Home » Archived » Test and Performance Tools Platform (TPTP) » EXCEPTION_ACCESS_VIOLATION when running TPTP
EXCEPTION_ACCESS_VIOLATION when running TPTP [message #143290] |
Fri, 17 July 2009 02:31 |
Tom P Messages: 3 Registered: July 2009 |
Getting an EXCEPTION_ACCESS_VIOLATION when running TPTP on Galileo.
Per this:
http://dev.eclipse.org/newslists/news.eclipse.tptp/msg04720. html
Ran the logging, have an 800K zip file. Let me know if I should upload
that or whether there is something else I should be doing.
Thanks.
# An unexpected error has been detected by HotSpot Virtual Machine:
# EXCEPTION_ACCESS_VIOLATION (0xc0000005) at pc=0x0263a0d5, pid=2796,
tid=3804
# Java VM: Java HotSpot(TM) Client VM (1.5.0_09-b01 mixed mode)
# Problematic frame:
# C
--------------- T H R E A D ---------------
Current thread (0x05ba30d8): JavaThread "AWT-EventQueue-1"
siginfo: ExceptionCode=0xc0000005, reading address 0x00000300
Registers:
EAX=0x0ea86d5c, EBX=0x00000000, ECX=0x000002a0, EDX=0x00000000
ESP=0x0684ef34, EBP=0x00013ce8, ESI=0x026513d8, EDI=0x0ea86820
EIP=0x0263a0d5, EFLAGS=0x00010246
Top of Stack: (sp=0x0684ef34)
0x0684ef34: 0ea86d5c 00000000 0ea86900 02692b80
0x0684ef44: 0ea86890 0684ef80 0264b16b ffffffff
0x0684ef54: 026367c9 00013ce8 00000000 7f50a710
0x0684ef64: 00000091 00aa2701 02651498 0684f054
0x0684ef74: 003e79c8 00000000 02692bf0 0684fbe4
0x0684ef84: 0264b02c ffffffff 02634dd4 0000000e
0x0684ef94: 00000000 00013ce8 00000000 7f50a710
0x0684efa4: 00000091 00aa2701 0684f054 00bf4740
Instructions: (pc=0x0263a0d5)
0x0263a0c5: 3b c5 75 f0 8b 57 14 3b d1 75 e9 8b 07 50 8b 08
0x0263a0d5: ff 51 60 8a 4c 24 30 89 47 40 8b 44 24 2c 89 57
Stack:
Java frames: (J=compiled Java code, j=interpreted, Vv=VM code)
J org.eclipse.tptp.martini.CGProxy.MethodEnter(ZI)V
J pcgen.cdom.base.CDOMReference.getName()Ljava/lang/String;
J pcgen.cdom.reference.CDOMSimpleSingleRef.hashCode()I
J
java.util.HashMap.put(Ljava/lang/Object;Ljava/lang/Object;)L java/lang/Object;
J pcgen.base.util.WrappedMapSet.add(Ljava/lang/Object;)Z
J java.util.AbstractCollection.addAll(Ljava/util/Collection;)Z
J
pcgen.base.util.WrappedMapSet.<init>(Ljava/lang/Class;Ljava/util/Collection;)V
J pcgen.base.util.DoubleKeyMapToList.getKeySet()Ljava/util/Set ;
J
pcgen.rules.context.ConsolidatedListCommitStrategy.getAssoci ations(Lpcgen/cdom/base/CDOMList;Lpcgen/cdom/base/CDOMObject ;)Ljava/util/Collection;
J
pcgen.core.analysis.SpellLevel.getMasterLevelInfo(Lpcgen/cor e/PlayerCharacter;Lpcgen/core/spell/Spell;)Lpcgen/base/util/ HashMapToList;
v ~RuntimeStub::alignment_frame_return Runtime1 stub
j
pcgen.core.PlayerCharacter.getMasterLevelInfo(Lpcgen/core/sp ell/Spell;)Lpcgen/base/util/HashMapToList;+40
