Home » Eclipse Projects » Dynamic Languages Toolkit (DLTK) » Instance DLTK Editor manually
Instance DLTK Editor manually [message #991307] Tue, 18 December 2012 12:50 Go to next message
Rodrigo Antonio is currently offline Rodrigo AntonioFriend
Hello!
I have a problem here.
I made an Editor using the DLTK, it works correctly, however need to instantiate it manually.
I need to instantiate it within the WindowBuilder.
Any idea?
Thank you.
Re: Instance DLTK Editor manually [message #991423 is a reply to message #991307] Wed, 19 December 2012 03:01 Go to previous messageGo to next message
Alex Panchenko is currently offline Alex PanchenkoFriend
Hi Rodrigo,
Do you mean create the editor inside of some other editor/dialog or what
exactly?
ScriptSourceViewer can be embedded with the code like this:
IDocument document = new Document();
ScriptTextTools tools = uiToolkit.getTextTools();
tools.setupDocumentPartitioner(document);
IPreferenceStore store = uiToolkit.getCombinedPreferenceStore();
ScriptSourceViewer viewer = new ScriptSourceViewer(parent, null, null,
false, SWT.V_SCROLL | SWT.H_SCROLL, store);
ScriptSourceViewerConfiguration configuration =
uiToolkit.createSourceViewerConfiguration();
viewer.configure(configuration);
viewer.setDocument(document);
Control control = viewer.getControl();
GridData data = new GridData(GridData.FILL_BOTH);
control.setLayoutData(data);
Alex
Re: Instance DLTK Editor manually [message #991663 is a reply to message #991423] Wed, 19 December 2012 23:59 Go to previous messageGo to next message
Hi Alex,
In my plugin which derives from the "Window Builder" I created an editor that derives from MultiPageEditorPart.
In this class I create 3 tabs.
I would put the DLTK editor in the first tab.
I put a TextEditor (org.eclipse.ui.editors.TextEditor) in the first tab, and it works well, however, I would use my DLTK edtior the facilities it offers.
I think my problem with this natures ...
I will test the above source.
Thank you.
Rodrigo
Re: Instance DLTK Editor manually [message #992087 is a reply to message #991663] Thu, 20 December 2012 20:50 Go to previous message
As I understand, if you can use TextEditor in the multipageeditor, then
you should also be able to use DLTK based editor, as it extends TextEditor.
What's exactly the problem?
Alex
Previous Topic:Want to get ruby working in Eclipse for the first time? (DLTK 2.0)
Next Topic:Blank console window after running Ruby code
Current Time: Thu Nov 26 02:14:50 GMT 2020
Powered by FUDForum. Page generated in 0.02033 seconds
