Home » Eclipse Projects » Rich Client Platform (RCP) » Disable text search(Adding org.eclipse.search but do not show the text search)
Disable text search [message #989746] Fri, 07 December 2012 13:49 Go to next message
Frank Benoit is currently offline Frank BenoitFriend
Hi All,
in my application I have added the org.eclipse.search plugin and implemented a search and result page.
This works.
But there is the text search page, which makes no sense to my application.
As a user, I can select to hide. But, is there a way to programatically hide from the beginning? And to avoid the user can even activate it?
thx
Frank
Re: Disable text search [message #989937 is a reply to message #989746] Mon, 10 December 2012 07:35 Go to previous messageGo to next message
Sumit Singh is currently offline Sumit SinghFriend
Can you please give us little more information about your requirement it detail.
[Updated on: Mon, 10 December 2012 07:40]
Report message to a moderator
Re: Disable text search [message #990864 is a reply to message #989746] Fri, 14 December 2012 15:05 Go to previous message
Hi Sumit
thanks for the reply.
Attached is the search dialog, that I see when I run my application.
I implemented the search "Severity", but the search "File Search" is available too.
index.php/fa/12716/0/
Because "File Search" does not make any sense in my application, I want to disable (or hide) it completely. It shall also not be available, if the "customize" button is pressed.
Frank
  • Attachment: search.png
    (Size: 59.12KB, Downloaded 457 times)
Previous Topic:Convert multiple Eclipse Plugins into a single RCP Application
Next Topic:Eclipse 4 RCP getting parts via EPartService
Current Time: Fri Jan 28 12:26:54 GMT 2022
Powered by FUDForum. Page generated in 0.02166 seconds