j
pcgen.core.analysis.SpellLevel.levelForKeyContains(Lpcgen/co re/spell/Spell;Ljava/util/List;ILpcgen/core/PlayerCharacter; )Z+44
j pcgen.core.Globals.getSpellsIn(ILjava/util/List;)Ljava/util/ List;+157
j
pcgen.core.PCClass.calculateKnownSpellsForClassLevel(Lpcgen/ core/PlayerCharacter;)V+49
j pcgen.core.PCClass.setLevel(ILpcgen/core/PlayerCharacter;)V+ 158
j
pcgen.core.PCClass.addLevel(Lpcgen/core/pclevelinfo/PCLevelI nfo;ZZLpcgen/core/PlayerCharacter;Z)Z+209
j
pcgen.core.PlayerCharacter.incrementClassLevel(ILpcgen/core/ PCClass;ZZ)V+353
j
pcgen.core.PlayerCharacter.incrementClassLevel(ILpcgen/core/ PCClass;Z)V+24
j
pcgen.core.PlayerCharacter.incrementClassLevel(ILpcgen/core/ PCClass;)V+23
j pcgen.gui.tabs.InfoSummary.addClass(Lpcgen/core/PCClass;I)V+ 534
j
pcgen.gui.tabs.InfoSummary.access$11(Lpcgen/gui/tabs/InfoSum mary;Lpcgen/core/PCClass;I)V+22
j
pcgen.gui.tabs.InfoSummary$4.actionPerformed(Ljava/awt/event /ActionEvent;)V+185
j
javax.swing.AbstractButton.fireActionPerformed(Ljava/awt/eve nt/ActionEvent;)V+84
j
javax.swing.AbstractButton$Handler.actionPerformed(Ljava/awt /event/ActionEvent;)V+5
j
javax.swing.DefaultButtonModel.fireActionPerformed(Ljava/awt /event/ActionEvent;)V+35
j javax.swing.DefaultButtonModel.setPressed(Z)V+117
j
javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Lja va/awt/event/MouseEvent;)V+35
j
java.awt.AWTEventMulticaster.mouseReleased(Ljava/awt/event/M ouseEvent;)V+8
j java.awt.Component.processMouseEvent(Ljava/awt/event/MouseEv ent;)V+64
j
javax.swing.JComponent.processMouseEvent(Ljava/awt/event/Mou seEvent;)V+23
j java.awt.Component.processEvent(Ljava/awt/AWTEvent;)V+81
j java.awt.Container.processEvent(Ljava/awt/AWTEvent;)V+18
j java.awt.Component.dispatchEventImpl(Ljava/awt/AWTEvent;)V+4 77
j java.awt.Container.dispatchEventImpl(Ljava/awt/AWTEvent;)V+4 2
J
java.awt.LightweightDispatcher.retargetMouseEvent(Ljava/awt/ Component;ILjava/awt/event/MouseEvent;)V
j
java.awt.LightweightDispatcher.processMouseEvent(Ljava/awt/e vent/MouseEvent;)Z+139
j java.awt.LightweightDispatcher.dispatchEvent(Ljava/awt/AWTEv ent;)Z+50
j java.awt.Container.dispatchEventImpl(Ljava/awt/AWTEvent;)V+1 2
j java.awt.Window.dispatchEventImpl(Ljava/awt/AWTEvent;)V+19
j java.awt.Component.dispatchEvent(Ljava/awt/AWTEvent;)V+2
j java.awt.EventQueue.dispatchEvent(Ljava/awt/AWTEvent;)V+46
J
pcgen.gui.PCGen_Frame1$WaitCursorEventQueue.dispatchEvent(Lj ava/awt/AWTEvent;)V
J
java.awt.EventDispatchThread.pumpOneEventForHierarchy(ILjava /awt/Component;)Z
j
java.awt.EventDispatchThread.pumpEventsForHierarchy(ILjava/a wt/Conditional;Ljava/awt/Component;)V+26
j java.awt.EventDispatchThread.pumpEvents(ILjava/awt/Condition al;)V+4
