Re: Forced to set project specific settings [message #991093 is a reply to message #991030] |
Mon, 17 December 2012 10:41 |
Dani Megert Messages: 3802 Registered: July 2009 |
On 17.12.2012 11:36, Pierre-Yves Benzaken wrote:
> Hi everyone,
> I have following problem:
> Since I migrated my projects from Eclipse 3.7.2 to Eclipse 4.2, I am
> forced to enable project specific compiler settings.
> The only installed JRE within Eclipse is a 1.6.0 JDK and in the
> preferences the compiler compliance level is set to 1.6.
Eclipse does not come with an installed JRE. You specify the JRE. In an
empty workspace that JRE is installed and used by default but you can
add additional JREs on the Java > Installed JREs preference page and you
can also specify the compiler compliance default on the Java > Compiler
preference page. Note though, that it is recommended to set those things
on your projects, e.g. to ease sharing them with others.
Dani
> Still, all java projects containing java 1.5 specific language
> extensions, like static imports, don't compile any longer. I have to
> edit the properties of each project invidually and set the compiler
> compliance level to 1.6 by activating project specific settings. After
> that, I have to clean my project and it will compile successfully.
> Anyone knows whether this is a known bug?
> Any help would be appreciated :)
> P-Y
Re: Forced to set project specific settings [message #991130 is a reply to message #991103] |
Mon, 17 December 2012 12:49 |
On 17.12.2012 12:24, Pierre-Yves Benzaken wrote:
> Hi Dani,
> Thanks for your answer. Unfortunately it looks like I wasn't really
> clear enough ;)
> I added the JRE and set the compiler settings correctly. And this a
> long time ago! My point is only that, while working with Eclipse 3.x,
> I never had problems, and now with Eclipse 4.2, it looks like the
> compiler settings (those from the preferences) are totally ignored and
> I have to set them on each project.
We've never seen this. If you have self-contained reproducible steps,
then please file a bug against JDT UI.
Dani
> Even if, as you are stating, this might be desired in order to ease
> sharing, this is not what I want!
> P-Y
FUDForum. Page generated in 0.04199 seconds
