Home » Archived » BIRT » Line height property not working in pdf with value under 4mm
Line height property not working in pdf with value under 4mm [message #990813] Fri, 14 December 2012 05:47 Go to next message
hi
the line height property works as long as its over 4mm but as soon as its under this value it doesn't work for the pdf output (it works in the html output). am i doing something wrong or is it really not working?
if it's not working is there a workaround?
i tested it on Eclipse BIRT Designer Version 4.2.1.v201209101448
thanks for any help
raffael
Re: Line height property not working in pdf with value under 4mm [message #991133 is a reply to message #990813] Mon, 17 December 2012 07:59 Go to previous messageGo to next message
Can you attach an example showing exactly what you're seeing, so I can see all your settings?
Re: Line height property not working in pdf with value under 4mm [message #991260 is a reply to message #991133] Tue, 18 December 2012 02:58 Go to previous messageGo to next message
if you let the 2 files run on html output and pdf output the lineheight setting works for both files on the html output but on the pdf output only for the one with more then +- 4mm
Re: Line height property not working in pdf with value under 4mm [message #991368 is a reply to message #991260] Tue, 18 December 2012 13:44 Go to previous messageGo to next message
The PDF limitation comes with the text size. This may be deemed a feature. If you make the text size smaller, the line height is able to decrease to match. You can always log a bug for this in the bugzilla.
Re: Line height property not working in pdf with value under 4mm [message #992263 is a reply to message #991368] Fri, 21 December 2012 03:31 Go to previous messageGo to next message
thanks for the answer even though its not the answer i hoped for
I filed a bug here https://bugs.eclipse.org/bugs/show_bug.cgi?id=397057
Re: Line height property not working in pdf with value under 4mm [message #992398 is a reply to message #992263] Fri, 21 December 2012 09:42 Go to previous messageGo to next message
Do you know of any workaround?
Re: Line height property not working in pdf with value under 4mm [message #992410 is a reply to message #992398] Fri, 21 December 2012 10:19 Go to previous messageGo to next message
Unfortunately, I don't. If I run across something, I'll post it in here.
Re: Line height property not working in pdf with value under 4mm [message #992412 is a reply to message #992410] Fri, 21 December 2012 10:21 Go to previous messageGo to next message
thanks that would be great
Re: Line height property not working in pdf with value under 4mm [message #997370 is a reply to message #992412] Mon, 07 January 2013 03:38 Go to previous messageGo to next message
Hi Michael
do you by any chance have a clue where this limitation is in the source code of birt?
thanks for any hint to where to find it
thanks for any help
raffael
Re: Line height property not working in pdf with value under 4mm [message #997505 is a reply to message #997370] Mon, 07 January 2013 16:00 Go to previous message
I don't know exactly where, but my guess would be in the pdf emitter code.
Previous Topic:How to move a report item from one page to the previous.
Next Topic:Report items from library is not shown
Current Time: Thu Apr 24 05:08:42 EDT 2025
Powered by FUDForum. Page generated in 0.04239 seconds
