seconds
