Re: [CDO]Rollback in DBStore NullPointerException [message #990143 is a reply to message #990103] |
Tue, 11 December 2012 06:50 |
Hi Andrew,
A customer of mine just reported the same exception. It's related to the default value of an EEnum-typed EAttribute. The
following EMF method is called: org.eclipse.emf.ecore.EEnum.getEEnumLiteralByLiteral(String) and to me it seems to
expect the text *literal* and not the integer (ordinal) value of the EEnumLiteral. Can you please double-check your meta
model and report here if changing it helps?
Cheers
/Eike
http://www.esc-net.de
Am 10.12.2012 22:49, schrieb Andrew Whelan:
> Hello.
> I am trying to save an object that extends CDOObject to a database and am getting an exception that seems to be coming
> from the server. The server is talking to a MySQL database. The server is an instance of the
> org.eclipse.emf.cdo.server.product.tcp_h2 product using a cdo-server.xml with the following dbAdapter configuration:
> <dbAdapter name="mysql"/>
> <dataSource class="com.mysql.jdbc.jdbc2.optional.MysqlDataSource"
> url="jdbc:mysql://localhost:3306/repo1"
> user="root"
> password="password"/>
> It worked using the following tutorial (with a few minor changes): http://www.rcp-vision.com/?p=1285&lang=en.
> This Server is being run from the IDE.
> Note that this all happens the first time a database call is made so there is an empty database schema "repo1" when we
> start. When the following exception is thrown the CDO meta tables are created (auto created by the server) and some
> data is actually added to those tables but I'm pretty sure the CDO meta data never gets fully set. When I try to run
> the same code a second time I get a duplicate key exception.
> Following is a dumbed down version of the client code, followed by the exception. I'm just wondering if this exception
> means anything to any of you? It looks like it's coming from the server end and I'm having a difficult time debugging
> this. Any help would be appreciated. Thanks
> Andrew
> PS: What is the significance of the string "/res1" in CDOResource resource = transaction
> .getOrCreateResource("/res1") ????
> CODE:
> public class ReferenceTest {
> private static CDOSession cdoSession;
> public static void init() {
> // The following lines are not needed if the extension
> // registry (OSGi/Equinox) is running
> Net4jUtil.prepareContainer(IPluginContainer.INSTANCE);
> TCPUtil.prepareContainer(IPluginContainer.INSTANCE);
> cdoSession = openSession("repo1");
> public static CDOSession openSession(String repoName) {
> final IConnector connector = (IConnector) IPluginContainer.INSTANCE
> .getElement( //
> "org.eclipse.net4j.connectors", // Product group
> "tcp", // Type
> "localhost"); // Description
> CDOSessionConfiguration config = CDONet4jUtil
> .createSessionConfiguration();
> ((CDONet4jSessionConfiguration) config).setConnector(connector);
> ((CDONet4jSessionConfiguration) config).setRepositoryName(repoName);
> CDOSession session = config.openSession();
> session.addListener(new LifecycleEventAdapter() {
> @Override
> protected void onDeactivated(ILifecycle lifecycle) {
> connector.close();
> return session;
> * Saves the List of EObjects to the specified URI. The URI must not be null.