j java.awt.EventDispatchThread.pumpEvents(Ljava/awt/Conditiona l;)V+3
j java.awt.EventDispatchThread.run()V+9
v ~StubRoutines::call_stub
--------------- P R O C E S S ---------------
Java Threads: ( => current thread )
0x008d6da0 JavaThread "DestroyJavaVM"
=>0x05ba30d8 JavaThread "AWT-EventQueue-1"
0x05c00e78 JavaThread "TimerQueue" daemon
0x05bb2428 JavaThread "Thread-3" daemon
0x0569e740 JavaThread "AWT-Shutdown"
0x05f114b0 JavaThread "Java2D Disposer" daemon
0x05ddebb0 JavaThread "AWT-Windows" daemon
0x05626ed0 JavaThread "Low Memory Detector" daemon
0x05625e30 JavaThread "CompilerThread0" daemon
0x05624908 JavaThread "Signal Dispatcher" daemon
0x008ac590 JavaThread "Thread-0" daemon
0x0098dae8 JavaThread "Finalizer" daemon
0x008d4bc0 JavaThread "Reference Handler" daemon
Other Threads:
0x0098c6c8 VMThread [id=1828]
0x00911330 WatcherThread [id=1216]
VM state:not at safepoint (normal execution)
VM Mutex/Monitor currently owned by a thread: None
Heap
def new generation total 18240K, used 12927K [0x12250000, 0x13610000,
0x149b0000)
eden space 16256K, 77% used [0x12250000, 0x12ea12c8, 0x13230000)
from space 1984K, 15% used [0x13420000, 0x1346e940, 0x13610000)
to space 1984K, 0% used [0x13230000, 0x13230000, 0x13420000)
tenured generation total 241984K, used 104907K [0x149b0000, 0x23600000,
0x32250000)
the space 241984K, 43% used [0x149b0000, 0x1b022f68, 0x1b023000,
0x23600000)
compacting perm gen total 29952K, used 29946K [0x32250000, 0x33f90000,
0x36250000)
the space 29952K, 99% used [0x32250000, 0x33f8e930, 0x33f8ea00,
0x33f90000)
No shared spaces configured.
Dynamic libraries:
0x00400000 - 0x0040d000 C:\Program Files\Java\jre1.5.0_09\bin\java.exe
0x7c900000 - 0x7c9b2000 C:\WINDOWS\system32\ntdll.dll
0x7c800000 - 0x7c8f6000 C:\WINDOWS\system32\kernel32.dll
0x77dd0000 - 0x77e6b000 C:\WINDOWS\system32\ADVAPI32.dll
0x77e70000 - 0x77f02000 C:\WINDOWS\system32\RPCRT4.dll
0x77fe0000 - 0x77ff1000 C:\WINDOWS\system32\Secur32.dll
0x77c10000 - 0x77c68000 C:\WINDOWS\system32\MSVCRT.dll
0x6d6c0000 - 0x6d85b000 C:\Program
Files\Java\jre1.5.0_09\bin\client\jvm.dll
0x7e410000 - 0x7e4a1000 C:\WINDOWS\system32\USER32.dll
0x77f10000 - 0x77f59000 C:\WINDOWS\system32\GDI32.dll
0x76b40000 - 0x76b6d000 C:\WINDOWS\system32\WINMM.dll
0x5cd70000 - 0x5cd77000 C:\WINDOWS\system32\serwvdrv.dll
0x5b0a0000 - 0x5b0a7000 C:\WINDOWS\system32\umdmxfrm.dll
0x6d280000 - 0x6d288000 C:\Program Files\Java\jre1.5.0_09\bin\hpi.dll
0x76bf0000 - 0x76bfb000 C:\WINDOWS\system32\PSAPI.DLL
0x10000000 - 0x1001a000 C:\Documents and Settings\Me\My
Documents\eclipse35\plugins\org.eclipse.tptp.platform.jvmti. runtime_4.5.0.v200906121434\agent_files\win_ia32\JPIBootLoad er.dll
0x003c0000 - 0x003cb000 C:\Documents and Settings\Me\My
