Home » Eclipse Projects » DSDP - Target Management » SystemStartHere.getSystemRegistry() returns null
SystemStartHere.getSystemRegistry() returns null [message #13247] |
Fri, 27 July 2007 11:54 |
Originally posted by: nchan.cisco.com
Iam trying to use Eclipse RSE 2.0 API to connect to an SSH server.
The first step of getting the ISystemRegistry itself fails :(
What am I doing wrong ?
My Eclipse version is 3.3.0.
My project is an eclipse plugin project and I have added the RSE plugins
to my plugin dependancies.
Iam able to get the RSE System details from RSECorePlugin.
RSECorePlugin rsep = RSECorePlugin.getDefault();
IRSECoreRegistry registry = rsep.getCoreRegistry();
IRSESystemType[] sysTypes = registry.getSystemTypes();
for (IRSESystemType sysType : sysTypes) {
System.out.println("System Name : " + sysType.getName());
System.out.println("System Desc : " + sysType.getDescription());
System.out.println("System ID : " + sysType.getId());
output :
RSECORE PLUGIN:org.eclipse.rse.core
registry.getSystemType()class org.eclipse.rse.internal.core.RSECoreRegistry
System Name : SSH Only
System Desc : Connection for SSH access to remote systems
System ID : org.eclipse.rse.systemtype.ssh
System Name : FTP Only
System Desc : Connection for FTP access to remote systems
System ID : org.eclipse.rse.systemtype.ftp
System Name : Windows
System Desc : Any version of Microsoft Windows
System ID : org.eclipse.rse.systemtype.windows
System Name : Linux
System Desc : Any distribution of Linux
System ID : org.eclipse.rse.systemtype.linux
System Name : Unix
System Desc : Any distribution of Unix
System ID : org.eclipse.rse.systemtype.unix
System Name : Local
System Desc : Local file system on this computer
System ID : org.eclipse.rse.systemtype.local
What am I missing ?
Any help in this regard is much appreciated.
Chandran Narasimhan.l
Re: SystemStartHere.getSystemRegistry() returns null [message #13274 is a reply to message #13247] |
Fri, 27 July 2007 18:13 |
Martin Oberhuber Messages: 1007 Registered: July 2009 |
Hello Chandran,
unfortunately RSE does not really work headless yet.
The interfaces have been moved to non-UI but it still
requires the UI to get booted :-(
In other words, what you need is activating RSEUIPlugin
which will then instanciate the SystemRegistry and make
it available for others:
//Start RSE initialization
RSEUIPlugin.getDefault();
//Wait until initialization complete
final IRSEPersistenceManager pm =
RSECorePlugin.getThePersistenceManager();
try {
while (!pm.isRestoreComplete() || pm.isBusy()) Thread.sleep(100);
} catch(InterruptedException e) {
/*bail out or ignore*/
I know it's not pretty at all, but unfortunately it is what you have to
do right now. The RSEUIPlugin instantiates the SystemRegistry and
schedules the InitRSEJob, which initializes the SystemProfileManager,
which leads to doing
RSECorePlugin.getThePersistenceManager().restoreProfiles(500 0).
You'll need to wait for that to be complete before you can do anything
useful.
This code should work although problems have been reported with it
(intermittent NullPointerExceptions, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=194802
). I'd be interested in getting feeback from you whether it works OK for
you. At any rate you should CC and/or comment on that bug.
For improving the situation as such, we already have a bug filed for a
better API to get a callback when RSE is up and the model is fully restored:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=197167
and for being able to do all this in non-UI we have
https://bugs.eclipse.org/bugs/show_bug.cgi?id=190231
for moving the SystemRegistry itself into non-UI we do not currently
have a bug, but it's kind of obvious and part of improving UI/non-UI
splitting as discussed in
http://wiki.eclipse.org/index.php/TM_Future_Planning
Martin Oberhuber
Target Management Project Lead, DSDP PMC Member
http://www.eclipse.org/dsdp/tm
Chandran Narasimhan wrote:
> output :
> System Name : Linux
> System Name : Unix
> System Name : Local
> What am I missing ?
Re: SystemStartHere.getSystemRegistry() returns null [message #13302 is a reply to message #13274] |
Mon, 30 July 2007 16:36 |
Hi Martin,
Thanks a lot for your prompt response.
Yes, using RSEUIPlugin to get the RSE System registry works ! Am able to
execute commands using SSH !
I spent 2 full days debugging the RSECorePlugin before I sent the mail
to eclipse.dsdp.tm newsgroup :)
Anyway these 2 days I have learned lots of technical stuff about the
Eclipse TM and RSE Architecture.
I have got the registry from RSEUIPlugin :
ISystemRegistry isr = RSEUIPlugin.getTheSystemRegistry();
I have ran it couple of times and I didn't got any NULLPointer exception.
Btw, since Iam using RSEUIPlugin I have included the RSE UI Plugin as
dependencies to my application. Following are the RSE plugins which I
have added as dependencies :
1 - org.eclipse.rse.core
2 - org.eclipse.rse.services
3 - org.eclipse.rse.services.ssh
4 - org.eclipse.rse.ui
5 - org.eclipse.rse.subsystems.shells.core
This adds the following functionality that we don't need in our application.
1 - The 'Remote System Explorer' perspective is added to my workbench.
2 - Getting an 'Info' popup with an empty message when I connect to the
SSH system before command execution.
3 - Iam getting a 'Project Explorer' View that contains an UI Tree of
various services properties.
- RemoteSystemsConnection
- dom.properties
- PRF.<mypcname>_0
- FP.daytime.tcp_0
node.properties
- FP.dstore.files_0
node.properties
Any workarounds to solve the 3 issues listed above ?
Should I vote for the bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=197167 ?
Martin Oberhuber wrote:
> Hello Chandran,
> try {
> useful.
> restored:
> Martin Oberhuber
>> Hi,
>> plugins to my plugin dependancies.
>> sysType.getName());
>> System.out.println("System ID : " + sysType.getId()); }
>> output :
>> System Name : Linux
>> System Name : Unix
>> System Name : Local
>> What am I missing ?
>> Thanks,
Re: SystemStartHere.getSystemRegistry() returns null [message #569356 is a reply to message #13247] |
Hello Chandran,
try {
useful.
Martin Oberhuber
> output :
> System Name : Linux
> System Name : Unix
> System Name : Local
> What am I missing ?
Re: SystemStartHere.getSystemRegistry() returns null [message #569419 is a reply to message #13274] |
Hi Martin,
- dom.properties
- PRF.<mypcname>_0
- FP.daytime.tcp_0
node.properties
- FP.dstore.files_0
node.properties
> Hello Chandran,
> try {
> useful.
> restored:
> Martin Oberhuber
>> Hi,
>> sysType.getName());
>> output :
>> System Name : Linux
>> System Name : Unix
>> System Name : Local
>> What am I missing ?
>> Thanks,
Current Time: Thu Apr 25 13:49:32 GMT 2024
Powered by FUDForum. Page generated in 0.04118 seconds