> * * @param uri
> * @param objects
> * @throws IOException
> //public static void save(List<EObject> objects) throws IOException {
> public static void save(EObject object) throws IOException {
> try
> init();
> CDOTransaction transaction = cdoSession.openTransaction();
> .getOrCreateResource("/res1");
> resource.getContents().add(object);
> transaction.commit();
> cdoSession.close();
> } catch (CommitException e) {
> e.printStackTrace();
> } finally {
> if(cdoSession!=null){
> cdoSession.close();
> public static void main(String [] args)
> java.lang.System.out.println("Starting");
> //Designator extends an object that extends CDOObject
> Designator d = ReferenceFactory.eINSTANCE.createDesignator();
> String valid = "Y";
> d.getValid().add(valid);
> //Reference extends an object that extends CDOObject
> Reference r = ReferenceFactory.eINSTANCE.createReference();
> r.getDesignator().add(d);
> try
> save(d);
> catch(Exception e)
> System.out.println("End");
> EXCEPTON (NOTE: The trace after the string "End" is client side)
> Starting
> org.eclipse.emf.cdo.util.CommitException: Rollback in DBStore: java.lang.NullPointerException
> at org.eclipse.emf.cdo.server.internal.db.mapping.CoreTypeMappings$TMEnum.getDefaultValue(CoreTypeMappings.java:87)
> at org.eclipse.emf.cdo.server.db.mapping.AbstractTypeMapping.setValue(AbstractTypeMapping.java:115)
> at org.eclipse.emf.cdo.server.db.mapping.AbstractTypeMapping.setValueFromRevision(AbstractTypeMapping.java:94)
> at
> org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalBranchingClassMapping.writeValues(HorizontalBranchingClassMapping.java:645)
> at
> org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalBranchingClassMapping.writeRevision(HorizontalBranchingClassMapping.java:842)
> at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.writeRevision(DBStoreAccessor.java:584)
> at org.eclipse.emf.cdo.server.internal.db.DBStoreAccessor.writeRevisions(DBStoreAccessor.java:564)
> at org.eclipse.emf.cdo.spi.server.StoreAccessor.doWrite(StoreAccessor.java:94)
> at org.eclipse.emf.cdo.spi.server.StoreAccessorBase.write(StoreAccessorBase.java:149)
> at org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:487)
> at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:43)
> at org.eclipse.emf.cdo.spi.server.InternalCommitContext$1.runLoop(InternalCommitContext.java:1)
> at org.eclipse.net4j.util.om.monitor.ProgressDistributor.run(ProgressDistributor.java:96)
> at
> org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicatingCommit(CommitTransactionIndication.java:262)
> at
> org.eclipse.emf.cdo.server.internal.net4j.protocol.CommitTransactionIndication.indicating(CommitTransactionIndication.java:96)
> at
> org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndicationWithMonitoring.indicating(CDOServerIndicationWithMonitoring.java:109)
> at org.eclipse.net4j.signal.IndicationWithMonitoring.indicating(IndicationWithMonitoring.java:86)
> at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedInput(IndicationWithResponse.java:92)
> at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328)
> at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:65)
> at org.eclipse.net4j.signal.IndicationWithMonitoring.execute(IndicationWithMonitoring.java:65)
> at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
> at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
> at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
> at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
> at java.lang.Thread.run(Unknown Source)
> End
> at
> org.eclipse.emf.internal.cdo.transaction.CDOSingleTransactionStrategyImpl.commit(CDOSingleTransactionStrategyImpl.java:85)
> at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1144)
> at org.eclipse.emf.internal.cdo.transaction.CDOTransactionImpl.commit(CDOTransactionImpl.java:1164)
> at com.src.ewir.nighthawk.analysis.models.reference.test.ReferenceTest.save(ReferenceTest.java:91)
> at com.src.ewir.nighthawk.analysis.models.reference.test.ReferenceTest.main(ReferenceTest.java:140)
Cheers
/Eike
Re: [CDO]Rollback in DBStore NullPointerException [message #990145 is a reply to message #990143] |
Tue, 11 December 2012 07:17 |
Am 11.12.2012 07:50, schrieb Eike Stepper:
> Hi Andrew,
> The following EMF method is called: org.eclipse.emf.ecore.EEnum.getEEnumLiteralByLiteral(String) and to me it seems to
> meta model and report here if changing it helps?
I found this bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=335942
I strongly recommend that you comment on that bugzilla to show that it's worth to be fixed soon!
Cheers
/Eike
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
>> Hello.
>> coming from the server. The server is talking to a MySQL database. The server is an instance of the
>> user="root"
>> we start. When the following exception is thrown the CDO meta tables are created (auto created by the server) and
>> some data is actually added to those tables but I'm pretty sure the CDO meta data never gets fully set. When I try to
>> run the same code a second time I get a duplicate key exception.
>> exception means anything to any of you? It looks like it's coming from the server end and I'm having a difficult time
>> debugging this. Any help would be appreciated. Thanks
>> Andrew
>> CODE:
>> .getElement( //
>> "tcp", // Type
>> @Override
>> connector.close();
>> return session;
>> * * @param uri
>> * @param objects
>> try
>> init();
>> cdoSession.close();
>> } finally {
>> cdoSession.close();
>> String valid = "Y";
>> try
>> save(d);
>> catch(Exception e)
>> Starting
>> at
>> at
>> at
>> at
>> at
>> End
>> at
Cheers
/Eike
FUDForum. Page generated in 0.02166 seconds