Documents\eclipse35\plugins\org.eclipse.tptp.platform.jvmti. runtime_4.5.0.v200906121434\agent_files\win_ia32\MartiniOSA. dll
0x00ba0000 - 0x00be1000 C:\Documents and Settings\Me\My
Documents\eclipse35\plugins\org.eclipse.tptp.platform.jvmti. runtime_4.5.0.v200906121434\agent_files\win_ia32\JPI.dll
0x00cf0000 - 0x00d0e000 C:\Documents and Settings\Me\My
Documents\eclipse35\plugins\org.eclipse.tptp.platform.ac.win _ia32_4.4.200.v200906041936\agent_controller\bin\AgentBase.d ll
0x00d10000 - 0x00d22000 C:\Documents and Settings\Me\My
Documents\eclipse35\plugins\org.eclipse.tptp.platform.ac.win _ia32_4.4.200.v200906041936\agent_controller\bin\transportSu pport.dll
0x71ab0000 - 0x71ac7000 C:\WINDOWS\system32\WS2_32.dll
0x71aa0000 - 0x71aa8000 C:\WINDOWS\system32\WS2HELP.dll
0x00d30000 - 0x00d58000 C:\Documents and Settings\Me\My
Documents\eclipse35\plugins\org.eclipse.tptp.platform.ac.win _ia32_4.4.200.v200906041936\agent_controller\bin\tptpUtils.d ll
0x12000000 - 0x12241000 C:\Documents and Settings\Me\My
Documents\eclipse35\plugins\org.eclipse.tptp.platform.ac.win _ia32_4.4.200.v200906041936\agent_controller\bin\xerces-c_2_ 6.dll
0x003f0000 - 0x00400000 C:\Documents and Settings\Me\My
Documents\eclipse35\plugins\org.eclipse.tptp.platform.ac.win _ia32_4.4.200.v200906041936\agent_controller\bin\hcclco.dll
0x00d60000 - 0x00d70000 C:\Documents and Settings\Me\My
Documents\eclipse35\plugins\org.eclipse.tptp.platform.ac.win _ia32_4.4.200.v200906041936\agent_controller\bin\hcclsm.dll
0x00d70000 - 0x00d87000 C:\Documents and Settings\Me\My
Documents\eclipse35\plugins\org.eclipse.tptp.platform.ac.win _ia32_4.4.200.v200906041936\agent_controller\bin\tptpConfig. dll
0x00d90000 - 0x00d9d000 C:\Documents and Settings\Me\My
Documents\eclipse35\plugins\org.eclipse.tptp.platform.ac.win _ia32_4.4.200.v200906041936\agent_controller\bin\processCont rolUtil.dll
0x00da0000 - 0x00dac000 C:\Documents and Settings\Me\My
Documents\eclipse35\plugins\org.eclipse.tptp.platform.ac.win _ia32_4.4.200.v200906041936\agent_controller\bin\tptpLogUtil s.dll
0x024f0000 - 0x02519000 C:\Documents and Settings\Me\My
Documents\eclipse35\plugins\org.eclipse.tptp.platform.jvmti. runtime_4.5.0.v200906121434\agent_files\win_ia32\JPIAgent.dl l
0x02630000 - 0x02657000 C:\Documents and Settings\Me\My
Documents\eclipse35\plugins\org.eclipse.tptp.platform.jvmti. runtime_4.5.0.v200906121434\agent_files\win_ia32\CGProf.dll
0x02770000 - 0x02789000 C:\Documents and Settings\Me\My
Documents\eclipse35\plugins\org.eclipse.tptp.platform.jvmti. runtime_4.5.0.v200906121434\agent_files\win_ia32\ACCollector .dll
0x02cb0000 - 0x02cbf000 C:\Documents and Settings\Me\My
