Home » Archived » Buckminster » creating an action which depends on other components' actions
Re: creating an action which depends on other components' actions [message #990431 is a reply to message #990426] |
Wed, 12 December 2012 13:30   |
On 2012-12-12 13:58, Lorenzo Bettini wrote:
> Hi
> in a .cspex I'd like to define an action which has as prerequisites the
> invocation of site.p2 NOT on this component but on other components...
> <prerequisites alias="repositories">
> <attribute name="site.p2" component="my.component" />
> <attribute name="site.p2" component="my.other.component" />
> </prerequisites>
> but this does not work at all...
> any clue please?
It should work. And a lot of things relies on that mechanism. What makes
you think it doesn't work? It's hard to give clues unless you provide
some more details.
- thomas
Re: creating an action which depends on other components' actions [message #990474 is a reply to message #990431] |
Wed, 12 December 2012 16:09   |
>> Hi
>> </prerequisites>
>> any clue please?
> some more details.
consider for instance the standard .cspex example to create a product
<public name="create.product" actor="ant">
<actorProperties>
<property key="buildFile" value="build/product.ant" />
<property key="targets" value="create.product" />
</actorProperties>
<properties>
<property key="profile" value="BuckyRcpMailProfile" />
<property key="iu"
value="org.eclipse.buckminster.examples.rcp.mail.product" />
</properties>
<prerequisites alias="repository">
<attribute name="site.p2" />
</prerequisites>
<products alias="destination" base="${buckminster.output}">
<path
path="BuckyRcpMail.${target.ws}.${target.os}.${target.arch}/" />
</products>
</public>
If I try to add the component to the prerequisites, e.g., like this
</prerequisites>
even if my.component is the very same component I'm in, Buckminster in
the IDE issues
Project refresh on my.component failed: No component named my.component
is known to Buckminster
removing
makes Buckminster happy again, thus I assume that the component
specification makes Buckminster consider that component somehow wrong...
cheers
Lorenzo
ICQ# lbetto, 16080134 (GNU/Linux User # 158233)
HOME: http://www.lorenzobettini.it MUSIC: http://www.purplesucker.com
http://www.myspace.com/supertrouperabba
BLOGS: http://tronprog.blogspot.com http://longlivemusic.blogspot.com
http://www.gnu.org/software/src-highlite
http://www.gnu.org/software/gengetopt
http://www.gnu.org/software/gengen http://doublecpp.sourceforge.net
TDD Book: https://leanpub.com/tdd-buildautomation-ci
Xtext Book: https://www.packtpub.com/application-development/implementing-domain-specific-languages-xtext-and-xtend-second-edition
Re: creating an action which depends on other components' actions [message #990481 is a reply to message #990474] |
Wed, 12 December 2012 16:25   |
>>> Hi
>>> </prerequisites>
>>> any clue please?
>> some more details.
> Hi
> <actorProperties>
> </actorProperties>
> <properties>
> <property key="iu"
> </properties>
> </prerequisites>
> <path
> </products>
> </public>
> </prerequisites>
> the IDE issues
> removing
You should not specify component="xxx" when "xxx" is the component itself.
- thomas
Re: creating an action which depends on other components' actions [message #990485 is a reply to message #990474] |
Wed, 12 December 2012 16:27   |
mh... wait, something has changed: if I specify components which are
different from the one I'm in, Buckminster does not complain...
>>> Hi
>>> </prerequisites>
>>> any clue please?
>> some more details.
> Hi
> <actorProperties>
> </actorProperties>
> <properties>
> <property key="iu"
> </properties>
> </prerequisites>
> <path
> </products>
> </public>
> </prerequisites>
> the IDE issues
> removing
> cheers
> Lorenzo
Re: creating an action which depends on other components' actions [message #990489 is a reply to message #990481] |
Wed, 12 December 2012 17:09   |
OK, thanks :)
now I successfully have this
component="org.eclipse.buckminster.examples.rcp.mail.feature" />
component="org.eclipse.buckminster.examples.rcp.mail.platform" />
</prerequisites>
and in the product.ant I also managed to create the corresponding list
of repositories to pass to the director like this
<target name="create.product">
... SKIP ...
<buckminster.valuepath value="${fs:repositories}"
id="repositories.valuepath"/>
<pathconvert pathsep="," property="repositories"
refid="repositories.valuepath" >
<map from="/" to="file:/"/>
</pathconvert>
<echoproperties/>
<echo message="${repositories}"/>
... SKIP ...
indeed my intention is to create two site.p2 repositories separately and
then build the product against those two, and it is working :)
but the reason I want to create those two repos separately is that for
one of them I want cbi.include.source=false (the one for the platform)
and for the other one I want it set to true... now I'm wondering: is
there a way to specify such property in the prerequisites, but just for
only one of the site.p2?
</prerequisites>
thanks in advance
Lorenzo
Re: creating an action which depends on other components' actions [message #992688 is a reply to message #990489] |
Sat, 22 December 2012 09:48  |
> OK, thanks :)
> </prerequisites>
> ... SKIP ...
> </pathconvert>
> <echoproperties/>
> ... SKIP ...
> </prerequisites>
> thanks in advance
> Lorenzo
any idea?
cheers
Lorenzo
Current Time: Fri May 27 22:07:08 GMT 2022
Powered by FUDForum. Page generated in 0.02601 seconds