Documents\eclipse35\plugins\org.eclipse.tptp.platform.jvmti. runtime_4.5.0.v200906121434\agent_files\win_ia32\CGAdaptor.d ll
0x02dd0000 - 0x02e52000 C:\Documents and Settings\Me\My
Documents\eclipse35\plugins\org.eclipse.tptp.platform.jvmti. runtime_4.5.0.v200906121434\agent_files\win_ia32\JIE.dll
0x6d690000 - 0x6d69c000 C:\Program Files\Java\jre1.5.0_09\bin\verify.dll
0x6d300000 - 0x6d31d000 C:\Program Files\Java\jre1.5.0_09\bin\java.dll
0x6d6b0000 - 0x6d6bf000 C:\Program Files\Java\jre1.5.0_09\bin\zip.dll
0x6d000000 - 0x6d169000 C:\Program Files\Java\jre1.5.0_09\bin\awt.dll
0x73000000 - 0x73026000 C:\WINDOWS\system32\WINSPOOL.DRV
0x76390000 - 0x763ad000 C:\WINDOWS\system32\IMM32.dll
0x774e0000 - 0x7761d000 C:\WINDOWS\system32\ole32.dll
0x73760000 - 0x737ab000 C:\WINDOWS\system32\ddraw.dll
0x73bc0000 - 0x73bc6000 C:\WINDOWS\system32\DCIMAN32.dll
0x7c9c0000 - 0x7d1d7000 C:\WINDOWS\system32\shell32.dll
0x77f60000 - 0x77fd6000 C:\WINDOWS\system32\SHLWAPI.dll
0x773d0000 - 0x774d3000
C:\WINDOWS\WinSxS\x86_Microsoft.Windows.Common-Controls_6595 b64144ccf1df_6.0.2600.5512_x-ww_35d4ce83\comctl32.dll
0x5d090000 - 0x5d12a000 C:\WINDOWS\system32\comctl32.dll
0x6d240000 - 0x6d27f000 C:\Program
Files\Java\jre1.5.0_09\bin\fontmanager.dll
0x6d4c0000 - 0x6d4d3000 C:\Program Files\Java\jre1.5.0_09\bin\net.dll
0x6d4e0000 - 0x6d4e9000 C:\Program Files\Java\jre1.5.0_09\bin\nio.dll
0x6d1c0000 - 0x6d1e3000 C:\Program Files\Java\jre1.5.0_09\bin\dcpr.dll
0x06580000 - 0x06586000 C:\ibmtools\aptezbtn\RAKDLL.dll
0x5b860000 - 0x5b8b5000 C:\WINDOWS\system32\netapi32.dll
0x71b20000 - 0x71b32000 C:\WINDOWS\system32\MPR.dll
0x75f60000 - 0x75f67000 C:\WINDOWS\System32\drprov.dll
0x71c10000 - 0x71c1e000 C:\WINDOWS\System32\ntlanman.dll
0x71cd0000 - 0x71ce7000 C:\WINDOWS\System32\NETUI0.dll
0x71c90000 - 0x71cd0000 C:\WINDOWS\System32\NETUI1.dll
0x71c80000 - 0x71c87000 C:\WINDOWS\System32\NETRAP.dll
0x71bf0000 - 0x71c03000 C:\WINDOWS\System32\SAMLIB.dll
0x75f70000 - 0x75f7a000 C:\WINDOWS\System32\davclnt.dll
0x77920000 - 0x77a13000 C:\WINDOWS\system32\SETUPAPI.dll
0x77b40000 - 0x77b62000 C:\WINDOWS\system32\appHelp.dll
0x76fd0000 - 0x7704f000 C:\WINDOWS\system32\CLBCATQ.DLL
0x77050000 - 0x77115000 C:\WINDOWS\system32\COMRes.dll
0x77120000 - 0x771ab000 C:\WINDOWS\system32\OLEAUT32.dll
0x77c00000 - 0x77c08000 C:\WINDOWS\system32\VERSION.dll
0x76980000 - 0x76988000 C:\WINDOWS\system32\LINKINFO.dll
0x76990000 - 0x769b5000 C:\WINDOWS\system32\ntshrui.dll
0x76b20000 - 0x76b31000 C:\WINDOWS\system32\ATL.DLL
0x769c0000 - 0x76a74000 C:\WINDOWS\system32\USERENV.dll
0x76400000 - 0x765a5000 C:\WINDOWS\system32\NETSHELL.dll
0x76c00000 - 0x76c2e000 C:\WINDOWS\system32\credui.dll
0x478c0000 - 0x478ca000 C:\WINDOWS\system32\dot3api.dll
0x76e80000 - 0x76e8e000 C:\WINDOWS\system32\rtutils.dll
0x736d0000 - 0x736d6000 C:\WINDOWS\system32\dot3dlg.dll
0x5dca0000 - 0x5dcc8000 C:\WINDOWS\system32\OneX.DLL
0x76f50000 - 0x76f58000 C:\WINDOWS\system32\WTSAPI32.dll
0x76360000 - 0x76370000 C:\WINDOWS\system32\WINSTA.dll
0x77a80000 - 0x77b15000 C:\WINDOWS\system32\CRYPT32.dll
0x77b20000 - 0x77b32000 C:\WINDOWS\system32\MSASN1.dll
0x745b0000 - 0x745d2000 C:\WINDOWS\system32\eappcfg.dll
0x76080000 - 0x760e5000 C:\WINDOWS\system32\MSVCP60.dll
0x5dcd0000 - 0x5dcde000 C:\WINDOWS\system32\eappprxy.dll
0x76d60000 - 0x76d79000 C:\WINDOWS\system32\iphlpapi.dll
0x0b530000 - 0x0b558000 C:\Program Files\Trillian\events.dll
0x763b0000 - 0x763f9000 C:\WINDOWS\system32\comdlg32.dll
0x7c340000 - 0x7c396000 C:\Program Files\Trillian\MSVCR71.dll
VM Arguments:
jvm_args: -Xms256m -Xmx512m
-agentlib:JPIBootLoader=JPIAgent:server=controlled;CGProf
java_command: pcgen.gui.pcGenGUI
Launcher Type: SUN_STANDARD
Environment Variables:
JAVA_HOME=C:\Program Files\Java\jdk1.5.0_09
PATH=C:\Program Files\Java\jre1.5.0_09\bin\java.exe;C:\Documents and
Settings\Me\My
Documents\eclipse35\plugins\org.eclipse.tptp.platform.jvmti. runtime_4.5.0.v200906121434\agent_files\win_ia32;C:\Document s
and Settings\Me\My
Documents\eclipse35\plugins\org.eclipse.hyades.probekit_4.2. 500.v200906121434\os\win32\x86;C:\Documents
and Settings\Me\My
Documents\eclipse35\plugins\org.eclipse.tptp.platform.ac.win _ia32_4.4.200.v200906041936\agent_controller\bin;C:/Program
Files/Java/jre1.5.0_09/bin/client;C:/Program
Files/Java/jre1.5.0_09/bin;C:\texmf\miktex\bin;C:\WINDOWS\sy stem32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program
Files\Java\jdk1.5.0_09\bin;C:\Documents and Settings\Me\My
Documents\Computer\Extensions\apache-ant-1.6.4\BIN;C:\Docume nts and
Settings\Me\My Documents\Computer\Extensions\javacc-3.2\bin;C:\Program
Files\Common Files\Roxio Shared\DLLShared;"C:\Program Files\Zone
Labs\ZoneAlarm\MailFrontier";C:\Program
Files\QuickTime\QTSystem\;C:\Program Files\Common
Files\GTK\2.0\bin;C:\Program Files\Graphviz2.22\bin
USERNAME=Me
OS=Windows_NT
PROCESSOR_IDENTIFIER=x86 Family 15 Model 2 Stepping 9, GenuineIntel
--------------- S Y S T E M ---------------
OS: Windows XP Build 2600 Service Pack 3
CPU:total 1 (cores per cpu 1, threads per core 1) family 15 model 2
stepping 9, cmov, cx8, fxsr, mmx, sse, sse2
Memory: 4k page, physical 1571824k(693252k free), swap 2208276k(1213796k
free)
vm_info: Java HotSpot(TM) Client VM (1.5.0_09-b01) for windows-x86, built
on Sep 7 2006 13:59:31 by "java_re" with MS VC++ 6.0
Current Time: Tue Mar 19 06:43:48 GMT 2024
Powered by FUDForum. Page generated in 0.01894 seconds
